Home » Modeling » UML2 » WrappedException: feature eGenericType not found while loading model
WrappedException: feature eGenericType not found while loading model [message #471955] Wed, 28 March 2007 11:05 Go to next message
I'm kind of lost with the above problem: When I try to create a
ResourceSet to be used for loading a UML activity, I get that exception.
I found somewhere that this is related to using UML 2.1 with EMF before
2.3, but this is not the case for me. Some more info:
I have a Java project within Eclipse 3.3M5, and I added a libs directory
containing the appropriate jar files (i.e., org.eclipse.uml2.uml_2.1.0,
org.eclipse.uml2.common_1.3.0, org.eclipse.emf.ecore_2.3.0,
org.eclipse.emf.common_2.3.0, and org.eclipse.emf.ecore.xmi_2.3.0). I
start the application using Run as.../Java application. My source to
create the ResourceSet looks as follows:
private static ResourceSet createResourceSet() {
ResourceSet rs = new ResourceSetImpl();
rs.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
Map extensionToFactoryMap = rs.getResourceFactoryRegistry()
.getExtensionToFactoryMap();
extensionToFactoryMap.put(UMLResource.FILE_EXTENSION,
UMLResource.Factory.INSTANCE);
extensionToFactoryMap.put("ecore", new EcoreResourceFactoryImpl());
extensionToFactoryMap.put(Resource.Factory.Registry.DEFAULT_ EXTENSION,
new XMIResourceFactoryImpl());
return rs;
The exception occurs when executing the put method of the 2nd line. here
it is:
Exception in thread "main" java.lang.ExceptionInInitializerError
de.upb.dmm.soundnesschecker.util.UML2Utils.createResourceSet (UML2Utils.java:72)
at de.upb.dmm.soundnesschecker.util.UML2Utils.<clinit>(UML2Utils.java:26)
de.upb.dmm.soundnesschecker.SoundnessChecker.doTransformatio ns(SoundnessChecker.java:54)
de.upb.dmm.soundnesschecker.SoundnessChecker.startChecker(So undnessChecker.java:95)
de.upb.dmm.soundnesschecker.ServiceConsistencyChecker.main(S erviceConsistencyChecker.java:64)
Caused by: org.eclipse.emf.common.util.WrappedException:
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature
'eGenericType' not found.
(jar:file:/C:/Dokumente%20und%20Einstellungen/chris/Desktop/ M5/eclipse/plugins/org.eclipse.uml2.uml_2.1.0.v200701040816. jar!/org/eclipse/uml2/uml/internal/impl/uml.ecore,
24, 98)
org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.loadPackag e(UMLPackageImpl.java:10909)
org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.init(UMLPa ckageImpl.java:1965)
at org.eclipse.uml2.uml.UMLPackage.<clinit>(UMLPackage.java:72)
... 5 more
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException:
Feature 'eGenericType' not found.
24, 98)
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:80)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:188)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1094)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:900)
org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.loadPackag e(UMLPackageImpl.java:10907)
... 7 more
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature
24, 98)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeatu re(XMLHandler.java:1830)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeatu re(XMLHandler.java:1794)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.handleUnknownFeatu re(XMIHandler.java:149)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1738)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:957)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:936)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:681)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:163)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:178)
... 11 more
Thanks in advance,
Chris
Re: WrappedException: feature eGenericType not found while loading model [message #471969 is a reply to message #471955] Wed, 28 March 2007 12:48 Go to previous message
Hi Chris,
It looks like you have Eclipse M5 but UML M4 ( from Jan4 ). Please try to
take all the proper dependencies required by UML and then retry ( try with
the M5 of UML or one of the more recent integration builds ... the download
page will list all the dependencies ).
If you still have the issue I will try to reproduce it on my machine but it
sounds like you are possibly mixing and matching plugins.
- James.
"chris" <chris_42@gmx.net> wrote in message
news:eue08f$6l9$1@utils.eclipse.org...
> return rs;
> it is:
> at
72)
> at
ker.java:54)
> at
ava:95)
> at
yChecker.java:64)
ns/org.eclipse.uml2.uml_2.1.0.v200701040816.jar!/org/eclipse /uml2/uml/intern
al/impl/uml.ecore,
> 24, 98)
> at
..java:10909)
> at
965)
> ... 5 more
al/impl/uml.ecore,
> 24, 98)
> at
> at
80)
> at
> at
> at
..java:10907)
> ... 7 more
al/impl/uml.ecore,
> 24, 98)
> at
va:1830)
> at
va:1794)
> at
va:149)
> at
> at
> at
> at
> at
> at
Source)
> at
wn
> Source)
> at
> Source)
> at
> Source)
> ... 11 more
> Thanks in advance,
> Chris
Re: WrappedException: feature eGenericType not found while loading model [message #604089 is a reply to message #471955] Wed, 28 March 2007 12:48 Go to previous message
Hi Chris,
- James.
> return rs;
> it is:
> at
72)
> at
ker.java:54)
> at
ava:95)
> at
yChecker.java:64)
al/impl/uml.ecore,
> 24, 98)
> at
..java:10909)
> at
965)
> ... 5 more
al/impl/uml.ecore,
> 24, 98)
> at
> at
80)
> at
> at
> at
..java:10907)
> ... 7 more
al/impl/uml.ecore,
> 24, 98)
> at
va:1830)
> at
va:1794)
> at
va:149)
> at
> at
> at
> at
> at
> at
Source)
> at
wn
> Source)
> at
> Source)
> at
> Source)
> ... 11 more
> Thanks in advance,
> Chris
Previous Topic:Creating a Usage programmatically
Next Topic:Creating a Usage programmatically
Current Time: Wed Jul 16 02:35:04 EDT 2025
Powered by FUDForum. Page generated in 0.09614 seconds
