Re: Page Break fails with bulky data [message #551485 is a reply to message #551477] |
Fri, 06 August 2010 15:05 |
What version of BIRT are you using?
Can you post the report plus data to run it?
On 8/6/2010 10:57 AM, srikanth wrote:
> Hello Everyone,
> I have a Rpt design as with a table and two rows and both are filled
> with the "dynamic text" element..
> This what i have done,
> 1)Defined a data source and a Dataset.
> 2)Defined one string element in the data set.
> 3)Binded the table with the dataset.
> 4)For the dataset Script, In a while loop(count until less than 3) ,I am
> assigning a very bulky data(say 1000 words) to the data set element
> under the "fetch" section.
> 5)I have given page break After,page break before,page break inside as
> "avoid" for the table.
> 6)When i generate the report as pdf,The page break avoid fails..
> Any suggestions will be really helpful..
Re: Page Break fails with bulky data [message #551496 is a reply to message #551493] |
Fri, 06 August 2010 16:12 |
The report did not run form me. I did not see any fetch code for the
main dataset.
Jason
On 8/6/2010 11:58 AM, srikanth wrote:
> Hey Jason,
> I am using BIRT 2.6...
> Below is the xml Source of the rpt design,
> <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version 2.6.0.v20100531
> Build <2.6.0.v20100609-1613></property>
> <property name="units">in</property>
> <property name="iconFile">/templates/blank_report.gif</property>
> <property name="bidiLayoutOrientation">ltr</property>
> <property name="imageDPI">96</property>
> <data-sources>
> <script-data-source name="DataSource" id="195"/>
> </data-sources>
> <data-sets>
> <script-data-set name="SubDataSet" id="196">
> <list-property name="resultSetHints">
> <structure>
> <property name="position">1</property>
> <property name="name">tableHeaderField1</property>
> <property name="dataType">string</property>
> </structure>
> <structure>
> <property name="position">2</property>
> <property name="name">tableHeaderField2</property>
> </structure>
> <structure>
> <property name="position">3</property>
> <property name="name">tableHeaderField1Value</property>
> </structure>
> <structure>
> <property name="position">4</property>
> <property name="name">tableHeaderField2Value</property>
> </structure>
> <structure>
> <property name="position">5</property>
> <property name="name">tableField1</property>
> </structure>
> <structure>
> <property name="position">6</property>
> <property name="name">tableField2</property>
> </structure>
> <structure>
> <property name="position">7</property>
> <property name="name">tableField3</property>
> </structure>
> <structure>
> <property name="position">8</property>
> <property name="name">tableField4</property>
> </structure>
> <structure>
> <property name="position">9</property>
> <property name="name">tableField5</property>
> </structure>
> <structure>
> <property name="position">10</property>
> <property name="name">tableField6</property>
> </structure>
> <structure>
> <property name="position">11</property>
> <property name="name">tableField7</property>
> </structure>
> <structure>
> <property name="position">12</property>
> <property name="name">tableField8</property>
> </structure>
> <structure>
> <property name="position">13</property>
> <property name="name">tableField9</property>
> </structure>
> <structure>
> <property name="position">14</property>
> <property name="name">tableField10</property>
> </structure>
> <structure>
> <property name="position">15</property>
> <property name="name">tableField11</property>
> </structure>
> <structure>
> <property name="position">16</property>
> <property name="name">tableField1Value</property>
> </structure>
> <structure>
> <property name="position">17</property>
> <property name="name">tableField2Value</property>
> </structure>
> <structure>
> <property name="position">18</property>
> <property name="name">tableField3Value</property>
> </structure>
> <structure>
> <property name="position">19</property>
> <property name="name">tableField4Value</property>
> </structure>
> <structure>
> <property name="position">20</property>
> <property name="name">tableField5Value</property>
> </structure>
> <structure>
> <property name="position">21</property>
> <property name="name">tableField6Value</property>
> </structure>
> <structure>
> <property name="position">22</property>
> <property name="name">tableField7Value</property>
> </structure>
> <structure>
> <property name="position">23</property>
> <property name="name">tableField8Value</property>
> </structure>
> <structure>
> <property name="position">24</property>
> <property name="name">tableField9Value</property>
> </structure>
> <structure>
> <property name="position">25</property>
> <property name="name">tableField10Value</property>
> </structure>
> <structure>
> <property name="position">26</property>
> <property name="name">tableField11Value</property>
> </structure>
> </list-property>
> <list-property name="columnHints">
> <structure>
> <property name="columnName">tableHeaderField1</property>
> <text-property name="displayName">tableHeaderField1</text-property>
> </structure>
> <structure>
> <property name="columnName">tableHeaderField2</property>
> <text-property name="displayName">tableHeaderField2</text-property>
> </structure>
> <structure>
> <property name="columnName">tableHeaderField1Value</property>
> <text-property name="displayName">tableHeaderField1Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableHeaderField2Value</property>
> <text-property name="displayName">tableHeaderField2Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField1</property>
> <text-property name="displayName">tableField1</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField2</property>
> <text-property name="displayName">tableField2</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField3</property>
> <text-property name="displayName">tableField3</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField4</property>
> <text-property name="displayName">tableField4</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField5</property>
> <text-property name="displayName">tableField5</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField6</property>
> <text-property name="displayName">tableField6</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField7</property>
> <text-property name="displayName">tableField7</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField8</property>
> <text-property name="displayName">tableField8</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField9</property>
> <text-property name="displayName">tableField9</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField10</property>
> <text-property name="displayName">tableField10</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField11</property>
> <text-property name="displayName">tableField11</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField1Value</property>
> <text-property name="displayName">tableField1Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField2Value</property>
