Re: Problem in running report after migrating to 2.5 [message #468313 is a reply to message #468200] |
Wed, 05 August 2009 01:42 |
Kanya,
Did you update your runtime? The error you are getting is locating the
design. Are you using a full path to the report. I know I saw
something about using __report=c:/mytestreport.rptdesign had to change
to __report=file://c:/mytestreport.rptdesign with the viewer.
Jason
Kanya wrote:
> Hi
> I ve upgraded my BIRT from 2.2.1 to 2.5 by downloading ALL IN ONE
> eclipse 2.5 from the following link.
> " http://www.eclipse.org/downloads/download.php?file=/birt/dow nloads/drops/R-R1-2_5_0-200906180630/birt-report-designer-al l-in-one-2_5_0.zip"
> After extracting the zip in my local folder, i opened up BIRT and tried
> migrating one of my reports to this new version. I was able to generate
> report from BIRT (through birt viewer) properly without any error(along
> with data). But, when i deployed the same migrated report on my Java
> server path and generated the report through my java application, i am
> facing the following error.
> + There is no such report design available.
> And the exception on the console is:
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper openReportDesign
> org.eclipse.birt.report.exception.ViewerException: There is no report
> design object available.
> What is wrong with my process? I have jdk 1.5 and Eclipse 3.1 installed
> in my machine. Do i need to install or do any other steps after
> downloading the new version of BIRT? ie., Am i missing any installations
> with my Java Eclipse?
> Please help.
> Thanks.
Re: Problem in running report after migrating to 2.5 [message #468426 is a reply to message #468330] |
Wed, 05 August 2009 13:38 |
Indu Messages: 11 Registered: July 2009 |
Junior Member |
Kanya wrote:
Jason
As i am new to this upgrade, could you please explain me what are the
steps which has to be done once we upgrade to new version of BIRT?
I ve just migrated the report developed in previous version to my new 2.5
version. I tried updating my runtime version by the following steps but
resulted in error again.
Any other downloads and installation necessary?
I did the following steps to install the birt runtime version in my app.
1)Downloaded the BIRT_runtime_version2.5.zip from the site.
2)Extracted and saved the same in my local.
3)Copied the webviewer example directory from this and placed inside my
jboss/server/apollo/deploy path.
4)renamed this to reports.war
5)placed my reports inside this
6)started the jboss server
7)generated the report from the application.
i am able to see the reports link in my url, but it resulted in a servlet
exception.
SEVERE: Not found choice: any
18:37:33,963 ERROR (http-0.0.0.0-8080-4) [[jsp]] Servlet.service() for
servlet jsp threw exception
java.lang.NoSuchMethodError:
org.eclipse.birt.report.utility.ParameterAccessor.getEncoded QueryString(Ljavax/servlet/http/HttpServletRequest;Ljava/lan g/String;Ljava/lang/String;)Ljava/lang/String;
org.apache.jsp.webcontent.birt.pages.control.ToolbarFragment _jsp._jspService(org.apache.jsp.webcontent.birt.pages.contro l.ToolbarFragment_jsp:71)
org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.callBack(AbstractBaseFragment.java:106)
org.apache.jsp.webcontent.birt.pages.layout.FramesetFragment _jsp._jspService(org.apache.jsp.webcontent.birt.pages.layout .FramesetFragment_jsp:254)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:97)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:322)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:314)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
Whats wrong with my process? Am i missing out anything?
> Your assistance is highly needed.
> Thanks in advance.
> Jason Weathersby wrote:
>> Kanya,
>> Jason
>> Kanya wrote:
>>> Hi
>>> Please help.
>>> Thanks.
Re: Problem in running report after migrating to 2.5 [message #479323 is a reply to message #468426] |
Mon, 10 August 2009 16:48 |
Kanya,
This error is around the any option for a datatype being removed. Can
you open in the designer and change those types?
Jason
Kanya wrote:
> Kanya wrote:
> Jason
> 2.5 version. I tried updating my runtime version by the following steps
> but resulted in error again.
> 5)placed my reports inside this 6)started the jboss server
> servlet exception.
> at
> at
> at
> at
> at
> at
>> Your assistance is highly needed. Thanks in advance.
>>> Kanya,
>>> the design. Are you using a full path to the report. I know I saw
>>> change to __report=file://c:/mytestreport.rptdesign with the viewer.
>>> Jason
>>> Kanya wrote:
>>>> Hi
>>>> tried migrating one of my reports to this new version. I was able
>>>> to generate report from BIRT (through birt viewer) properly without
>>>> any error(along with data). But, when i deployed the same migrated
>>>> report on my Java server path and generated the report through my
>>>> java application, i am facing the following error.
>>>> openReportDesign
>>>> report design object available.
>>>> installed in my machine. Do i need to install or do any other steps
>>>> after downloading the new version of BIRT? ie., Am i missing any
>>>> installations with my Java Eclipse?
>>>> Please help.
>>>> Thanks.
Re: Problem in running report after migrating to 2.5 [message #479495 is a reply to message #479323] |
Tue, 11 August 2009 10:39 |
Junior Member |
Jason
Thanks a lot for your response. I tried this too but it dint solve the
problem. Beside this, i tried restarting the server after deleting the
tmp and work directories and this worked out !! Somehow this resolved the
issue.
Thanks again !
> Kanya,
> Jason
> Kanya wrote:
>> Kanya wrote:
>> Jason
>> servlet exception.
>> at
>> at
>> at
>> at
>> at
>> at
>>>> Kanya,
>>>> Jason
>>>> Kanya wrote:
>>>>> Hi
>>>>> openReportDesign
>>>>> Please help.
>>>>> Thanks.
FUDForum. Page generated in 0.03976 seconds
