Home » Newcomers » Newcomers » set path for Javadoc
set path for Javadoc [message #55170] Tue, 19 April 2005 20:37 Go to next message
I am trying to add Javadoc.exe in eclipse. But after I click
on windows -> Preference -> Java, I cannot find Javadoc as suggested
in the help file. Therefore I cannot set the path for Javadoc.exe.
COuld someone tell me how I should set the path for javadoc.exe.
Thanks.
Newbie
Re: set path for Javadoc [message #55280 is a reply to message #55170] Wed, 20 April 2005 02:07 Go to previous message
You can configure it directly before launching javadoc:
- Select "Project", "Generate Javadoc..."
- In the dialog that appears now, hit the button [Configure...] and
select the javadoc.exe you want to use.
Hope this helps
Michael Pellaton
Previous Topic:Where's the example?
Next Topic:Can't run Eclipse
Current Time: Sat Oct 04 15:31:06 EDT 2025
Powered by FUDForum. Page generated in 0.07696 seconds
