Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT and JWS with HP-UX motif?
Re: SWT and JWS with HP-UX motif? [message #459792 is a reply to message #459772] |
Wed, 17 August 2005 02:34   |
Hi all!
....ok, what I have found was a similar situation for OS X, how to thread
to run a patched java_swt instead of the java launcher (snip block
below).
Before I start and try to type a wrapper class, I would like to know
what potential problems might occur. Therefore some questions and I
hope, someone could point me to get a workaround.
If a wrapper class is to defined which has to launch the SWT program
about a system call, all vm args, program args and the classpathes needs
to pass through.
To understand the launching order, first javws is launched and calls the
regular java on the system and provide the environment for that?
What is about security, if the wrapper itself and the SWT program in
order take use of system resources? Has the regular java launcher
problems to read the signed jars?
Many thanks for some hints!
Andreas N.
<snip>
Dane Summers wrote:
> I've done a little snooping and learned that SWT and webstart do not
appear to work at all on Mac OS X, because you cannot specify that the
webstart launcher user the 'java_swt' hacked launcher instead of 'java'.
> Does anybody know of any workarounds for this?
The ugly hack I ended up doing was to make a jar which contained a .zip
of the self-contained application bundle and a small .class to unzip and
run it. Oooogly, but it does run functionally when a Mac user clicks the
web start icon. You do end up with double dock icons and generally
startup feels non-native.
If you don't need WebStart specifically, in general I'd recommend
packaging a Mac version as an application bundle in a .dmg disk image,
the same way most downloadable Mac software is packaged. Unfortunately
you can only build a .dmg on Mac OS X, but a .zip file will often be
good enough if you need to do automated builds from another OS.
When making your .zip (or extracting one from Java code) be sure to set
the executable bit on java_swt (this can be done in Ant by fiddling with
the zipfile task).
-- brion vibber (brion @ pobox.com)
</snip>
Andreas Niemeyer wrote:
> Hi
> I would like to distribute an swt application about jnlp.
> We have some HP-UX workstations motif based with mozilla and plan to
> change our distribution concept.
> I found a note that since version 2.1 motif isn't supported?!
> http://dev.eclipse.org/viewcvs/index.cgi/*checkout*/platform -swt-home/faq.html?rev=1.140#javawebstart
> NOTE: As of 2.1, SWT Java Web Start apps can only be deployed on Windows
> and GTK.
> Is that true? Are there a workaround exists?
> Best regards,
> Andreas
Re: SWT and Java Web Start under Motif for Solaris and HP-UX ? [message #460320 is a reply to message #459792] |
Wed, 24 August 2005 04:43   |
Hi all!
I have posted some of my questions in a HP Dev Resource Central forum
and here are the answers from Eniac Zhang
http://devresource.hp.com/forums/thread.jspa?threadID=3721
One remaining and most important question I have:
What are the reasons for the unsupported Motif?
(The SWT FAQ only say: not supported since 2.1)
This means on Solaris and HP-UX no SWT about JWS can launched?!
Thank you for answers,
ANdreas
> Hi all!
> below).
> to pass through.
> Cheers,
> Andreas N.
> <snip>
> the zipfile task).
> </snip>
>> Hi
>> Windows and GTK.
>> Best regards,
>> Andreas
Re: SWT and Java Web Start under Motif for Solaris and HP-UX ? [message #460373 is a reply to message #460320] |
Wed, 24 August 2005 09:38  |
Andreas,
I think the FAQ entry is slightly misleading in two ways:
1. "As of 2.1" is not meant to imply that this worked previous to 2.1 and
then stopped working. I believe that this entry was added to the FAQ in the
2.1 timeframe, with the hope that it would be resolved in a future version.
2. The problem as I remember it was caused by SWT and AWT (AWT is used by
the JWS mechanism) attempting to access the same motif libraries on linux
simultaneously, and there being a resulting synchronization problem. I'm
not sure if this was ever actually tried on the other motif platforms
though, so if the ones you care about are hpux and solaris then it is worth
giving them a quick try.
Grant
"Andreas Niemeyer" <andreas.niemeyer@gutzmann.com> wrote in message
news:dehbvk$oik$1@news.eclipse.org...
> Hi all!
> ANdreas
> > Hi all!
> > below).
> > to pass through.
> > Cheers,
> > Andreas N.
> > <snip>
> > the zipfile task).
> > </snip>
> >> Hi
> >> Windows and GTK.
> >> Best regards,
> >> Andreas
Current Time: Wed Jul 16 04:56:59 EDT 2025
Powered by FUDForum. Page generated in 1.31222 seconds
