Re: java.lang.IllegalArgumentException when generate MS word [message #538461 is a reply to message #538309] |
Mon, 07 June 2010 16:45 |
Can you post the report?
On 6/7/2010 6:01 AM, Alex Chen wrote:
> Hi BIRT Guru,
> I got exception below when I try to generate MS word using BIRT engine
> API, could somebody give me a light on how to fix it? I guess it's an
> issue of my report template?
> Jun 7, 2010 5:54:09 PM
> org.eclipse.birt.report.engine.api.impl.RenderTask render
> SEVERE: An error happened while running the report. Cause:
> Throwable occurred: java.lang.IllegalArgumentException: "fromUnits"must
> be one of the absolute units(CM, IN, MM, PT).
> at org.eclipse.birt.report.model.api.util.DimensionUtil.convert
> To(DimensionUtil.java:89)
> at org.eclipse.birt.report.engine.ir.DimensionType.convertTo(Di
> mensionType.java:111)
> at org.eclipse.birt.report.engine.emitter.wpml.WordUtil.convert
> To(WordUtil.java:100)
> To(WordUtil.java:72)
> at org.eclipse.birt.report.engine.emitter.wpml.AbstractEmitterI
> mpl.startTable(AbstractEmitterImpl.java:529)
> at org.eclipse.birt.report.engine.emitter.wpml.DocEmitter.start
> Table(DocEmitter.java:362)
> at org.eclipse.birt.report.engine.presentation.ContentEmitterVi
> sitor.visitTable(ContentEmitterVisitor.java:81)
> at org.eclipse.birt.report.engine.content.impl.TableContent.acc
> ept(TableContent.java:104)
> sitor.visit(ContentEmitterVisitor.java:51)
> sitor.visitChildren(ContentEmitterVisitor.java:171)
> sitor.visitContainer(ContentEmitterVisitor.java:73)
> at org.eclipse.birt.report.engine.content.impl.ContainerContent
> .accept(ContainerContent.java:42)
> at org.eclipse.birt.report.engine.emitter.wpml.DocEmitterImpl.s
> tartForeign(DocEmitterImpl.java:169)
> Foreign(DocEmitter.java:282)
> at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.st
> artContent(ContentEmitterUtil.java:77)
> at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEm
> itter.startContent(HTMLTableLayoutEmitter.java:146)
> at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter
> .startForeign(ContentEmitterAdapter.java:168)
> at org.eclipse.birt.report.engine.layout.html.buffer.DummyPageB
> uffer.startContent(DummyPageBuffer.java:125)
> at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.st
> art(HTMLLeafItemLM.java:67)
> at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la
> yout(HTMLAbstractLM.java:139)
> at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking
> LM.layoutNodes(HTMLBlockStackingLM.java:70)
> at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la
> youtChildren(HTMLStackingLM.java:26)
> yout(HTMLAbstractLM.java:140)
> at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin
> gLM.resumeLayout(HTMLInlineStackingLM.java:111)
> gLM.layoutNodes(HTMLInlineStackingLM.java:160)
> at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.l
> ayoutChildren(HTMLTableBandLM.java:67)
> at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou
> tChildren(HTMLTableLM.java:132)
> at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout
> (HTMLPageLM.java:90)
> at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE
> ngine.layout(HTMLReportLayoutEngine.java:99)
> at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange
> Render.render(RenderTask.java:577)
> at org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re
> nderTask.java:221)
> at com.ibm.rmc.publishing.doc.service.DocumentGenerator$2.run(D
> ocumentGenerator.java:162)
> at java.lang.Thread.run(Thread.java:735)
FUDForum. Page generated in 0.03529 seconds
