Re: Missing TOC for Word [message #550001 is a reply to message #549554] |
Wed, 28 July 2010 17:21 |
When you export the doc, can you try and doing a refresh on the TOC in word?
Jason
On 7/27/2010 4:07 AM, anitescu@gmail.com wrote:
> I have created a simple BIRT report . When I export it as PDF I get a
> TOC in a frame to the left. But if I export the report to .doc (Word
> document) there is no TOC.
> There is some additional configuration to do in order to get it ?
Re: Missing TOC for Word [message #550240 is a reply to message #550114] |
Thu, 29 July 2010 15:01 |
Can you open a bug for this. Make sure to specify the version of BIRT
you are using.
On 7/29/2010 3:57 AM, anitescu@gmail.com wrote:
> Yes, I did. But it does not work:
> "Aucune entrée de table des matières n'a été trouvée."
> In other words, it does not find no TOC entry ...
FUDForum. Page generated in 0.03384 seconds
