Re: AssertionError in ImageContent.getImageURI() on running RunAndRenderTask [message #454506 is a reply to message #454465] |
Sat, 01 August 2009 18:19 |
velu Messages: 5 Registered: July 2009 |
Junior Member |
By the way, I have provided below the report design file content:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.1.v20080911 Build <2.3.1.v20080917-1340></property>
<property name="units">in</property>
<list-property name="propertyBindings">
<structure>
<property name="name">FILELIST</property>
<property name="id">56</property>
<expression name="value">importPackage( Packages.java.io );
importPackage( Packages.javax.servlet.http );
var servlet=reportContext.getHttpServletRequest();
if(servlet != null &&
servlet.getAttribute("attributeBean").isDesigner() ){
config[ "birt.viewer.working.path" ] + "/../../../BIRTTest/top-aps.xml";
}</expression>
</structure>
</list-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<list-property name="libraries">
<structure>
<property name="fileName">Test-Library.rptlibrary</property>
<property name="namespace">Test-Library</property>
</structure>
</list-property>
<parameters>
<scalar-parameter name="ReportTitle" id="295">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="paramType">simple</property>
<property name="controlType">text-box</property>
<property
name="defaultValue">C:\temp\birt\top-aps.xml</property>
<property name="distinct">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.datatools.enablement.oda.xml" name="Top APs XML
Data Source" id="56"/>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet " name="Top
APs Report: Top APs Data Set" id="57">
<list-property name="columnHints">
<structure>
<property name="columnName">AP Name</property>
<property name="displayName">AP Name</property>
</structure>
<structure>
<property name="columnName">Total Clients</property>
<property name="displayName">Total Clients</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">AP Name</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">Total Clients</property>
<property name="dataType">integer</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Top APs XML Data Source</property>
<structure>
<property name="nativeName">AP Name</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">Total Clients</property>
<property name="nativeDataType">4</property>
</structure>
</list-property>
<property
name="queryText"> table0#-TNAME-#table0#:#[/REPORT/CLIENT-SUMMARY-BY-AP/TOP_N/ AP_SESSION_LOAD]#:#{AP
Name;STRING;/@name},{Total Clients;INT;/@count}</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>AP Name</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>-1</design:precision>
<design:scale>-1</design:scale>
<design:nullability>Unknown</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>AP Name</design:label>
<design:formattingHints/>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>Total Clients</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:usageHints>
<design:label>Total Clients</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
<list-property name="privateDriverProperties">
<ex-property>
<name>MAX_ROW</name>
<value>-1</value>
</ex-property>
<ex-property>
<name>XML_FILE</name>
</ex-property>
</list-property>
</oda-data-set>
<oda-data-set
APs Report: Bottom APs Data Set" id="58">
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="needsCache">false</property>
<structure>
</structure>
<structure>
</structure>
</list-property>
<property
name="queryText"> table0#-TNAME-#table0#:#[/REPORT/CLIENT-SUMMARY-BY-AP/BOTTOM _N/AP_SESSION_LOAD]#:#{AP
<model:DesignValues
<design:attributes>
<design:usageHints>
<design:attributes>
<design:usageHints>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
<oda-data-set
name="Clients Distribution By Radios By APs" id="178">
<structure>
</structure>
<structure>
<property name="name">Radio</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">SSID</property>
</structure>
<structure>
<property name="position">4</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">Total Count At AP</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">Total Clients At
Radio</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">Radio</property>
</structure>
<structure>
<property name="nativeName">SSID</property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">Total Count At
AP</property>
</structure>
<structure>
<property name="name">Total Clients At Radio</property>
<property name="nativeName">Total Clients At
Radio</property>
</structure>
</list-property>
<property
name="queryText"> table0#-TNAME-#table0#:#[/REPORT/CLIENT-SUMMARY-BY-AP/SUMDET AIL/AP_SESSION_LOAD/RADIO_SESSION_LOAD/SSID_SESSION_LOAD]#:# {AP
Name;STRING;../../@name},{Radio;STRING;../@name},{SSID;STRIN G;/@name},{Total
Clients;INT;/@count},{Total Count At AP;INT;../../@count},{Total Clients
At Radio;INT;../@count}</property>
<model:DesignValues
<design:attributes>
<design:usageHints>
