Home » Modeling » UML2 Tools » cannot open diagram programmatically
cannot open diagram programmatically [message #474403] |
Tue, 06 May 2008 03:55  |
I have the following problem using UML2Tools plugin.
I can open the uml2class_diagram files from my Eclipse, however this does
not work when I do this programmatically. I get the following
error: "Cannot open input element. Reason: text editor does not have a
document provider".
All other files open fine.
Here is the code that handles the opening:
IFileStore fileStore = EFS.getLocalFileSystem().getStore(new Path(path));
IDE.openEditorOnFileStore(PlatformUI.getWorkbench().getActiv eWorkbenchWindow().getActivePage(),
fileStore);
I've already tried to launch eclipse with the -clean option. Doesn't help.
Thanks in advance for the help.
Here is the complete stack trace of the exception:
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor$1.run(DiagramDocumentEditor.java:120)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2451)
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.init(DiagramDocumentEditor.java:129)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2737)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2651)
at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPag e.java:2643)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2595)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2590)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2574)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2557)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1090)
org.kuleuven.grecco.views.GreccoConcernLibraryView$3.run(Gre ccoConcernLibraryView.java:233)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$
(ActionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Aram Hovsepyan
Distrinet research group
Katholieke Universiteit Leuven
Re: cannot open diagram programmatically [message #474404 is a reply to message #474403] |
Tue, 06 May 2008 07:21   |
Hello Aram,
I tried to open the editor programmatically the way you did, it works fine.
However, I had the same exception you had, when path was workspace-relative.
Is path in your example absolute (something like 'C:/junit-workspace/TestProject/test.umlclass_diagram')?
BTW, we open the diagram editor programattically in tests (org.eclipse.uml2.diagram.common.tests.UMLDiagramFacade#open ()):
IWorkbenchPage page = workbench.getActiveWorkbenchWindow().getActivePage();
IEditorPart editorPart = page .openEditor(new FileEditorInput((IFile) workspaceResource),
workbench.getEditorRegistry().getDefaultEditor(workspaceReso urce.getFullPath().toString()).getId());
Code is a bit different from yours, it uses IFile. Probably it can solve
your problem.
Best wishes,
Tatiana.
> however this does
> document provider".
> Path(path));
> Window().getActivePage(), fileStore);
> Doesn't help.
> java.lang.NullPointerException
> at
> at
> xt.java:369)
> at
> at
> a:758)
> at
> at
> 755)
> at
> at
> at
> 4)
> at
> ce.java:643)
> at
> a:426)
> at
> ference.java:592)
> at
> at
> at
> at
> at
> at
> ck.java:1256)
> at
> at
> at
> at
> at
> ner.java:63)
> at
> java:217)
> at
> va:207)
> at
> va:774)
> at
> anager.java:673)
> at
> 4)
> at
> age.java:2737)
> at
> a:2651)
> at
> 3)
> at
> at
> at
> 90)
> at
> 74)
> at
> 57)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> a:289)
> at
> :461)
> at
> at
> ation.java:106)
> at
> .java:169)
> at
> at
> at
> a:363)
> at
> a:176)
> at
> ava:39)
> at
> orImpl.java:25)
> at
Re: cannot open diagram programmatically [message #474407 is a reply to message #474404] |
Tue, 06 May 2008 09:17   |
Hi Tatiana,
Thanks for the reply but somehow it still doesn't work.
I need to mention that I'm working under linux. I've tried with the IFile
and I get now the following error:
Resource /home/barri/install/eclipse/plugin/org.kuleuven.grecco/conce rn_library/audit_interceptor.umlclass_diagram
does not exist. I've checked and the file is in there.
I think it has to do something with linux and paths, but I can't find it.
By the way, the tree UML editor works fine with this code. If I open a .uml
file with the same code it doesn't give any errors.
thnx in advance.
Tatiana Fesenko wrote:
> Hello Aram,
> fine. However, I had the same exception you had, when path was
> workspace-relative. Is path in your example absolute (something like
> workspaceResource),
> your problem.
> Best wishes,
> Tatiana.
>> however this does
>> document provider".
>> Path(path));
>> Doesn't help.
