Headless build thoughts [message #510748] |
Thu, 28 January 2010 14:36 |
I am trying to have my SWTBot tests automated during my build (that uses ant). I'd like to build in them the same feature as my standard plugin tests.
I noticed that SWTBot provides a org.eclipse.swtbot.ant.optional.junit3 bundle for unit tests, which seems to be exactly the same thing that the platform's org.eclipse.ant.optional.junit bundle.
From there and from conflicts between JUnit3 and JUnit4, I've been investigating around headless test automation and here are some questions and comments about things I found confusing:
* are actually org.eclipse.swtbot.ant.optional.junit3 and org.eclipse.ant.optional.junit the same?
* If yes, why don't you distribute the platform org.eclipse.ant.optional.junit bundle instead of org.eclipse.swtbot.ant.optional.junit3 in your test framework?
* Actually, my SWTBot tests are using JUnit4 whereas my PDE tests are using JUnit3. org.eclipse.ant.optional.junit and org.eclipse.swtbot.ant.optional.junit4 are not compatible. The only solution I found is to use the new bundle org.junit 4.8 from Orbit and to remove org.eclipse.swtbot.ant.optional.junit4. However, this new bundle (org.junit) conflicts with the current release of JDT, but this is already fixed and should be available with next M-build. Did you already think about using this new bundle + org.eclipse.ant.optional.junit instead of org.eclipse.swtbot.ant.optional.* in the future?
* Do you plan to include test framework (also) in your update-site? IMHO, installing it with command-line or UI from an update-site is much easier than using a zip.
I am trying to update wiki documentation as I progress on these topics. I'll be glad to help you as much as I can!
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: Headless build thoughts [message #510777 is a reply to message #510748] |
Thu, 28 January 2010 10:32 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
On 1/28/10 6:36 AM, Mickael Istria wrote:
> tests.
Yes!
I've done this for internal consistency and so that SWTBot is self
contained. You may use either of them. I'm unsure of what would happen
if you leave both of them in your target.
I'm aware that the next M build will use a system where junit3/junit4
tests can co-exist. SWTBot will still need to be backward-compatible for
previous releases of eclipse. I'll continue to release the two fragments
for eclipse 3.4/3.5 users. Eclipse 3.6 users may not need to download this.
It certainly makes sense! Please open a bug and I'll look into it :)
That's great! Feel free to ask questions if that helps.
-- Ketan
FUDForum. Page generated in 0.02966 seconds
