Problem with Image class?? [message #460207] |
Mon, 22 August 2005 20:21 |
No real name Messages: 3 Registered: July 2009 |
We are working on a graphical editing tool. The model editor has a flyout
palette. After opening and closing a model a few times, we get the error
below.
When we load a model, the memory usage in task manager keeps increasing, so
also the count of handles. We only have 4 images in the image registry. And
we have a few more in the palette, outside the image registry. We have not
supplied any images to the outline view to see if that solves the issue, but
it does not.
In the Image class, in the init(Device, int, int) method, the handle =
OS.CreateCompatibleBitmap(hDC, width, height); call is made. After some
time, this fails to get a handle and we get the error given below. None of
our code is involved here. Is this an eclipse bug OR are we not doing
something?
thanks and regards
Vinay
Unhandled event loop exception
Reason:
No more handles
Error while informing user about event loop exception:
org.eclipse.swt.SWTError: No more handles
at org.eclipse.swt.SWT.error(SWT.java:2717)
at org.eclipse.swt.graphics.Image.init(Image.java:1366)
at org.eclipse.swt.graphics.Image.<init>(Image.java:161)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$RotatedTit leLabel.updateImage(FlyoutPaletteComposite.java:988)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$RotatedTit leLabel.setFont(FlyoutPaletteComposite.java:972)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$TitleCanva s.init(FlyoutPaletteComposite.java:1188)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$TitleCanva s. <init>(FlyoutPaletteComposite.java:1170)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.createTitl e(FlyoutPaletteComposite.java:241)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.access$5(F lyoutPaletteComposite.java:240)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite$Sash.<init >(FlyoutPaletteComposite.java:607)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.createSash (FlyoutPaletteComposite.java:237)
at
org.eclipse.gef.ui.palette.FlyoutPaletteComposite.<init>(FlyoutPaletteComposite.java:169)
at
org.eclipse.gef.ui.parts.GraphicalEditorWithFlyoutPalette.cr eatePartControl(GraphicalEditorWithFlyoutPalette.java:75)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:133)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :205)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:939)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
at org.eclipse.ui.internal.EditorStack.setSelection(EditorStack .java:196)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:10 20)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:290)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:121 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:59)
at
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:266)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:694)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:683)
at
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:790)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:582)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:570)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2244)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2177)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2169)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2156)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2151)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:299)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:96)
at
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:94)
at
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:111)
at
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:293)
at
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:624)
at
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:388)
at
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:429)
at
at
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:427)
at
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:635)
at
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:731)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:211)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:206)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:238)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2773)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2432)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Dialog open exception:
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.graphics.Image.init(Image.java:1564)
at org.eclipse.swt.graphics.Image.init(Image.java:1689)
at org.eclipse.swt.graphics.Image.<init>(Image.java:628)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.ja va:840)
at org.eclipse.swt.widgets.Decorations.setImages(Decorations.ja va:909)
at org.eclipse.jface.window.Window.configureShell(Window.java:2 91)
at
org.eclipse.jface.dialogs.MessageDialog.configureShell(Messa geDialog.java:159)
at org.eclipse.jface.window.Window.createShell(Window.java:408)
at org.eclipse.jface.window.Window.create(Window.java:347)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:925)
at
org.eclipse.ui.internal.ide.dialogs.InternalErrorDialog.open (InternalErrorDialog.java:67)
at
org.eclipse.ui.internal.ide.dialogs.InternalErrorDialog.open Question(InternalErrorDialog.java:173)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.openQuestion Dialog(IDEExceptionHandler.java:151)
at
org.eclipse.ui.internal.ide.IDEExceptionHandler.handleExcept ion(IDEExceptionHandler.java:83)
at
org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.eventLoopExc eption(IDEWorkbenchAdvisor.java:240)
at
org.eclipse.ui.internal.ExceptionHandler.handleException(Exc eptionHandler.java:62)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1381)
at
at
at
at
Re: Problem with Image class?? [message #460213 is a reply to message #460207] |
Mon, 22 August 2005 20:59 |
Pratik Shah Messages: 1077 Registered: July 2009 |
You should use Sleak to see what images are being leaked (and to confirm
that is indeed the problem).
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/dev.html#tools
"vsikka" <vsikka@pathwaytechnologies.net> wrote in message
news:ded53t$l3u$1@news.eclipse.org...
> Hi
> below.
so
And
but
> it does not.
> something?
> thanks and regards
> Vinay
> Reason:
> No more handles
> at
> at
> at
> at
> at
omposite.java:241)
> at
osite.java:240)
> at
omposite.java:607)
> at
mposite.java:237)
> at
ite.java:169)
> at
> at
:616)
> at
a:939)
> at
va:59)
> at
6)
> at
> at
790)
> at
..java:582)
> at
> at
va:2244)
> at
> at
> at
> at
a:94)
> at
oup.java:111)
> at
oup.java:293)
> at
r.java:624)
> at
va:388)
> at
> at
:616)
> at
7)
> at
635)
> at
a:731)
> at
> at
> at
> at
java:335)
> at
> at
> at
9)
> at
alog.java:67)
> at
> at
> at
Handler.java:83)
> at
> at
va:62)
> at
> at
java:335)
> at
> at
FUDForum. Page generated in 0.03079 seconds
