Re: Export to PNG and Problems with class diagrams [message #556249 is a reply to message #554743] |
Tue, 31 August 2010 13:18 |
Markus Lorenz Messages: 11 Registered: August 2010 |
Junior Member |
Angi wrote on Tue, 24 August 2010 06:10 | There is no print symbol, no print in the menu, oder something like save as image.
Maybe you misunderstood Patrick?
The option to export images can be found in the context menu. You have to click into the diagram with the right button of your mouse.Then the context menu appears next to your mouse pointer. The option can not be found in the menu at the top of the window!
In the context menu there are several items starting with "Filter views...", "Add", "Navigate", and the fourth item is "File". Inside "File" you can find "Save As Image File...". You can choose between several formats like GIF, PNG, SVG, and PDF in the dialog. Though PDF is not working for me.
EDIT: The context menu can have different items, depending on where on your diagram you click. The items I listed appear if you right click somewhere into the diagram where no element is placed. If you do right click on an element some items are missing. But "File" is always there.
[Updated on: Tue, 31 August 2010 13:25] Report message to a moderator
FUDForum. Page generated in 0.04612 seconds
