calling a tableitem setText [message #460419] |
Thu, 25 August 2005 12:52  |
Originally posted by: ignorante.ignorante.com
I try to call a function which is in other class [window1] to add a new
item in a table, but always I get an 'Error: "Widget is disposed"', so I
dont how to add a new item in this way.
what's wrong? what can i do? How can i call a function to add a new item?
Thanks.
public class main {
window1 w1 = new window1();
w1.createSShell();
w1.populateTable();
public class window1 {
private Shell sShell = null;
private Table table = null;
Display display = new Display();
private TableItem item = null;
public void createSShell() {
GridLayout gridLayout = new GridLayout();
gridLayout.numColumns = 3;
gridLayout.makeColumnsEqualWidth = true;
sShell = new Shell(display);
sShell.setText("Shell");
sShell.setLayout(gridLayout);
sShell.setSize(new Point(300, 200));
GridData grid = new GridData();
grid.grabExcessHorizontalSpace = true;
grid.horizontalAlignment = GridData.FILL;
createTable();
sShell.open();
while (!sShell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
public void createTable() {
table = new Table(sShell, SWT.NONE);
TableColumn col1 = new TableColumn(table,SWT.LEFT);
col1.setText("COL1");
col1.setWidth(80);
TableColumn col2 = new TableColumn(table,SWT.LEFT);
col2.setText("COL2");
col2.setWidth(80);
table.setHeaderVisible(true);
table.setLinesVisible(true);
GridData gridData = new GridData(GridData.FILL_HORIZONTAL);
gridData.horizontalSpan = 3;
table.setLayoutData(gridData);
public void populateTable(){
item = new TableItem(table,0);
item.setText(new String[] {"c1","c2"});
Re: calling a tableitem setText [message #460445 is a reply to message #460419] |
Fri, 26 August 2005 11:58   |
The problem is that your populateTable() method never gets invoked until
after the Shell and its child Table have been disposed. Your
read-and-dispatch loop should move to after populateTable() has been
invoked, so your main method would become:
w1.createSShell();
w1.populateTable();
while (!sShell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
....and the read-and-dispatch loop would be removed from
window1.createSShell().
Grant
"ignorante" <ignorante@ignorante.com> wrote in message
news:2bba01d9cfa2af07d0ba97c4ab0a517c$1@www.eclipse.org...
> Thanks.
> public class main {
> public static void main(String[] args) {
> w1.createSShell();
> w1.populateTable();
> createTable();
> sShell.open();
> display.dispose ();
> col1.setWidth(80);
> col2.setWidth(80);
Re: calling a tableitem setText [message #460450 is a reply to message #460445] |
Fri, 26 August 2005 16:52  |
Thank you!
Now I can understand that little problem about "dispose".
public class main {
w1.createSShell();
w1.populateTable();
while (!w1.sShell.isDisposed()) {
if (!w1.display.readAndDispatch()) w1.display.sleep();
w1.display.dispose();
FUDForum. Page generated in 1.28663 seconds
