Home » Eclipse Projects » Riena » RAP with Riena Remote Service Support(how we can implement or consume services through Riena in RAP)
RAP with Riena Remote Service Support [message #488818] |
Wed, 30 September 2009 12:17 |
Hemanth M S Messages: 14 Registered: September 2009 |
Hai,
We have just started to design a project using Riena as RCP and web as RAP. And we created sample project in Riena with Remote Services. And successfully implemented client and server part in RienaRCP.
Server:
IUserManagement service = new UserManagement();
context.registerService(IUserManagement.class.getName(), service, null);
Publish.service(IUserManagement.class).usingPath("/IUserManagementService ")
.withProtocol("hessian").andStart(context);
System.out.println("IUserManagementService is registered");
Client Riena:
UserManagementTarget userManagementTarget = new UserManagementTarget();
Inject.service(IUserManagement.class).into(userManagementTar get).andStart(context);
RemoteServiceFactory rsf = new RemoteServiceFactory();
rsf.createAndRegisterProxy(IUserManagement.class,
"http://127.0.0.1/hessian/IUserManagementService", "hessian",
context);
userManagement = userManagementTarget.getUserManagement();
These code are written inside Activator.start() method. And Riena RCP Activator works fine. But same code in RAP Activator is not working.
Hemanth M S
[Updated on: Wed, 30 September 2009 12:53] Report message to a moderator
Re: RAP with Riena Remote Service Support [message #488852 is a reply to message #488818] |
Wed, 30 September 2009 13:48 |
Stefan Liebig Messages: 124 Registered: July 2009 |
Hi Hemanth,
When running with RAP this means that the Riena Client code is running
on the server?
What exactly happens? Exceptions, logs, ..
Tschüß,
Stefan
Hemanth M S wrote:
> Hai,
> Server:
> service, null);
> System.out.println("IUserManagementSerice is registered");
> Client Riena:
> "hessian",
> context);
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #488984 is a reply to message #488982] |
Thu, 01 October 2009 06:12 |
Hi Stefan,
Yes you are right. Now that error has gone. But now comes The "page cannot be displayed...". And log is as follows
osgi> Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null {org.osgi.service.log.LogReaderService, org.eclipse.equinox.log.ExtendedLogReaderService}={service.i d=43} ServiceEvent REGISTERED
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null {org.osgi.service.log.LogService, org.eclipse.equinox.log.ExtendedLogService}={service.id=45} ServiceEvent REGISTERED
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.equinox.log' succesful.
Thu Oct 01 11:32:52 IST 2009 INFO [DeferredLoggingForwarder] org.eclipse.riena.internal.core.Activator DeferredLogEvent on Thu Oct 01 11:32:52 IST 2009 (1254376972359 ms) in thread [Start Level Event Dispatcher]:
LogLevel(INFO), Message(No stage information set.)
Thu Oct 01 11:32:52 IST 2009 INFO [DeferredLoggingForwarder] org.eclipse.riena.internal.communication.core.ssl.SSLConfigu ration DeferredLogEvent on Thu Oct 01 11:32:52 IST 2009 (1254376972406 ms) in thread [Start Level Event Dispatcher]:
LogLevel(INFO), Message(No configuration given!.)
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Thu Oct 01 11:32:52 IST 2009 INFO [Start Level Event Dispatcher] org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @1162a9c
Thu Oct 01 11:32:52 IST 2009 INFO [Start Level Event Dispatcher] null {org.user.mgmt.common.services.IUserManagement}={service.url =http://localhost/hessian/IUserManagementService, service.protocol=hessian, service.id=46} ServiceEvent REGISTERED
Thu Oct 01 11:32:52 IST 2009 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.internal.communication.core.registry.Remot eServiceRegistry OSGi NEW service registered id: org.user.mgmt.common.services.IUserManagement
[Lorg.user.mgmt.common.beans.UserBean;@1abcd9b
Thu Oct 01 11:32:52 IST 2009 INFO [Start Level Event Dispatcher] null {org.eclipse.core.runtime.content.IContentTypeManager}={serv ice.id=47} ServiceEvent REGISTERED
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent STARTED
Thu Oct 01 11:32:52 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent STARTLEVEL CHANGED
ss
Framework is launched.