> <text-property name="displayName">tableField2Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField3Value</property>
> <text-property name="displayName">tableField3Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField4Value</property>
> <text-property name="displayName">tableField4Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField5Value</property>
> <text-property name="displayName">tableField5Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField6Value</property>
> <text-property name="displayName">tableField6Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField7Value</property>
> <text-property name="displayName">tableField7Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField8Value</property>
> <text-property name="displayName">tableField8Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField9Value</property>
> <text-property name="displayName">tableField9Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField10Value</property>
> <text-property name="displayName">tableField10Value</text-property>
> </structure>
> <structure>
> <property name="columnName">tableField11Value</property>
> <text-property name="displayName">tableField11Value</text-property>
> </structure>
> </list-property>
> <structure name="cachedMetaData">
> <list-property name="resultSet">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <property name="dataSource">DataSource</property>
> <method name="open"><![CDATA[count = 0;]]></method>
> <method name="fetch"><![CDATA[while(count<3)
> row["tableHeaderField1"]="testiheadertesting the headertesting the
> headertesting the headertesting thetestiheadertesting the headertesting
> the headertesting the headertesting thetestiheadertesting the
> headertesting the headertesting the headertesting thetestiheadertesting
> the headertesting the headertesting the headertesting
> thetestiheadertesting the headertesting the headertesting the
> headertesting thetestiheadertesting the headertesting the headertesting
> the headertesting thetestiheadertesting the headertesting the
> the headertesting the headertesting theing the headertesting the
> the headertesting the headertesting the";
> count++;
> }]]></method>
> </script-data-set>
> <script-data-set name="MainDataSet" id="222">
> <structure>
> <property name="name">title</property>
> </structure>
> <structure>
> <property name="name">titleValue</property>
> </structure>
> </list-property>
> <structure>
> <property name="columnName">title</property>
> <text-property name="displayName">title</text-property>
> </structure>
> <structure>
> <property name="columnName">titleValue</property>
> <text-property name="displayName">titleValue</text-property>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> </script-data-set>
> </data-sets>
> <styles>
> <style name="report" id="4">
> <property name="fontFamily">sans-serif</property>
> <property name="fontSize">10pt</property>
> </style>
> <style name="crosstab-cell" id="5">
> <property name="borderBottomColor">#CCCCCC</property>
> <property name="borderBottomStyle">solid</property>
> <property name="borderBottomWidth">1pt</property>
> <property name="borderLeftColor">#CCCCCC</property>
> <property name="borderLeftStyle">solid</property>
> <property name="borderLeftWidth">1pt</property>
> <property name="borderRightColor">#CCCCCC</property>
> <property name="borderRightStyle">solid</property>
> <property name="borderRightWidth">1pt</property>
> <property name="borderTopColor">#CCCCCC</property>
> <property name="borderTopStyle">solid</property>
> <property name="borderTopWidth">1pt</property>
> </style>
> <style name="crosstab" id="6">
> </style>
> </styles>
> <page-setup>
> <simple-master-page name="Simple MasterPage" id="2">
> <page-footer>
> <text id="3">
> <property name="contentType">html</property>
> <text-property name="content"><![CDATA[<value-of>new
> Date()</value-of>]]></text-property>
> </text>
> </page-footer>
> </simple-master-page>
> </page-setup>
> <body>
> <table id="197">
> <property name="dataSet">SubDataSet</property>
> <list-property name="boundDataColumns">
> <structure>
> <expression name="expression"
> type="javascript">dataSetRow["tableHeaderField1"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableHeaderField2"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableHeaderField1Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableHeaderField2Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField1"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField2"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField3"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField4"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField5"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField6"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField7"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField8"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField9"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField10"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField11"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField1Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField2Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField3Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField4Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField5Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField6Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField7Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField8Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField9Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField10Value"]</expression >
> </structure>
> <structure>
> type="javascript">dataSetRow["tableField11Value"]</expression >
> </structure>
> </list-property>
> <column id="204"/>
> <detail>
> <row id="200">
> <cell id="201">
> <table id="280">
> <property name="pageBreakAfter">avoid</property>
> <column id="317"/>
> <column id="318"/>
> <column id="319"/>
> <column id="320"/>
> <column id="321"/>
> <column id="322"/>
> <column id="323"/>
> <column id="324"/>
> <column id="325"/>
> <column id="326"/>
> <column id="327"/>
> <detail>
> <row id="293">
> <cell id="294">
> <property name="colSpan">11</property>
> <property name="rowSpan">1</property>
> <property name="borderBottomColor">#000000</property>
> <property name="borderBottomWidth">thin</property>
> <property name="borderLeftColor">#000000</property>
> <property name="borderLeftWidth">thin</property>
> <property name="borderRightColor">#000000</property>
> <property name="borderRightWidth">thin</property>
> <property name="borderTopColor">#000000</property>
> <property name="borderTopWidth">thin</property>
> <text-data id="328">
> <property name="fontWeight">bold</property>
> <expression name="valueExpr">"First Row"</expression>
> </text-data>
> </cell>
> </row>
> <row id="329">
> <cell id="330">
> <text-data id="341">
> <expression name="valueExpr">row["tableHeaderField1"]</expression>
> </text-data>
> </cell>
> </row>
> </detail>
> </table>
> </cell>
> </row>
> </detail>
> </table>
> </body>
> </report>
FUDForum. Page generated in 0.05525 seconds
