Tree CCombo KeyListener traverse problem swt 3.1.1 [message #462067] |
Wed, 05 October 2005 16:00 |
Originally posted by: supplanter64.hotmail.com
I am creating a treetable using the new swt Tree.
In my Tree I am adding two CCombo editors to columns 2 and 3. If I add
keylisteners to these controls, traversal (TAB key) from the tree to the
control does not work and traversal from control to control does not work.
Basically nothing seems to have focus.
Bug?
I am using modify and key listeners to provide auto-complete functionality
to the combo boxes. As the user types, if the leading characters of an item
in the combo box's drop down list matches those that the user types, then
the word is completed with the part that they haven't typed is highlighted
(using setSelection(Point point)).
The keylistener simply sets a flag to tell modify not to do it's thing when
the backspace, delete, or ctrl-x keys are pressed, otherwise my routine in
the modify listener will autocomplete again after the highlighted selection
was removed. So it looks like backspace, delete, etc. have no effect.
Re: Tree CCombo KeyListener traverse problem swt 3.1.1 [message #462069 is a reply to message #462067] |
Wed, 05 October 2005 16:09 |
James Cornett Messages: 3 Registered: July 2009 |
Sorry about the name...
Newreader was not setup correctly.
Here my custom combo source:
public class CComboCustom extends Composite
CCombo combo;
private boolean skipAutoComplete = false;
public CComboCustom(Composite composite, int style) {
super(composite, SWT.NONE);
this.setLayout(new FillLayout());
combo = new CCombo(this, style);
combo.addModifyListener(new ComboModifyListener());
combo.addKeyListener(new ComboKeyListener());
combo.addMouseListener(new ComboMouseListener());
layout();
private class ComboMouseListener extends MouseAdapter
public void mouseDown(MouseEvent e)
skipAutoComplete = true;
private class ComboKeyListener implements KeyListener
public void keyPressed(KeyEvent e)
if (e.keyCode == SWT.BS ||
e.keyCode == SWT.DEL ||
(e.keyCode == 120 && e.stateMask == SWT.CONTROL)) {
else
public void keyReleased(KeyEvent e)
private class ComboModifyListener implements ModifyListener
public void modifyText(ModifyEvent e)
if (!skipAutoComplete) {
String text = combo.getText();
if (text == null || text.equals(""))
return;
String current = "";
String[] items = combo.getItems();
int caretPosition = combo.getSelection().x;
boolean found = false;
for (int i = 0; i < items.length && !found; i++) {
current = items[i];
if (current.toUpperCase().startsWith(text.toUpperCase())) {
combo.setText(current);
found = true;
if (found) {
combo.setSelection(new Point(caretPosition,256));
public CCombo getCombo()
return combo;
"Eclipse RCP News Server" <supplanter64@hotmail.com> wrote in message
news:di0ta7$8f4$1@news.eclipse.org...
> Bug?
> item in the combo box's drop down list matches those that the user types,
> then the word is completed with the part that they haven't typed is
> highlighted (using setSelection(Point point)).
> when the backspace, delete, or ctrl-x keys are pressed, otherwise my
> routine in the modify listener will autocomplete again after the
> highlighted selection was removed. So it looks like backspace, delete,
FUDForum. Page generated in 0.02926 seconds