>> at
>> at
>> xt.java:369)
>> at
>> at
>> a:758)
>> at
>> at
>> 755)
>> at
>> at
>> at
>> 4)
>> at
>> ce.java:643)
>> at
>> a:426)
>> at
>> ference.java:592)
>> at
>> at
>> at
>> at
>> at
>> at
>> ck.java:1256)
>> at
>> at
>> at
>> at
>> at
>> ner.java:63)
>> at
>> java:217)
>> at
>> va:207)
>> at
>> va:774)
>> at
>> anager.java:673)
>> at
>> 4)
>> at
>> age.java:2737)
>> at
>> a:2651)
>> at
>> 3)
>> at
>> at
>> at
>> 90)
>> at
>> 74)
>> at
>> 57)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> a:289)
>> at
>> :461)
>> at
>> at
>> ation.java:106)
>> at
>> .java:169)
>> at
>> at
>> at
>> a:363)
>> at
>> a:176)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> ava:39)
>> at
>> orImpl.java:25)
>> at
Aram Hovsepyan
Re: cannot open diagram programmatically [message #474417 is a reply to message #474411] |
Thu, 22 May 2008 10:32   |
Hi Aram,
I found the root of the problem.
If diagram file is located in eclipse workspace, it is opened correctly in
both Windows and Linux (I use Ubuntu) systems.
However, when I tried to open diagrams that are not in workspace, it didn't
work, while *.uml files were opened well.
The reason is, that when file isn't located in Workspace, IDE.getEditorInput()
is instanceof FileStoreEditorInput. It is used as a parameter in UMLDiagramEditor#setDocumentProvider(IEditorInput)
UMLDiagramEditor#setDocumentProvider(IEditorInput) sets null in such case.
That's why getDocumentProvider() returns null after and you see NPE.
Solution is to add diagram file to your workspace before opening it. It should
help.
I hope I wasn't late with the advice.
Best wishes,
Tatiana.
> Hey guys,
> I still can't find it. I have to give a demo at thursday and
> I'd like to
> have it working :). The UML2 tree editor works fine while the diagram
> editor always results in an error saying that he can't find the file,
> while
> the file is there.
> thnx.
> Aram Hovsepyan wrote:
>> this does
>> a
>> document provider".
>> Path(path));
>> fileStore);
>> help. Thanks in advance for the help.
>> at
>> at
> xt.java:369)
>> at
>> at
> a:758)
>> at
>> at
>> :755) at
>> at
>> at
> 4)
>> at
> ce.java:643)
>> at
> a:426)
>> at
> ference.java:592)
>> at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9) at
>> at
>> at
>> at
>> at
> ck.java:1256)
>> at
>> at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04) at
>> org.eclipse.ui.internal.PartStack.add(PartStack.java:499) at
>> org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 ) at
>> org.eclipse.ui.internal.PartStack.add(PartStack.java:485) at
>> org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 ) at
> ner.java:63)
>> at
> java:217)
>> at
> va:207)
>> at
> va:774)
>> at
> anager.java:673)
>> at
> 4)
>> at
> age.java:2737)
>> at
> a:2651)
>> at
> (WorkbenchPage.java:2643)
>> at
>> at
>> at
>> 590)
>> at
>> 574)
>> at
>> 557)
>> at
>> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 ) at
>> at
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101) at
>> at
>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353) at
>> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19) at
>> org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466) at
> a:289)
>> at
> :461)
>> at
>> at
> ation.java:106)
>> at
> .java:169)
>> at
>> at
>> at
> a:363)
>> at
> a:176)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
> ava:39)
>> at
> orImpl.java:25)
>> at
>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447) at
Re: cannot open diagram programmatically [message #474420 is a reply to message #474417] |
Mon, 26 May 2008 04:16  |
Hi Tatiana,
Thnx for the help. I managed to get it working by creating a link to the
diagram and .uml files in the current workspace.
file.createLink(location, IResource.NONE, null);
Aram.
> Hi Aram,
> didn't work, while *.uml files were opened well.
> IDE.getEditorInput() is instanceof FileStoreEditorInput. It is used as a
> parameter in UMLDiagramEditor#setDocumentProvider(IEditorInput) .
> should help.
> Best wishes,
> Tatiana.