<design:attributes>
<design:name>Radio</design:name>
<design:usageHints>
<design:label>Radio</design:label>
<design:attributes>
<design:name>SSID</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>SSID</design:label>
<design:attributes>
<design:position>4</design:position>
<design:usageHints>
<ex-property>
<value>-1</value>
</ex-property>
<ex-property>
</ex-property>
</list-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab-cell" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="5">
</style>
<style name="table_header_row" id="169">
<property name="backgroundColor">#FFFF80</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="269"
extends="Test-Library.Simple MasterPage">
<property name="topMargin">0.25in</property>
<property name="leftMargin">1.25in</property>
<overridden-values>
<ref-entry baseId="7" id="7"/>
<ref-entry baseId="8" id="8"/>
<ref-entry baseId="9" id="9"/>
<ref-entry baseId="10" id="10"/>
<ref-entry baseId="11" id="11"/>
<ref-entry baseId="12" id="12"/>
<ref-entry baseId="19" name="NewLabel" id="19"/>
<ref-entry baseId="13" id="13"/>
<ref-entry baseId="14" id="14"/>
<ref-entry baseId="15" id="15"/>
<ref-entry baseId="16" id="16"/>
<ref-entry baseId="17" id="17"/>
<ref-entry baseId="18" id="18"/>
</overridden-values>
</simple-master-page>
</page-setup>
<body>
<grid id="152">
<property name="height">2.6875in</property>
<property name="width">5.989583333333333in</property>
<column id="153">
<property name="width">3.0208333333333335in</property>
</column>
<row id="156">
<cell id="157">
<property name="colSpan">1</property>
<property name="rowSpan">1</property>
<text id="170">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<CENTER><B><span style="font-size: larger">
Top APs
</B></span><BR>
<FONT size="small">Scope: Network Plan</FONT><BR><BR>
Report generated on <VALUE-OF>new Date( )</VALUE-OF>
</CENTER><BR><BR>]]></text-property>
</text>
</cell>
</row>
<row id="292">
<property name="height">0.3541666666666667in</property>
<cell id="293">
<label id="294">
<property name="fontWeight">bold</property>
<text-property name="text">Top APs</text-property>
</label>
</cell>
</row>
<row id="160">
<property name="height">2.6041666666666665in</property>
<cell id="161">
<table id="121">
<property name="fontSize">small</property>
<property
name="borderBottomColor">#000000</property>
<property name="borderLeftColor">black</property>
<property name="borderLeftWidth">thin</property>
<property
name="borderRightColor">#000000</property>
<property name="borderRightWidth">thin</property>
<property name="borderTopColor">#000000</property>
<property name="borderTopWidth">thin</property>
<property name="marginTop">0pt</property>
<property name="canShrink">true</property>
<property name="width">100%</property>
<property name="dataSet">Top APs Report: Top APs
Data Set</property>
<list-property name="boundDataColumns">
<structure>
Name</property>
<expression
name="expression">dataSetRow["AP Name"]</expression>
</structure>
<structure>
Clients</property>
Clients</property>
<expression
name="expression">dataSetRow["Total Clients"]</expression>
<property
</structure>
</list-property>
<property name="multiViews">
<multi-views id="137">
<property name="index">-1</property>
</multi-views>
</property>
<list-property name="sort">
<structure>
<expression name="key">row["Total
<property name="direction">desc</property>
</structure>
</list-property>
<column id="131"/>
<column id="132"/>
<header>
<row id="122">
<property name="height">24pt</property>
<property
name="style">table_header_row</property>
<cell id="123">
<label id="133">
<property
<property
name="textAlign">center</property>
<text-property name="text">AP
Name</text-property>
</label>
</cell>
<cell id="124">
<label id="134">
<property
<property
<text-property name="text">Total
Clients</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="125">
<cell id="126">
<data id="136">
<property
<property
name="resultSetColumn">AP Name</property>
<structure name="action">
<property
name="linkType">bookmark-link</property>
<property
name="toolTip">Navigate to the AP to see details.</property>
<expression
name="targetBookmark">row["AP Name"]</expression>
</structure>
</data>
</cell>
<cell id="127">
<data id="135">
<property
<property
name="resultSetColumn">Total Clients</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="128">
<cell id="129"/>
<cell id="130"/>
</row>
</footer>
</table>
<extended-item extensionName="Chart" name="NewChart"
id="151">
<xml-property
name="xmlRepresentation"><![CDATA[<model:ChartWithoutAxes
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:attribute="http://www.birt.eclipse.org/ChartModelAttribute"
xmlns:layout="http://www.birt.eclipse.org/ChartModelLayout"
xmlns:model="http://www.birt.eclipse.org/ChartModel"
xmlns:type="http://www.birt.eclipse.org/ChartModelType">
<Type>Pie Chart</Type>
<SubType>Standard</SubType>
<Description>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Description>
