Home » Archived » BIRT » Data tools issue 2.3 series
Data tools issue 2.3 series [message #538228] |
Sun, 06 June 2010 20:20 |
Steven Messages: 32 Registered: July 2009 |
Member |
At some point I started having issues with certain buttons and actions
on the Birt designer in the 2.3 series on Ubuntu Linux (9.10) 64bit .
Basically when accessing anything data related, the save buttons don't
work and only occasionally are error messages produced. The 2.5 series
works, but that is not an option since my company has only 2.3 currently
deployed in our application.
Oddly, the issues don't occur on my Mac machine which I've taken to
using instead. I've downloaded complete builds for 2.3, 2.3.1, and 2.3.2
and the issue is the same for all three. (However, I have run each of
those on this same system just fine before.) Launching with the -clean
option, deleting the metatdata, and deleting my .eclipse folder haven't
done anything.
For example, I can reproduce the error in a few situations:
* Testing a connection. When I click test on a JDBC Mysql connection,
the button does nothing. No error message or log entry is made.
* If I delete the driver in the jdbc folder, and try to access the
connection, no error message is shown. the buttons just do nothing.(I
should get a an error saying the jdbc driver can't be found.)
* Create a connection using Classic Cars database, I get an error
(below) and the button does nothing:
Description Resource Path Location Type
Problem with driver "Derby Embedded JDBC Driver 10.0 Default." (Error:
Unable to locate JAR/zip in file system as specified by the driver
definition:
/home/steven/Apps/eclipse64/plugins/org.apache.derby.core_10 .3.1.4/derby.jar.)
Derby Embedded JDBC Driver 10.0 Default Driver Problems
The file is there, and the read permissions are there.
I opened up the log file in the metadata folder of my workspace and the
error messages do not match up with the timing of the errors I am seeing:
!SESSION 2010-06-06 16:04:28.921
eclipse.buildId=M20090211-1700
java.version=1.6.0_20
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2010-06-06 16:04:48.758
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.JSPJa vaHyperlinkDetector'
extension from plug-in 'org.eclipse.wst.jsdt.web.ui' to the
'org.eclipse.ui.workbench.texteditor.hyperlinkDetectors' extension point
will be ignored because it contains invalid attributes.
!MESSAGE The
'org.eclipse.wst.jsdt.web.ui.internal.hyperlink.script.event .JSPJavaHyperlinkDetector'
Any help fixing this would be greatly appreciated.
Steven
Re: Data tools issue 2.3 series [message #538426 is a reply to message #538228] |
Mon, 07 June 2010 15:03 |
Can you search the install location and workspace folders for *.log and
see if you are getting other logs?
Jason
> done anything.
> definition:
> !MESSAGE The
> !MESSAGE The
> Steven
Re: Data tools issue 2.3 series [message #538910 is a reply to message #538426] |
Wed, 09 June 2010 04:26 |
Member |
Anyone log file in particular I should be looking for?
The the workspace has my sandbox logs (where I log my errors to
birt-error.log) that aren't relevant since its not connected to the
designer. The .metatadata log and its backups are the only relevant ones
that I can think of.
The only log file that is there is .log and on start up it gives the
following errors, but no further errors when the buttons are pressed and
nothing happens.
Command-line arguments: -os linux -ws gtk -arch x86_64 -clean
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2010-06-09 00:18:53.619
!MESSAGE The
!ENTRY org.eclipse.ui.workbench.texteditor 4 0 2010-06-09 00:18:53.620
!MESSAGE The
Searching for that error turns up this thread:
http://dev.eclipse.org/newslists/news.eclipse.newcomer/msg28 893.html
That problem (two xulrunners) doesn't sound like mine, but I do know
that an earlier birt + ubuntu issue was indeed xulrunner related.
Launching from the Command line shows these errors: (there are numerous
of each...)
WARNING: Not found choice: any
Jun 9, 2010 12:18:53 AM
org.eclipse.birt.report.model.metadata.ChoicePropertyType validateXml
org.eclipse.birt.report.model.css.StyleSheetLoader semanticWarning
WARNING:
Error.StyleSheetParserException.INVALID_SHORT_HAND_CSSPROPER TY_VALUE
WARNING: Not found choice: avoid
org.eclipse.birt.report.model.metadata.StructRefPropertyType validateValue
INFO: The value of the structure property is a string
(.:25401): GLib-WARNING **: g_set_prgname() called multiple times
Steven
> Jason
>> done anything.
>> definition:
>> !MESSAGE The
>> !MESSAGE The
>> Steven
Re: Data tools issue 2.3 series [message #539089 is a reply to message #538910] |
Wed, 09 June 2010 15:23 |
Do you get these errors with a fresh install of the allinone package?
Jason
> nothing happens.
> !MESSAGE The
> !MESSAGE The
> of each...)
> WARNING:
> Steven
>> and see if you are getting other logs?
>> Jason
>>> done anything.
>>> definition:
>>> seeing:
>>> !MESSAGE The
>>> !MESSAGE The
>>> Steven
Re: Data tools issue 2.3 series [message #539856 is a reply to message #539089] |
Mon, 14 June 2010 06:39 |
Member |
Yes, the issue occurs on fresh installs. It could be because the 64-bit
linux builds on the Eclipse website have issues. I am downloading the
builds from eclipse. All birt 2.3 series 64 bit linux builds on the on
the eclipse site give me the same issue. The issue does not occur in
birt 2.5 downloaded from the eclipse site.
> Jason
>> nothing happens.
>> !MESSAGE The
>> !MESSAGE The
>> of each...)
>> WARNING:
>> validateValue
>> validateValue
>> Steven
>>> Jason
>>>> currently
>>>> 2.3.2
>>>> done anything.
>>>> definition:
>>>> seeing:
>>>> !MESSAGE The
>>>> point
>>>> !MESSAGE The
>>>> point
>>>> Steven
Current Time: Fri Apr 26 13:03:35 GMT 2024
Powered by FUDForum. Page generated in 0.03106 seconds