id State Bundle
0 ACTIVE org.eclipse.osgi_3.5.100.v20090803
Fragments=91, 92, 99
3 ACTIVE org.eclipse.equinox.app_1.2.0.v20090520-1800
5 ACTIVE org.eclipse.equinox.registry_3.4.100.v20090520-1800
Fragments=83
7 ACTIVE org.eclipse.core.expressions_3.4.100.v20090429-1800
14 ACTIVE org.eclipse.core.databinding_1.2.0.I20090630-0800
15 ACTIVE org.eclipse.rap.rwt_1.3.0.20090817-1725
Fragments=40
23 ACTIVE org.eclipse.core.jobs_3.4.100.v20090429-1800
28 ACTIVE org.eclipse.equinox.common_3.5.100.v20090727
29 ACTIVE com.ibm.icu.base_4.0.1.v20090415
32 ACTIVE org.eclipse.equinox.http.registry_1.0.200.v20090520-1800
34 ACTIVE org.eclipse.core.commands_3.5.0.I20090525-2000
37 ACTIVE org.eclipse.core.databinding.property_1.2.0.I20090630-0800
38 ACTIVE org.eclipse.rap.ui_1.3.0.20090817-1725
39 ACTIVE org.eclipse.rap.jface_1.3.0.20090817-1725
40 RESOLVED org.eclipse.rap.rwt.q07_1.3.0.20090817-1725
Master=15
44 ACTIVE org.eclipse.rap.ui.workbench_1.3.0.20090817-1725
48 ACTIVE org.eclipse.core.databinding.observable_1.2.0.I20090630-0800
54 ACTIVE org.eclipse.core.runtime_3.5.100.v20090629
55 ACTIVE org.user.mgmt.rap_1.0.0.qualifier
60 ACTIVE org.user.mgmt.common_1.0.0.qualifier
80 ACTIVE org.eclipse.help_3.4.0.v20090526
81 ACTIVE org.eclipse.swt_3.5.0.v3550b
Fragments=93
82 ACTIVE org.eclipse.ui.workbench_3.5.0.I20090603-2000
83 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.2.200.v200 90429-1800
Master=5
84 ACTIVE javax.servlet_2.5.0.v200806031605
85 ACTIVE org.eclipse.ui_3.5.0.I20090604-2000
86 ACTIVE org.eclipse.core.variables_3.2.200.v20090521
87 ACTIVE org.eclipse.jface.databinding_1.3.0.I20090525-2000
88 ACTIVE org.eclipse.equinox.preferences_3.2.300.v20090520-1800
89 ACTIVE org.eclipse.core.contenttype_3.4.0.v20090429-1800
90 ACTIVE org.eclipse.jface_3.5.0.I20090525-2000
91 RESOLVED org.eclipse.persistence.jpa.equinox.weaving_1.1.2.v20090612- r4475
Master=0
92 RESOLVED org.eclipse.equinox.transforms.hook_1.0.100.v20090520-1800
Master=0
93 RESOLVED org.eclipse.swt.win32.win32.x86_3.5.0.v3550b
Master=81
94 ACTIVE org.eclipse.riena.communication.core_1.2.0.200908210731NGT
95 ACTIVE com.caucho.hessian_3.1.3
96 ACTIVE org.eclipse.riena.core_1.2.0.200908210731NGT
97 ACTIVE org.eclipse.osgi.services_3.2.0.v20090520-1800
98 ACTIVE org.eclipse.equinox.log_1.2.0.v20090520-1800
99 RESOLVED javax.transaction_1.1.1.v200909161740
Master=0
106 ACTIVE org.eclipse.riena.communication.factory.hessian_1.2.0.200908 210731NGT
And I am very thankful for your kind response...
Hemanth M S
[Updated on: Thu, 01 October 2009 06:14] Report message to a moderator
Re: RAP with Riena Remote Service Support [message #488993 is a reply to message #488984] |
Thu, 01 October 2009 07:05 |
Hi Hemanth,
Nice! The log looks fine so far. ;-)
But what is this "page cannot be displayed"? Is it an exception, log
message or a dialog?
Tschüß,
Stefan
Hemanth M S wrote:
> Hi Stefan,
> :) Yes you are right. Now that error has gone. But now comes The "page
> REGISTERED
> Dispatcher]:
> BundleEvent STARTED
> BundleEvent STARTED
> protocol [hessian]
> mailto: org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @1162a9c
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #489000 is a reply to message #488993] |
Thu, 01 October 2009 08:05 |
Hi Stefan,
Ok I got it. It is because of server is not started. I forgot to select server bundle. After selection
org.eclipse.equinox.http.jetty
org.mortbay.jetty.server
org.mortbay.jetty.util
Now I got the page with following log.
osgi> Thu Oct 01 13:29:42 IST 2009 INFO [Framework Event Dispatcher] null {org.osgi.service.log.LogService, org.eclipse.equinox.log.ExtendedLogService}={service.id=48} ServiceEvent REGISTERED
Thu Oct 01 13:29:42 IST 2009 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.equinox.log' succesful.