>> Hey guys,
>> I'd like to
>> while
>> the file is there.
>> thnx.
>>> Hi,
>>> this does
>>> a
>>> document provider".
>>> Path(path));
>>> fileStore);
>>> at
>>> at
>> xt.java:369)
>>> at
>>> at
>> a:758)
>>> at
>>> at
>>> :755) at
>>> at
>>> at
>> 4)
>>> at
>> ce.java:643)
>>> at
>> a:426)
>>> at
>> ference.java:592)
>>> at
>>> at
>>> at
>>> at
>> ck.java:1256)
>>> at
>> ner.java:63)
>>> at
>> java:217)
>>> at
>> va:207)
>>> at
>> va:774)
>>> at
>> anager.java:673)
>>> at
>> 4)
>>> at
>> age.java:2737)
>>> at
>> a:2651)
>>> at
>>> at
>>> at
>>> at
>>> 590)
>>> at
>>> 574)
>>> at
>>> 557)
>>> at
>>> at
>>> at
>> a:289)
>>> at
>> :461)
>>> at
>>> at
>> ation.java:106)
>>> at
>> .java:169)
>>> at
>>> at
>>> at
>> a:363)
>>> at
>> a:176)
>> ava:39)
>>> at
>> orImpl.java:25)
>>> at
Aram Hovsepyan
Re: cannot open diagram programmatically [message #619709 is a reply to message #474403] |
Hello Aram,
your problem.
Best wishes,
Tatiana.
> however this does
> document provider".
> Path(path));
> Doesn't help.
> at
> at
> xt.java:369)
> at
> at
> a:758)
> at
> at
> 755)
> at
> at
> at
> 4)
> at
> ce.java:643)
> at
> a:426)
> at
> ference.java:592)
> at
> at
> at
> at
> at
> at
> ck.java:1256)
> at
> at
> at
> at
> at
> ner.java:63)
> at
> java:217)
> at
> va:207)
> at
> va:774)
> at
> anager.java:673)
> at
> 4)
> at
> age.java:2737)
> at
> a:2651)
> at
> 3)
> at
> at
> at
> 90)
> at
> 74)
> at
> 57)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> a:289)
> at
> :461)
> at
> at
> ation.java:106)
> at
> .java:169)
> at
> at
> at
> a:363)
> at
> a:176)
> at
> ava:39)
> at
> orImpl.java:25)
> at
Re: cannot open diagram programmatically [message #619715 is a reply to message #474404] |
Hi Tatiana,
thnx in advance.
> Hello Aram,
> workspaceResource),
> your problem.
> Best wishes,
> Tatiana.
>> however this does
>> document provider".
>> Path(path));
>> Doesn't help.
>> at
>> at
>> xt.java:369)
>> at
>> at
>> a:758)
>> at
>> at
>> 755)
>> at
>> at
>> at
>> 4)
>> at
>> ce.java:643)
>> at
>> a:426)
>> at
>> ference.java:592)
>> at
>> at
>> at
>> at
>> at
>> at
>> ck.java:1256)
>> at
>> at
>> at
>> at
>> at
>> ner.java:63)
>> at
>> java:217)
>> at
>> va:207)
>> at
>> va:774)
>> at
>> anager.java:673)
>> at
>> 4)
>> at
>> age.java:2737)
>> at
>> a:2651)
>> at
>> 3)
>> at
>> at
>> at
>> 90)
>> at
>> 74)
>> at
>> 57)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> a:289)
>> at
>> :461)
>> at
>> at
>> ation.java:106)
>> at
>> .java:169)
>> at
>> at
>> at
>> a:363)
>> at
>> a:176)
>> at
>> ava:39)
>> at
>> orImpl.java:25)
>> at
Aram Hovsepyan
Re: cannot open diagram programmatically [message #619722 is a reply to message #474403] |
Tue, 20 May 2008 03:25  |
Hey guys,
I still can't find it. I have to give a demo at thursday and I'd like to
editor always results in an error saying that he can't find the file, while
the file is there.
thnx.
> this does
> document provider".
