Home » Modeling » OCL » N00b OCL expression question to compare URI(How do I get the URI of an OCL object to compare with a URI String)
Re: N00b OCL expression question to compare URI [message #490624 is a reply to message #490534] |
Fri, 09 October 2009 13:00 |
--=-/r/tuTS2Rdq1zlAtxgBN
Content-Type: text/plain
Hi, Ed, Roshan,
The //Property looks like an XPath expression to get all properties in a
document, perhaps using the M2T JET project's XPath interpreter for EMF.
And $inputURI looks like an input parameter in a database query.
Together, this all looks like the IBM RSA integration of OCL queries
(the "oclQuery" XPath function) into BIRT-based model reporting.
Roshan, if this is a question of working with OCL queries in a BIRT
context, then perhaps the BIRT newsgroup, DTP newsgroup (for an EMF ODA
layer), or whatever support fora are available for IBM RSA, would be a
more appropriate place to ask. Clearly, this is an issue of integration
in some other system and not about the MDT OCL component.
Christian
On Fri, 2009-10-09 at 05:51 +0100, Ed Willink wrote:
> Hi Roshan
> I cannot understand your question at all; you seem to be using terms for
> which I know no meaning "OCL query" and elements that could come from a
> variety of languages, but not all the same one: "oclQuery", "//", "$".
> Google points out that EMF Query can be used in association with OCL,
> but the OCL Query examples of
> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.query.doc/references/examples/oclQueryExample.html
> bear little resemblance to your example.
> Regards
> Ed Willink
> Roshan Soni wrote:
> > I'm trying to create an OCL query so that it will return the comparision
> > of the URIs from an input string. So I'm trying the following:
> > oclQuery(//Property, "self.type.getURI()=$inputURI")
> > I know that getURI() does not work, how can I compare the two? Or how
> > can I get the URI?
> > Any help would be great!
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Ed, Roshan,<BR>
<BR>
The //Property looks like an XPath expression to get all properties in a document, perhaps using the M2T JET project's XPath interpreter for EMF. And $inputURI looks like an input parameter in a database query.<BR>
<BR>
Together, this all looks like the IBM RSA integration of OCL queries (the "oclQuery" XPath function) into BIRT-based model reporting.<BR>
<BR>
Roshan, if this is a question of working with OCL queries in a BIRT context, then perhaps the BIRT newsgroup, DTP newsgroup (for an EMF ODA layer), or whatever support fora are available for IBM RSA, would be a more appropriate place to ask. Clearly, this is an issue of integration in some other system and not about the MDT OCL component.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
Hi Roshan
<A HREF=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.query.doc/references/examples/oclQueryExample.html"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.query.doc/references/examples/oclQueryExample.html</A>
Ed Willink
> can I get the URI?
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-/r/tuTS2Rdq1zlAtxgBN--
Current Time: Sat May 11 00:13:49 GMT 2024
Powered by FUDForum. Page generated in 0.03650 seconds
