[Eugenia] Subdiagrams [message #582431] |
Fri, 30 October 2009 12:51 |
Christoph Wienands Messages: 55 Registered: July 2009 |
Member |
Hello all,
I just started with Eugenia and I am really impressed how quickly I was able to create a DSL, after having spent days before with "raw" GMF.
Now I was wondering whether it was possible to do subdiagrams with Eugenia. For example, I'm thinking about state machines where you can expand a composite state into a second diagram with its details. Or think of a network topology with routers, connections, etc. in a top-level diagram, and routing tables, NAT settings in subdiagrams for each router.
I once was able to get subdiagrams of the same type as the parent diagram working (it was a couple of settings in the gmfmap), but never got subdiagrams of different types working. It required a really ugly workaround with two sets of gmfmap, gmftool, and gmfgen.
http://wiki.eclipse.org/Diagram_Partitioning
If you ever got the different subdiagram type working (I didn't), you could never use the generators again if you made changes to your DSL :( So I figured, Eugenia would be predestined for subdiagram support because all the GMF artifacts are completely regenerated after changes to the DSL.
I didn't see any annotations in the Eugenia reference that would support that feature. Has anybody done that before (maybe with a couple of those generated code overrides, forgot the name)? Or is this maybe a planned feature?
Thanks a lot, Christoph
FUDForum. Page generated in 0.03672 seconds