Thu Oct 01 13:29:42 IST 2009 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Thu Oct 01 13:29:42 IST 2009 INFO [DeferredLoggingForwarder] org.eclipse.riena.internal.core.Activator DeferredLogEvent on Thu Oct 01 13:29:42 IST 2009 (1254383982453 ms) in thread [Start Level Event Dispatcher]:
Thu Oct 01 13:29:42 IST 2009 INFO [DeferredLoggingForwarder] org.eclipse.riena.internal.communication.core.ssl.SSLConfigu ration DeferredLogEvent on Thu Oct 01 13:29:42 IST 2009 (1254383982500 ms) in thread [Start Level Event Dispatcher]:
Thu Oct 01 13:29:42 IST 2009 INFO [Start Level Event Dispatcher] org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @4ac216
Thu Oct 01 13:29:42 IST 2009 INFO [Start Level Event Dispatcher] null {org.user.mgmt.common.services.IUserManagement}={service.url =http://localhost/hessian/IUserManagementService, service.protocol=hessian, service.id=49} ServiceEvent REGISTERED
Thu Oct 01 13:29:42 IST 2009 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.internal.communication.core.registry.Remot eServiceRegistry OSGi NEW service registered id: org.user.mgmt.common.services.IUserManagement
[Lorg.user.mgmt.common.beans.UserBean;@1758500
Thu Oct 01 13:29:42 IST 2009 INFO [Start Level Event Dispatcher] null {org.eclipse.core.runtime.content.IContentTypeManager}={serv ice.id=50} ServiceEvent REGISTERED
Thu Oct 01 13:29:42 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent INFO
Thu Oct 01 13:29:43 IST 2009 INFO [Start Level Event Dispatcher] null {org.osgi.service.http.HttpService}={service.description=Equ inox Jetty-based Http Service, service.vendor=Eclipse.org, http.port=2401, service.id=51} ServiceEvent REGISTERED
Thu Oct 01 13:29:43 IST 2009 INFO [Start Level Event Dispatcher] null {org.osgi.service.cm.ManagedServiceFactory}={service.pid=org .eclipse.equinox.http.jetty.config, service.id=52} ServiceEvent REGISTERED
Thu Oct 01 13:29:43 IST 2009 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Thu Oct 01 13:29:43 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent STARTED
Thu Oct 01 13:29:43 IST 2009 INFO [Framework Event Dispatcher] null FrameworkEvent STARTLEVEL CHANGED
!SESSION 2009-10-01 13:29:39.937 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_16
Command-line arguments: -dev file:F:/latest downloads/eclipse/workspace/.metadata/.plugins/org.eclipse.p de.core/org.user.mgmt.rap/dev.properties -os win32 -ws win32 -arch x86 -console -consolelog
!ENTRY org.eclipse.osgi 2 0 2009-10-01 13:29:43.656
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2009-10-01 13:29:43.656
!MESSAGE Bundle org.eclipse.core.runtime_3.5.100.v20090629 [168] was not resolved.
!SUBENTRY 2 org.eclipse.core.runtime 2 0 2009-10-01 13:29:43.656
!MESSAGE Missing optionally required bundle org.eclipse.core.runtime.compatibility.auth_[3.2.0,4.0.0).
!MESSAGE Missing imported package org.eclipse.core.internal.runtime.auth_0.0.0.
!ENTRY org.eclipse.rap.ui 4 0 2009-10-01 13:29:51.093
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.WorkbenchSourceProvider' should extend AbstractSourceProvider
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.services.WorkbenchSourceProvider' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.services.ActionSetSourceProvider' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.ActionSetSourceProvider' should extend AbstractSourceProvider
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.menus.FocusControlSourceProvider' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.services.MenuSourceProvider' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
!MESSAGE Source Provider 'org.eclipse.ui.internal.menus.FocusControlSourceProvider' should extend AbstractSourceProvider
!ENTRY org.eclipse.rap.ui 4 0 2009-10-01 13:29:51.109
!MESSAGE Source Provider 'org.eclipse.ui.internal.services.MenuSourceProvider' should extend AbstractSourceProvider
!MESSAGE Source Provider 'org.eclipse.ui.internal.contexts.ActiveContextSourceProvide r' should extend AbstractSourceProvider
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Source Provider 'org.eclipse.ui.internal.contexts.ActiveContextSourceProvide r' should extend AbstractSourceProvider, Code: 0, Plugin: org.eclipse.rap.ui
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.140
!MESSAGE A handler conflict occurred. This may disable some commands.
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.140
!MESSAGE Conflict for 'org.eclipse.ui.newWizard':
HandlerActivation(commandId=org.eclipse.ui.newWizard,
handler=org.eclipse.ui.internal.handlers.WizardHandler$New,
expression=,sourcePriority=0)
handler=org.eclipse.ui.internal.handlers.WizardHandler$New@177ab84,
Thu Oct 01 13:29:51 IST 2009 WARNING [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: A handler conflict occurred. This may disable some commands., Code: 0, Plugin: org.eclipse.ui.workbench
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.156
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.156
!MESSAGE Conflict for 'org.eclipse.ui.file.import':
HandlerActivation(commandId=org.eclipse.ui.file.import,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Impor t,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Import@44b7f7,
expression=,sourcePriority=0)Thu Oct 01 13:29:51 IST 2009 WARNING [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: A handler conflict occurred. This may disable some commands., Code: 0, Plugin: org.eclipse.ui.workbench
!MESSAGE Conflict for 'org.eclipse.ui.file.export':
HandlerActivation(commandId=org.eclipse.ui.file.export,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Export@ebaf12,
handler=org.eclipse.ui.internal.handlers.WizardHandler$Expor t,
