Home » Modeling » Epsilon » [EuGENia] attribute declarations with multiplicity expressions
[EuGENia] attribute declarations with multiplicity expressions [message #550767] Wed, 04 August 2010 06:01 Go to next message
Hi All,
I am looking for some example in Eugenia about attribute declarations with multiplicity expressions.
For example
class workshop {
attr String[0..10]  student;
attr String[*] participant;
I have a workshop model in which I want to specify students with their names as attributes. I do not want to specify it like.
val student [*]  student.
class student {
attr String name;
As I want student attribute to be the part of workshop not an extra node in canvas. Some tip would be helpful.
Kindly,
Syed Imran
Re: [EuGENia] attribute declarations with multiplicity expressions [message #550844 is a reply to message #550767] Wed, 04 August 2010 09:40 Go to previous messageGo to next message
Hi Syed,
Would it be feasible to use a compartment for the students? Something like the following code:
@gmf.node(foo="bar")
class Workshop {
  @gmf.compartment(layout="list")
  val Student[*] students
@gmf.node(label="name")
class Student {
  attr String name;
This will allow Student nodes to be placed inside Workshops.
If this is not feasible, then it might be best to post the question on the GMF forums. Once you have a GMF editor that you're satisfied with, we may be able to extract a further annotation for EuGENia...
Louis.
Re: [EuGENia] attribute declarations with multiplicity expressions [message #550857 is a reply to message #550844] Wed, 04 August 2010 10:05 Go to previous messageGo to next message
Hi Louis,
I have also tried the compartment option, but the problem is if the number of students is 10 or 20, it gets real messy in the view. Further, one cannot get the whole informaiton just by clicking the workshop icon "Show Properties View" and a click on each compartment is required to view their properties.
Else if there is any way possible to show the node and its compartment properties in one view. For example if I click workshop icon "Show Properties View" all the properties of its compartments also become visible.
I am basically trying to solve this problem at Eugenia level level before posting it on the GMF forums.
kindly,
Syed Imran
Re: [EuGENia] attribute declarations with multiplicity expressions [message #551103 is a reply to message #550857] Thu, 05 August 2010 05:13 Go to previous messageGo to next message
Hi Syed,
You're right - the compartment view takes up on awful lot of room because each student is represented as a node. It might be better if we could achieve something like in the Ecore diagram editor where properties are displayed inside classes. I don't think there's any support in EuGENia for this yet though...
As you mention that it might be desirable to customise the properties view, it may be best to post a question on the GMF forums. EuGENia can't do this right now, and I'm not sure to what extent GMF supports customisation of other views.
Sorry that I can't be any more constructive. If you do find an answer, please do let us know and we'll consider capturing the pattern in EuGENia -- it does sound very useful.
Louis.
Re: [EuGENia] attribute declarations with mul tiplicity expressions [message #551147 is a reply to message #551103] Thu, 05 August 2010 08:48 Go to previous messageGo to next message
Hi Syed,
You could reduce the space taken by nodes in the compartment using a
polishing transformation as shown in the class diagram example in
http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-poli shing/
Dimitris
Louis Rose <louis@cs.york.ac.uk> wrote:
> Hi Syed,
> Cheers,
> Louis.
Re: [EuGENia] attribute declarations with mul tiplicity expressions [message #551149 is a reply to message #551147] Thu, 05 August 2010 08:54 Go to previous messageGo to next message
Hi Dimitris,
Yes, you are right as this is the only option left to make it look better, as I have not recieved any reply of the same post from GMF forums.
regards
Syed Imran
Re: [EuGENia] attribute declarations with mul tiplicity expressions [message #592710 is a reply to message #551147] Thu, 05 August 2010 08:54 Go to previous message
Hi Dimitris,
regards
Syed Imran
Previous Topic:Re: [EuGENia] attribute declarations with multiplicity expressions
Next Topic:How to not append a result model each time running an etl transformation
Current Time: Sun Jul 13 01:28:39 EDT 2025
Powered by FUDForum. Page generated in 0.05205 seconds
