Delta's with linked resources that are shared [message #535267] |
Fri, 21 May 2010 18:53 |
Cameron Ross Messages: 31 Registered: May 2010 |
Member |
I have linked resources that are included within each project of a workspace. These linked resources are editable from within any of the projects. I also have a builder associated with these projects. When a linked resource is edited within one project, a delta is generated for each of the projects, but I only need to build the file once.
Is there a way that I can remove the delta from the change set on the first build of a linked resource? Alternatively, I could cache linked resources when I build them and check the cache before building. However, its not clear how I would do this as the builder is called once per project and I would need some way to manage the cache effectively.
Any advice is greatly appreciated.
Cameron.
FUDForum. Page generated in 0.03158 seconds