!MESSAGE Conflict for 'org.eclipse.ui.file.properties':
HandlerActivation(commandId=org.eclipse.ui.file.properties,
handler=org.eclipse.ui.internal.handlers.PropertyDialogHandl er,
handler=org.eclipse.ui.internal.handlers.PropertyDialogHandler@14b03ea,
!MESSAGE Conflict for 'org.eclipse.ui.file.exit':
HandlerActivation(commandId=org.eclipse.ui.file.exit,
handler=org.eclipse.ui.internal.handlers.QuitHandler@77a748,
handler=org.eclipse.ui.internal.handlers.QuitHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.234
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.234
!MESSAGE Conflict for 'org.eclipse.ui.window.switchToEditor':
HandlerActivation(commandId=org.eclipse.ui.window.switchToEd itor,
handler=org.eclipse.ui.internal.WorkbenchEditorsHandler,
handler=org.eclipse.ui.internal.WorkbenchEditorsHandler@f84b0a,
!ENTRY org.eclipse.ui.workbench 2 0 Thu Oct 01 13:29:51 IST 2009 WARNING [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: A handler conflict occurred. This may disable some commands., Code: 0, Plugin: org.eclipse.ui.workbench
!MESSAGE Conflict for 'org.eclipse.ui.window.minimizePart':
HandlerActivation(commandId=org.eclipse.ui.window.minimizePa rt,
handler=org.eclipse.ui.internal.handlers.MinimizePartHandler ,
handler=org.eclipse.ui.internal.handlers.MinimizePartHandler@15ee9e3,
!MESSAGE Conflict for 'org.eclipse.ui.file.closePart':
HandlerActivation(commandId=org.eclipse.ui.file.closePart,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler,
handler=org.eclipse.ui.internal.handlers.ClosePartHandler@1f94a1f,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.250
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.250
!MESSAGE Conflict for 'org.eclipse.ui.window.preferences':
HandlerActivation(commandId=org.eclipse.ui.window.preference s,
handler=org.eclipse.ui.internal.handlers.ShowPreferencePageH andler,
handler=org.eclipse.ui.internal.handlers.ShowPreferencePageHandler@1d318f,
!MESSAGE Conflict for 'org.eclipse.ui.views.showView':
HandlerActivation(commandId=org.eclipse.ui.views.showView,
handler=org.eclipse.ui.handlers.ShowViewHandler@1b0c08,
handler=org.eclipse.ui.handlers.ShowViewHandler,
!MESSAGE Conflict for 'org.eclipse.ui.perspectives.showPerspective':
HandlerActivation(commandId=org.eclipse.ui.perspectives.show Perspective,
handler=org.eclipse.ui.handlers.ShowPerspectiveHandler,
handler=org.eclipse.ui.handlers.ShowPerspectiveHandler@a9509d,
!MESSAGE Conflict for 'org.eclipse.ui.navigate.showIn':
HandlerActivation(commandId=org.eclipse.ui.navigate.showIn,
handler=org.eclipse.ui.internal.ShowInHandler@16528a2,
handler=org.eclipse.ui.internal.ShowInHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.281
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.281
!MESSAGE Conflict for 'org.eclipse.ui.window.activateEditor':
HandlerActivation(commandId=org.eclipse.ui.window.activateEd itor,
handler=org.eclipse.ui.internal.ActivateEditorHandler,
!MESSAGE Conflict for 'org.eclipse.ui.window.showSystemMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showSystem Menu,
handler=org.eclipse.ui.internal.ShowPartPaneMenuHandler,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.296
!MESSAGE Conflict for 'org.eclipse.ui.window.showViewMenu':
HandlerActivation(commandId=org.eclipse.ui.window.showViewMe nu,
handler=org.eclipse.ui.internal.ShowViewMenuHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.296
!MESSAGE Conflict for 'org.eclipse.ui.file.close':
HandlerActivation(commandId=org.eclipse.ui.file.close,
handler=org.eclipse.ui.internal.CloseEditorHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.312
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.312
!MESSAGE Conflict for 'org.eclipse.ui.file.closeAll':
HandlerActivation(commandId=org.eclipse.ui.file.closeAll,
handler=org.eclipse.ui.internal.CloseAllHandler,
!MESSAGE Conflict for 'org.eclipse.ui.file.closeOthers':
HandlerActivation(commandId=org.eclipse.ui.file.closeOthers,
handler=org.eclipse.ui.internal.CloseOthersHandler,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0Thu Oct 01 13:29:51 IST 2009 WARNING [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: A handler conflict occurred. This may disable some commands., Code: 0, Plugin: org.eclipse.ui.workbench
!MESSAGE Conflict for 'org.eclipse.ui.ToggleCoolbarAction':
HandlerActivation(commandId=org.eclipse.ui.ToggleCoolbarActi on,
handler=org.eclipse.ui.internal.handlers.ToggleCoolbarHandle r,
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.328
!MESSAGE Conflict for 'org.eclipse.ui.window.nextEditor':
HandlerActivation(commandId=org.eclipse.ui.window.nextEditor ,
handler=org.eclipse.ui.internal.CycleEditorHandler:true,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.328
!MESSAGE Conflict for 'org.eclipse.ui.window.previousEditor':
HandlerActivation(commandId=org.eclipse.ui.window.previousEd itor,
handler=org.eclipse.ui.internal.CycleEditorHandler:false,
!MESSAGE Conflict for 'org.eclipse.ui.window.nextView':
HandlerActivation(commandId=org.eclipse.ui.window.nextView,
handler=org.eclipse.ui.internal.CycleViewHandler:true,
!MESSAGE Conflict for 'org.eclipse.ui.window.previousView':
HandlerActivation(commandId=org.eclipse.ui.window.previousVi ew,
handler=org.eclipse.ui.internal.CycleViewHandler:false,
!MESSAGE Conflict for 'org.eclipse.ui.window.nextPerspective':
HandlerActivation(commandId=org.eclipse.ui.window.nextPerspe ctive,
handler=org.eclipse.ui.internal.CyclePerspectiveHandler:true ,
!MESSAGE Conflict for 'org.eclipse.ui.window.previousPerspective':
HandlerActivation(commandId=org.eclipse.ui.window.previousPe rspective,