<Block>
<Children xsi:type="layout:TitleBlock">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
<Height>0.0</Height>
</Bounds>
<Anchor>South</Anchor>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Bottom>3.0</Bottom>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Rowspan>-1</Rowspan>
<Columnspan>-1</Columnspan>
<Outline>
<Style>Solid</Style>
<Thickness>1</Thickness>
<Color>
<Transparency>255</Transparency>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
<Visible>false</Visible>
</Outline>
<Visible>true</Visible>
<Label>
<Caption>
<Value></Value>
<Font>
<Size>16.0</Size>
<Bold>true</Bold>
<Alignment>
<horizontalAlignment>Center</horizontalAlignment>
<verticalAlignment>Center</verticalAlignment>
</Alignment>
</Font>
</Caption>
<Background xsi:type="attribute:ColorDefinition">
<Transparency>0</Transparency>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Bottom>0.0</Bottom>
<Right>3.0</Right>
</Insets>
</Label>
</Children>
<Children xsi:type="layout:Plot">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<HorizontalSpacing>5</HorizontalSpacing>
<VerticalSpacing>5</VerticalSpacing>
<ClientArea>
<Outline>
<Thickness>0</Thickness>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>0.0</Left>
<Right>0.0</Right>
</Insets>
</ClientArea>
</Children>
<Children xsi:type="layout:Legend">
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>0.0</Width>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<ClientArea>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>2.0</Top>
<Left>2.0</Left>
<Bottom>2.0</Bottom>
<Right>2.0</Right>
</Insets>
</ClientArea>
<Text>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Text>
<Orientation>Vertical</Orientation>
<Direction>Top_Bottom</Direction>
<Separator>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Separator>
<Position>Right</Position>
<ItemType>Categories</ItemType>
<Title>
<Caption>
<Value></Value>
<Font>
<Alignment/>
</Font>
</Caption>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Insets>
<Top>0.0</Top>
<Left>2.0</Left>
<Right>3.0</Right>
</Insets>
</Title>
<TitlePosition>Above</TitlePosition>
</Children>
<Bounds>
<Left>0.0</Left>
<Top>0.0</Top>
<Width>427.5</Width>
<Height>186.0</Height>
</Bounds>
<Insets>
<Top>3.0</Top>
<Left>3.0</Left>
<Right>3.0</Right>
</Insets>
<Row>-1</Row>
<Column>-1</Column>
<Outline>
<Color>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Color>
</Outline>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Background>
</Block>
<Dimension>Two_Dimensional</Dimension>
<Units>Points</Units>
<SeriesThickness>10.0</SeriesThickness>
<GridColumnCount>0</GridColumnCount>
<SampleData>
<BaseSampleData>
<DataSetRepresentation>'A','B','C','D','E'</DataSetRepresentation >
</BaseSampleData>
<OrthogonalSampleData>
<DataSetRepresentation>6,4,12,8,10</DataSetRepresentation>
<SeriesDefinitionIndex>0</SeriesDefinitionIndex>
</OrthogonalSampleData>
</SampleData>
<Interactivity>
<Enable>true</Enable>
<LegendBehavior>None</LegendBehavior>
</Interactivity>
<SeriesDefinitions>
<Query>
<Definition></Definition>
</Query>
<SeriesPalette>
<Entries xsi:type="attribute:ColorDefinition">
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
</Entries>
<Red>242</Red>
<Green>88</Green>
<Blue>106</Blue>
</Entries>
<Red>232</Red>
<Green>172</Green>
<Blue>57</Blue>
</Entries>
<Red>128</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>64</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>170</Red>
<Green>85</Green>
<Blue>85</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
<Red>192</Red>
<Green>192</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>192</Green>
<Blue>128</Blue>
</Entries>
<Red>7</Red>
<Green>146</Green>
<Blue>94</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>0</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>0</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>192</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>255</Blue>
</Entries>
<Red>128</Red>
<Green>64</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>80</Red>
<Green>240</Green>
<Blue>120</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>0</Green>
<Blue>64</Blue>
</Entries>
<Red>255</Red>
<Green>0</Green>
<Blue>128</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>64</Blue>
</Entries>
<Red>128</Red>
<Green>128</Green>
<Blue>128</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>255</Blue>
</Entries>
<Red>0</Red>
<Green>64</Green>
<Blue>0</Blue>
</Entries>
<Red>0</Red>
<Green>0</Green>
<Blue>0</Blue>
</Entries>
<Red>255</Red>
<Green>255</Green>
<Blue>255</Blue>
</Entries>
<Red>255</Red>
<Green>128</Green>
<Blue>0</Blue>
</Entries>
</SeriesPalette>
<SeriesDefinitions>
<Query>
</Query>
<SeriesPalette>
<Red>80</Red>
<Green>166</Green>
<Blue>218</Blue>
Re: AssertionError in ImageContent.getImageURI() on running RunAndRenderTask [message #468318 is a reply to message #454506] |
Wed, 05 August 2009 01:53 |
Velu,
If you remove the chart does it work?
