Node with 2 labels [GMF] [message #491760] |
Thu, 15 October 2009 17:08 |
Alvaro Jimenez Rielo Messages: 41 Registered: July 2009 Location: Rey Juan Carlos Universit... |
Member |
Hello everyone!
I'm creating some graphical editors with EuGENia. My problem is that I need create a node with 2 labels, one of them to show the name (EAttribute) and another one must be show a fixed text (not EAttribute).
I don't know how to do, any ideas??
Thank you,
ajimenezr
[Updated on: Thu, 15 October 2009 17:09] Report message to a moderator
Re: Node with 2 labels [GMF] [message #491769 is a reply to message #491768] |
Thu, 15 October 2009 18:02 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
As explained in
http://eclipse.org/gmt/epsilon/doc/articles/eugenia-polishin g/ , EuGENia
doesn't provide a 1:1 mapping with GMF (if it did, it would be as
complex as GMF and this would beat the whole point).
Its aim is to support the most commonly used features of GMF using
annotations so that you can get a working and fairly complete editor
very quickly, and then provide you with a systematic way of polishing
your editor.
So the short answer is that you can create an editor up to a certain
level of complexity with the built-in annotations, but you then have to
use the polishing transformations if you need to go any further.
In case it helps, in addition to the example above, the following two
examples also use polishing transformations:
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.eugenia.examples.endlabels
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.eugenia.examples.flowchart
Dimitris
ajimenezr wrote:
> Hi again,
> I've already known your idea (I created another editors using GMF) but I
> want to create all through emfatic code and EuGENia plugin, but I don't
> know if it is possible:
> Could I create a complex editor using only emfatic code and EuGENia?
> ajimenezr
Re: Node with 2 labels [GMF] [message #582102 is a reply to message #491768] |
As explained in
your editor.
Dimitris
ajimenezr wrote:
> Hi again,
> ajimenezr
FUDForum. Page generated in 0.03199 seconds