handler=org.eclipse.ui.internal.CyclePerspectiveHandler:fals e,
!MESSAGE Conflict for 'org.eclipse.ui.window.closeAllPerspectives':
HandlerActivation(commandId=org.eclipse.ui.window.closeAllPe rspectives,
handler=org.eclipse.ui.internal.handlers.CloseAllPerspective sHandler,
!ENTRY org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.343
!SUBENTRY 1 org.eclipse.ui.workbench 2 0 2009-10-01 13:29:51.343
!MESSAGE Conflict for 'org.eclipse.ui.window.customizePerspective':
HandlerActivation(commandId=org.eclipse.ui.window.customizeP erspective,
handler=org.eclipse.ui.internal.handlers.EditActionSetsHandl er,
!MESSAGE Conflict for 'org.eclipse.ui.window.closePerspective':
HandlerActivation(commandId=org.eclipse.ui.window.closePersp ective,
handler=org.eclipse.ui.internal.handlers.ClosePerspectiveHan dler,
!MESSAGE Conflict for 'org.eclipse.ui.window.openEditorDropDown':
HandlerActivation(commandId=org.eclipse.ui.window.openEditor DropDown,
handler=org.eclipse.ui.internal.WorkbookEditorsHandler,
!MESSAGE Conflict for 'org.eclipse.ui.window.newEditor':
HandlerActivation(commandId=org.eclipse.ui.window.newEditor,
handler=org.eclipse.ui.internal.handlers.NewEditorHandler,
!MESSAGE Conflict for 'org.eclipse.ui.window.maximizePart':
HandlerActivation(commandId=org.eclipse.ui.window.maximizePa rt,
handler=org.eclipse.ui.internal.handlers.MaximizePartHandler ,
!ENTRY org.eclipse.rap.ui 4 4 2009-10-01 13:29:51.390
!MESSAGE Could not create color factory.
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Could not create color factory., Code: 4, Plugin: org.eclipse.rap.ui
!ENTRY org.eclipse.equinox.registry 4 1 2009-10-01 13:29:51.406
!MESSAGE Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.themes.LightColorFactory".
!STACK 0
java.lang.ExceptionInInitializerError
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.checkColo rFactory(ThemeRegistryReader.java:406)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.getColorV alue(ThemeRegistryReader.java:183)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readColor (ThemeRegistryReader.java:139)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readEleme nt(ThemeRegistryReader.java:239)
at org.eclipse.ui.internal.registry.RegistryReader.readElements (RegistryReader.java:144)
at org.eclipse.ui.internal.registry.RegistryReader.readExtensio n(RegistryReader.java:155)
at org.eclipse.ui.internal.registry.RegistryReader.readRegistry (RegistryReader.java:176)
at org.eclipse.ui.internal.themes.ThemeRegistryReader.readTheme s(ThemeRegistryReader.java:458)
at org.eclipse.ui.internal.WorkbenchPlugin$ThemeRegistryStore.<init >(WorkbenchPlugin.java:149)
at org.eclipse.rwt.SessionSingletonBase.getInstanceInternal(Ses sionSingletonBase.java:154)
at org.eclipse.rwt.SessionSingletonBase.getInstance(SessionSing letonBase.java:91)
at org.eclipse.ui.internal.WorkbenchPlugin$ThemeRegistryStore.g etInstance(WorkbenchPlugin.java:142)
at org.eclipse.ui.internal.WorkbenchPlugin.getThemeRegistry(Wor kbenchPlugin.java:876)
at org.eclipse.ui.internal.Workbench$29.runWithException(Workbe nch.java:1428)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
at org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:115)
at org.eclipse.swt.widgets.Display$2.run(Display.java:696)
at org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 460)
at org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:694)
at org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.initializeFonts(Workbench. java:1424)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1304)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2320)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 09)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:427)
at org.eclipse.ui.internal.RealmAdapterHook.runWithDefault(Real mAdapterHook.java:48)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:430)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at org.user.mgmt.rap.Application.createUI(Application.java:17)
at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:231)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:119)
at org.eclipse.ui.themes.ColorUtil.getSystemColor(ColorUtil.jav a:152)
at org.eclipse.ui.themes.ColorUtil.process(ColorUtil.java:47)
at org.eclipse.ui.themes.ColorUtil.getColorValue(ColorUtil.java :172)
at org.eclipse.ui.internal.themes.LightColorFactory.<clinit>(LightColorFactory.java:33)
... 48 more
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Plug-in "org.eclipse.ui" was unable to instantiate class "org.eclipse.ui.internal.themes.LightColorFactory"., Code: 1, Plugin: org.eclipse.equinox.registry
!ENTRY org.eclipse.rap.ui 4 4 2009-10-01 13:29:51.406
!MESSAGE Plugin org.eclipse.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.ACTIVE_TAB_TEXT_COLOR: Only one of value or defaultMapping may be set.
... 48 more
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Plugin org.eclipse.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.ACTIVE_TAB_TEXT_COLOR: Only one of value or defaultMapping may be set., Code: 4, Plugin: org.eclipse.rap.ui
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.ui.internal.themes.LightColorFactory
Thu Oct 01 13:29:51 IST 2009 ERROR [UIThread [12awl37xa5vk6]] Bundle org.eclipse.core.runtime Message: Plugin org.eclipse.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.ACTIVE_TAB_BG_END: Only one of value or defaultMapping may be set., Code: 4, Plugin: org.eclipse.rap.ui
!ENTRY org.eclipse.rap.ui 4 4 2009-10-01 13:29:51.421
!MESSAGE Plugin org.eclipse.ui, extension org.eclipse.ui.themes, id org.eclipse.ui.workbench.ACTIVE_TAB_BG_END: Only one of value or defaultMapping may be set.