> fileStore);
> Doesn't help. Thanks in advance for the help.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.internal.PartStack.add(PartStack.java:499) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Aram Hovsepyan
Re: cannot open diagram programmatically [message #619812 is a reply to message #474411] |
Wed, 21 May 2008 08:49  |
Hi Aram,
Have you solved the problem? Could you please try to programmatically open
other GMF-generated diagrams, say, Taipan.
I'm installing Linux on my machine to check the problem.
Tatiana.
> Hey guys,
> I'd like to
> while
> the file is there.
> thnx.
>> this does
>> a
>> document provider".
>> Path(path));
>> fileStore);
>> at
>> at
> xt.java:369)
>> at
>> at
> a:758)
>> at
>> at
>> :755) at
>> at
>> at
> 4)
>> at
> ce.java:643)
>> at
> a:426)
>> at
> ference.java:592)
>> at
>> at
>> at
>> at
> ck.java:1256)
>> at
> ner.java:63)
>> at
> java:217)
>> at
> va:207)
>> at
> va:774)
>> at
> anager.java:673)
>> at
> 4)
>> at
> age.java:2737)
>> at
> a:2651)
>> at
>> at
>> at
>> at
>> 590)
>> at
>> 574)
>> at
>> 557)
>> at
>> at
>> at
> a:289)
>> at
> :461)
>> at
>> at
> ation.java:106)
>> at
> .java:169)
>> at
>> at
>> at
> a:363)
>> at
> a:176)
> ava:39)
>> at
> orImpl.java:25)
>> at
Re: cannot open diagram programmatically [message #619816 is a reply to message #474411] |
Hi Aram,
help.
Best wishes,
Tatiana.
> Hey guys,
> I'd like to
> while
> the file is there.
> thnx.
>> this does
>> a
>> document provider".
>> Path(path));
>> fileStore);
>> at
>> at
> xt.java:369)
>> at
>> at
> a:758)
>> at
>> at
>> :755) at
>> at
>> at
> 4)
>> at
> ce.java:643)
>> at
> a:426)
>> at
> ference.java:592)
>> at
>> at
>> at
>> at
> ck.java:1256)
>> at
> ner.java:63)
>> at
> java:217)
>> at
> va:207)
>> at
> va:774)
>> at
> anager.java:673)
>> at
> 4)
>> at
> age.java:2737)
>> at
> a:2651)
>> at
>> at
>> at
>> at
>> 590)
>> at
>> 574)
>> at
>> 557)
>> at
>> at
>> at
> a:289)
>> at
> :461)
>> at
>> at
> ation.java:106)
>> at
> .java:169)
>> at
>> at
>> at
> a:363)
>> at
> a:176)
> ava:39)
>> at
> orImpl.java:25)
>> at
Re: cannot open diagram programmatically [message #619823 is a reply to message #474417] |
Hi Tatiana,
Aram.
> Hi Aram,
> should help.
> Best wishes,
> Tatiana.
>> Hey guys,
>> I'd like to
>> while
>> the file is there.
>> thnx.
>>> Hi,
>>> this does
>>> a
>>> document provider".
>>> Path(path));
>>> fileStore);
>>> at
>>> at
>> xt.java:369)
>>> at
>>> at
>> a:758)
>>> at
>>> at
>>> :755) at
>>> at
>>> at
>> 4)
>>> at
>> ce.java:643)
>>> at
>> a:426)
>>> at
>> ference.java:592)
>>> at
>>> at
>>> at
>>> at
>> ck.java:1256)
>>> at
>> ner.java:63)
>>> at
>> java:217)
>>> at
>> va:207)
>>> at
>> va:774)
>>> at
>> anager.java:673)
>>> at
>> 4)
>>> at
>> age.java:2737)
>>> at
>> a:2651)
>>> at
>>> at
>>> at
>>> at
>>> 590)
>>> at
>>> 574)
>>> at
>>> 557)
>>> at
>>> at
>>> at
>> a:289)
>>> at
>> :461)
>>> at
>>> at
>> ation.java:106)
>>> at
>> .java:169)
>>> at
>>> at
>>> at
>> a:363)
>>> at
>> a:176)
>> ava:39)
>>> at
>> orImpl.java:25)
>>> at
Aram Hovsepyan
Current Time: Tue Jul 15 19:38:21 EDT 2025
Powered by FUDForum. Page generated in 0.06221 seconds
