Home » Archived » Visual Editor (VE) » Is there any easy way to disable the "visual nature"?
Is there any easy way to disable the "visual nature"? [message #56368] Fri, 20 August 2004 08:04 Go to next message
Originally posted by: anders_biehl.yahoo.com
I use the VE only for prototyping, but if a prototype "makes it" then it
would be nice to not have the VE and palette appear if I open a file for
editing.
Simply deleting the non-<nature>org.eclipse.jdt.core.javanature</nature>
from the .project file just seems to mess up the VE.
Anders
Re: Is there any easy way to disable the "visual nature"? [message #56402 is a reply to message #56368] Fri, 20 August 2004 09:26 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
Hi Anders,
Whenever you'd rather open a class with the Java editor rather than the
Visual Editor, select the class in the package explorer, right click on
it and choose Open With->Java Editor. The association of that file will
change to always open with the Java Editor, until you choose to Open
With->Visual Editor later on.
- Jeff
> editing.
> Thanks
> Anders
Re: Is there any easy way to disable the "visual nature"? [message #57592 is a reply to message #56402] Thu, 26 August 2004 07:13 Go to previous message
Thanks a lot.
This seems logical - sorry for having to ask about that.
-Anders
"Jeff Myers" <myersj@nospam.gmail.com> wrote in message
news:cg4tu8$ne$1@eclipse.org...
> Hi Anders,
> - Jeff
> > editing.
> > Thanks
> > Anders
Re: Is there any easy way to disable the "visual nature"? [message #597430 is a reply to message #56368] Fri, 20 August 2004 09:26 Go to previous message
Hi Anders,
- Jeff
> editing.
> Thanks
> Anders
Re: Is there any easy way to disable the "visual nature"? [message #597801 is a reply to message #56402] Thu, 26 August 2004 07:13 Go to previous message
Thanks a lot.
-Anders
> Hi Anders,
> - Jeff
> > editing.
> > Thanks
> > Anders
Previous Topic:Integrating java code generated from an EMF model with JBuilder, VE1.0 or IBM AIUML toolkit
Next Topic:Integration Build 20040825 available
Current Time: Sat Sep 13 01:59:21 EDT 2025
Powered by FUDForum. Page generated in 0.04693 seconds