!ENTRY org.eclipse.equinox.registry 4 1 2009-10-01 13:29:51.421
!STACK 0
at
[Updated on: Thu, 01 October 2009 08:09] Report message to a moderator
Re: RAP with Riena Remote Service Support [message #489019 is a reply to message #489000] |
Thu, 01 October 2009 08:55 |
Benjamin Muskalla Messages: 338 Registered: July 2009 |
it looks like you have both org.eclipse.rap.ui.workbench and
org.eclipse.ui.workbench in your launc configuration. Please be sure to
either have the RCP plugins *or* the RAP plugins in your target / launch
config to prevent these errors. Due to the architecture of Equinox it's
not possible to have them run in the same configuration together.
Ben
Hemanth M S wrote:
> Hi Stefan,
> REGISTERED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> Dispatcher]:
> protocol [hessian]
> mailto: org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @4ac216
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> FrameworkEvent INFO
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> resolved.
> handler=org.eclipse.ui.internal.handlers.WizardHandler$mailt o:New@177ab84,
> handler=org.eclipse.ui.internal.handlers.WizardHandler$mailt o:Import@44b7f7,
> handler=org.eclipse.ui.internal.handlers.WizardHandler$mailt o:Export@ebaf12,
> handler=mailto:org.eclipse.ui.internal.handlers.PropertyDialogHandler@14b03ea,
> handler=mailto:org.eclipse.ui.internal.handlers.QuitHandler@77a748,
> handler=mailto:org.eclipse.ui.internal.WorkbenchEditorsHandler@f84b0a,
> handler=mailto:org.eclipse.ui.internal.handlers.MinimizePartHandler@15ee9e3,
> handler=mailto:org.eclipse.ui.internal.handlers.ClosePartHandler@1f94a1f,
> handler=mailto:org.eclipse.ui.internal.handlers.ShowPreferencePageHandler@1d318f,
> handler=mailto:org.eclipse.ui.handlers.ShowViewHandler@1b0c08,
> handler=mailto:org.eclipse.ui.handlers.ShowPerspectiveHandler@a9509d,
> handler=mailto:org.eclipse.ui.internal.ShowInHandler@16528a2,
> !STACK 0
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> at
> ... 48 more
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> at
> ... 48 more
> !STACK 0
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
Re: RAP with Riena Remote Service Support [message #489106 is a reply to message #489083] |
Thu, 01 October 2009 14:14 |
Hi Ben,
RAP Activator worked fine and even started to load page, then got exception
This is the launch config
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.rap.ui.launch.RAPLauncher">
<booleanAttribute key="append.args" value="true"/>
<booleanAttribute key="automaticAdd" value="true"/>
<booleanAttribute key="automaticValidate" value="false"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="false"/>
<stringAttribute key="configLocation" value=" ${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/org .user.mgmt.rap "/>
<booleanAttribute key="default_auto_start" value="true"/>
<intAttribute key="default_start_level" value="4"/>
<booleanAttribute key="includeOptional" value="true"/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS" value="-os ${target.os} -ws ${target.ws} -arch ${target.arch} -nl ${target.nl} -console"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER" value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS" value="-Declipse.ignoreApp=true -Dosgi.noShutdown=true"/>
<stringAttribute key="org.eclipse.rap.launch.browserMode" value="INTERNAL"/>
<stringAttribute key="org.eclipse.rap.launch.entryPoint" value="userMgmt"/>
<stringAttribute key="org.eclipse.rap.launch.libraryVariant" value="STANDARD"/>
<stringAttribute key="org.eclipse.rap.launch.logLevel" value="OFF"/>
<booleanAttribute key="org.eclipse.rap.launch.openBrowser" value="true"/>
<intAttribute key="org.eclipse.rap.launch.port" value="10080"/>
<stringAttribute key="org.eclipse.rap.launch.servletName" value="rap"/>
<booleanAttribute key="org.eclipse.rap.launch.terminatePrevious" value="true"/>
<booleanAttribute key="org.eclipse.rap.launch.useManualPort" value="false"/>
<stringAttribute key="pde.version" value="3.3"/>
<booleanAttribute key="show_selected_only" value="false"/>
<stringAttribute key="target_bundles" value="org.eclipse.swt@default:default,org.eclipse.core.commands*
3.5.0.I20090525-2000@default:default,org.eclipse.osgi*3.5.0.v20090520@-
1:true,org.eclipse.core.databinding.observable*
1.2.0.I20090604-2000@default:default,org.eclipse.equinox.registry*
3.4.100.v20090520-1800@default:default,
org.eclipse.jface.databinding@default:default,org.eclipse.equinox.http.servlet*
1.0.200.v20090520-1800@default:default,org.eclipse.osgi*3.5.100.v20090803@-
