Handler and Integration Test [message #481486] |
Fri, 21 August 2009 04:43  |
First Thanks for reading this post.
I created an Handler class which deletes model elements from my tree
navigator. It semms to work well. Now I'm trying to write an integration
test for my Handler class. Therefore I used JUnit. I have basic knowledge
in JUnit but i never tested a Handler before. Wenn I start my test, i will
get a lot of NullPointExceptions.
For example that method in the class EMFTransactionPlugin causes an
Exception because getPlugin() returns null.
public static String getPluginId() {
return getPlugin().getBundle().getSymbolicName();
It is easy to understand because the whole UI interaction is missing in my
test.
Now my question.
How can I create an integration test for handlers unsing Junit? Can
somebody please help me, maybe there is a tutorial?
Thank you very much!
RCH
Re: Handler and Integration Test [message #481611 is a reply to message #481486] |
Fri, 21 August 2009 16:11  |
FYI, this group is a "sandbox" for testing your ability to post
messages; it is not for technical discussions relating to testing.
You question would be better placed on the eclipse.platform group.
Eric
RCH wrote:
> knowledge in JUnit but i never tested a Handler before. Wenn I start my
> test, i will get a lot of NullPointExceptions.
> Exception because getPlugin() returns null. public static String
> getPluginId() {
> my test.
> Now my question.
> RCH
Re: Handler and Integration Test [message #568118 is a reply to message #481486] |
Eric
RCH wrote:
> getPluginId() {
> my test.
> Now my question.
> RCH
FUDForum. Page generated in 0.04983 seconds