1:true,org.eclipse.core.runtime*3.5.0.v20090525@default:true,
org.eclipse.equinox.transforms.hook@default:false,org.eclipse.swt.win32.win32.x86@default:false,
org.eclipse.help@default:default,org.eclipse.equinox.preferences*
3.2.300.v20090520-1800@default:default,org.eclipse.core.jobs*
3.4.100.v20090429-1800@default:default,
org.eclipse.rap.ui@default:default,org.eclipse.core.databinding.observable*
1.2.0.I20090630-0800@default:default,
org.eclipse.equinox.log@default:default,org.eclipse.core.jobs*3.4.100.v20090429-1800@default:default,
org.eclipse.rap.rwt@default:default,org.apache.log4j@default:default,com.ibm.icu.base@default:default,org.eclipse.jface@default:default,org.eclipse.core.expressions*
3.4.100.v20090429-1800@default:default,org.eclipse.equinox.http.registry*
1.0.200.v20090520-1800@default:default,org.eclipse.core.databinding*
1.2.0.I20090630-0800@default:default,org.eclipse.core.commands*
org.eclipse.rap.jface.databinding@default:default,org.eclipse.core.expressions*
3.4.100.v20090429-1800@default:default,org.eclipse.rap.jface@default:default,
com.ibm.icu@default:default,org.eclipse.core.contenttype*3.4.0.v20090429-1800@default:default,
org.user.mgmt.common@default:default,org.eclipse.equinox.http.jetty*
2.0.0.v20090520-1800@default:default,org.eclipse.osgi.services*
3.2.0.v20090520-1800@default:default,org.eclipse.equinox.http.jetty*
org.eclipse.riena.communication.factory.hessian@default:default,org.eclipse.core.databinding*
1.2.0.I20090604-2000@default:default,org.mortbay.jetty.util*6.1.15.v200905182336@default:default
,org.user.mgmt.ws@default:default,org.eclipse.equinox.app*
1.2.0.v20090520-1800@default:default,org.eclipse.core.databinding.property*
1.2.0.I20090630-0800@default:default,org.eclipse.equinox.http.registry*
1.0.200.v20090520-1800@default:default,org.eclipse.rap.ui.workbench@default:default,
com.caucho.hessian@default:default,org.eclipse.equinox.common*3.5.100.v20090727@2:true,
org.eclipse.rap.rwt.q07@default:false,org.eclipse.core.contenttype*
3.4.0.v20090429-1800@default:default,javax.servlet*
2.5.0.v200806031605@default:default,org.eclipse.equinox.registry*
3.4.100.v20090520-1800@default:default,org.mortbay.jetty.server*
6.1.15.v200905151201@default:default,javax.servlet*2.5.0.v200806031605@default:default,
org.eclipse.equinox.security@default:default,
org.eclipse.core.runtime.compatibility.auth@default:default,org.eclipse.equinox.common*
3.5.0.v20090520-1800@2:true,org.mortbay.jetty.server*6.1.15.v200905151201@default:default,
org.eclipse.riena.core@default:default,org.eclipse.core.databinding.property*
1.2.0.I20090526-2000@default:default,org.eclipse.core.net@default:default,
javax.servlet.jsp@default:default,org.eclipse.equinox.app*
1.2.0.v20090520-1800@default:default,org.eclipse.osgi.services*
org.eclipse.equinox.security.win32.x86@default:false,org.eclipse.equinox.preferences*
3.2.300.v20090520-1800@default:default,org.eclipse.equinox.http.servlet*
1.0.200.v20090520-1800@default:default,org.mortbay.jetty.util*
6.1.15.v200905182336@default:default,org.eclipse.core.variables@default:default,
org.eclipse.riena.communication.core@default:default"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useDefaultConfigArea" value="true"/>
<stringAttribute key="workspace_bundles" value="org.user.mgmt.rap@default:default"/>
</launchConfiguration>
What should I do other than this?
Hemanth M S
[Updated on: Thu, 01 October 2009 15:21] Report message to a moderator
Re: RAP with Riena Remote Service Support [message #583740 is a reply to message #583729] |
Hi Hemanth,
Tschüß,
Stefan
Hemanth M S wrote:
> Hi Stefan,
> REGISTERED
> Dispatcher]:
> BundleEvent STARTED
> BundleEvent STARTED
> protocol [hessian]
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> Regards
> Hemanth M S
Re: RAP with Riena Remote Service Support [message #583757 is a reply to message #488993] |
Hi Stefan,
Thu Oct 01 13:29:42 IST 2009 INFO [Start Level Event Dispatcher] org.eclipse.riena.communication.core.factory.RemoteServiceFa ctory found protocol [hessian] mailto: org.eclipse.riena.internal.communication.factory.hessian.Rem oteServiceFactoryHessian @4ac216
!STACK 0
... 48 more
... 48 more
!STACK 0
!STACK 0
Re: RAP with Riena Remote Service Support [message #583774 is a reply to message #583757] |
Ben
Hemanth M S wrote:
> Hi Stefan,
> REGISTERED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> Dispatcher]:
> protocol [hessian]
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> FrameworkEvent INFO
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> BundleEvent STARTED
> resolved.
> !STACK 0
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> at
> ... 48 more
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> at
> ... 48 more
> !STACK 0
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
> bench.java:430)
> ava:157)
> LifeCycle.java:231)
> Method)
> Source)
> known Source)
> Method)
> Source)
> known Source)
> letonBase.java:91)
> nch.java:1428)
> java:1424)
Re: RAP with Riena Remote Service Support [message #583834 is a reply to message #489083] |
Hi Ben,
This is the launch config which used to run
<stringAttribute key="target_bundles" value="mailto:org.eclipse.swt@default:default,org.eclipse.core.commands*mailto:3.5.0.I20090525-2000@default:default,org.eclipse.osgi*mailto:3.5.0.v20090520@-1:true,org.eclipse.core.databinding.observable*mailto:1.2.0.I20090604-2000@default:default,org.eclipse.equinox.registry*mailto:3.4.100.v20090520-1800@default:default,mailto:org.eclipse.jface.databinding@default:default,org.eclipse.equinox.http.servlet*mailto:1.0.200.v20090520-1800@default:default,org.eclipse.osgi*mailto:3.5.100.v20090803@-1:true,org.eclipse.core.runtime*mailto:3.5.0.v20090525@default:true,mailto:org.eclipse.equinox.transforms.hook@default:false,mailto:org.eclipse.swt.win32.win32.x86@default:false,mailto:org.eclipse.help@default:default,org.eclipse.equinox.preferences*mailto:3.2.300.v20090520-1800@default:default,org.eclipse.core.jobs*mailto:3.4.100.v20090429-1800@default:default,mailto:org.eclipse.rap.ui@default:default,org.eclipse.core.databinding.observable*mailto:1.2.0.I20090630-0800@default:default,mailto:org.eclipse.equinox.log@default:default,org.eclipse.core.jobs*mailto:3.4.100.v20090429-1800@default:default,mailto:org.eclipse.rap.rwt@default:default,mailto:org.apache.log4j@default:default,mailto:com.ibm.icu.base@default:default,mailto:org.eclipse.jface@default:default,org.eclipse.core.expressions*mailto:3.4.100.v20090429-1800@default:default,org.eclipse.equinox.http.registry*mailto:1.0.200.v20090520-1800@default:default,org.eclipse.core.databinding*mailto:1.2.0.I20090630-0800@default:default,org.eclipse.core.commands*mailto:3.5.0.I20090525-2000@default:default,mailto:org.eclipse.rap.jface.databinding@default:default,org.eclipse.core.expressions*mailto:3.4.100.v20090429-1800@default:default,mailto:org.eclipse.rap.jface@default:default,mailto:com.ibm.icu@default:default,org.eclipse.core.contenttype*mailto:3.4.0.v20090429-1800@default:default,mailto:org.user.mgmt.common@default:default,org.eclipse.equinox.http.jetty*mailto:2.0.0.v20090520-1800@default:default,org.eclipse.osgi.services*mailto:3.2.0.v20090520-1800@default:default,org.eclipse.equinox.http.jetty*mailto:2.0.0.v20090520-1800@default:default,mailto:org.eclipse.riena.communication.factory.hessian@default:default,org.eclipse.core.databinding*mailto:1.2.0.I20090604-2000@default:default,org.mortbay.jetty.util*mailto:6.1.15.v200905182336@default:default,mailto:org.user.mgmt.ws@default:default,org.eclipse.equinox.app*mailto:1.2.0.v20090520-1800@default:default,org.eclipse.core.databinding.property*mailto:1.2.0.I20090630-0800@default:default,org.eclipse.equinox.http.registry*mailto:1.0.200.v20090520-1800@default:default,mailto:org.eclipse.rap.ui.workbench@default:default,mailto:com.caucho.hessian@default:default,org.eclipse.equinox.common*mailto:3.5.100.v20090727@2:true,mailto:org.eclipse.rap.rwt.q07@default:false,org.eclipse.core.contenttype*mailto:3.4.0.v20090429-1800@default:default,javax.servlet*mailto:2.5.0.v200806031605@default:default,org.eclipse.equinox.registry*mailto:3.4.100.v20090520-1800@default:default,org.mortbay.jetty.server*mailto:6.1.15.v200905151201@default:default,javax.servlet*mailto:2.5.0.v200806031605@default:default,mailto:org.eclipse.equinox.security@default:default,mailto:org.eclipse.core.runtime.compatibility.auth@default:default,org.eclipse.equinox.common*mailto:3.5.0.v20090520-1800@2:true,org.mortbay.jetty.server*mailto:6.1.15.v200905151201@default:default,mailto:org.eclipse.riena.core@default:default,org.eclipse.core.databinding.property*mailto:1.2.0.I20090526-2000@default:default,mailto:org.eclipse.core.net@default:default,mailto:javax.servlet.jsp@default:default,org.eclipse.equinox.app*mailto:1.2.0.v20090520-1800@default:default,org.eclipse.osgi.services*mailto:3.2.0.v20090520-1800@default:default,mailto:org.eclipse.equinox.security.win32.x86@default:false,org.eclipse.equinox.preferences*mailto:3.2.300.v20090520-1800@default:default,org.eclipse.equinox.http.servlet*mailto:1.0.200.v20090520-1800@default:default,org.mortbay.jetty.util*mailto:6.1.15.v200905182336@default:default,mailto:org.eclipse.core.variables@default:default,mailto:org.eclipse.riena.communication.core@default:default"/>
<stringAttribute key="workspace_bundles" value="mailto:org.user.mgmt.rap@default:default"/>
What should I do other than this? :(
Hemanth M S
Current Time: Mon Apr 29 10:20:57 GMT 2024
Powered by FUDForum. Page generated in 0.06253 seconds