Jason
> id="1">
> <structure>
> }</expression>
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> <parameters>
> <property
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <oda-data-source
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <ex-property>
> <value>-1</value>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <property
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <ex-property>
> <value>-1</value>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> Radio</property>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property name="nativeName">Total Count At AP</property>
> </structure>
> <structure>
> Radio</property>
> </structure>
> </list-property>
> <property
> <model:DesignValues
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <ex-property>
> <value>-1</value>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <overridden-values>
> </page-setup>
> <body>
> <grid id="152">
> <column id="153">
> </column>
> <row id="156">
> <cell id="157">
> <text id="170">
> <text-property
> Top APs
> </B></span><BR>
> </text>
> </cell>
> </row>
> <row id="292">
> <cell id="293">
> <label id="294">
> </label>
> </cell>
> </row>
> <row id="160">
> <cell id="161">
> <table id="121">
> <property
> <property name="borderRightColor">#000000</property>
> Data Set</property>
> <structure>
> Name</property>
> <expression
> </structure>
> <structure>
> Clients</property>
> Clients</property>
> <expression
> </structure>
> </list-property>
> </multi-views>
> </property>
> <structure>
> </structure>
> </list-property>
> <column id="131"/>
> <column id="132"/>
> <header>
> <row id="122">
> <property
> <cell id="123">
> <label id="133">
> <property
> <property
> </label>
> </cell>
> <cell id="124">
> <label id="134">
> <property
> <property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="125">
> <cell id="126">
> <data id="136">
> <property
> <property
> <property
> <property
> <expression
> </structure>
> </data>
> </cell>
> <cell id="127">
> <data id="135">
> <property
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="128">
> <cell id="129"/>
> <cell id="130"/>
> </row>
> </footer>
> </table>
> id="151">
> <xml-property
> <Description>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Description>
> <Block>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Label>
> <Caption>
> <Value></Value>
> <Font>
> <Size>16.0</Size>
> <Bold>true</Bold>
> <Alignment>
> </Alignment>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Label>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>0.0</Left>
> <Right>0.0</Right>
> </Insets>
> </ClientArea>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> <Width>0.0</Width>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <ClientArea>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>2.0</Top>
> <Left>2.0</Left>
> <Right>2.0</Right>
> </Insets>
> </ClientArea>
> <Text>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Text>
> <Separator>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Separator>
> <Title>
> <Caption>
> <Value></Value>
> <Font>
> <Alignment/>
> </Font>
> </Caption>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Insets>
> <Top>0.0</Top>
> <Left>2.0</Left>
> <Right>3.0</Right>
> </Insets>
> </Title>
> </Children>
> <Bounds>
> <Left>0.0</Left>
> <Top>0.0</Top>
> </Bounds>
> <Insets>
> <Top>3.0</Top>
> <Left>3.0</Left>
> <Right>3.0</Right>
> </Insets>
> <Row>-1</Row>
> <Column>-1</Column>
> <Outline>
> <Color>
> <Red>0</Red>
> <Green>0</Green>
> <Blue>0</Blue>
> </Color>
> </Outline>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Background>
> </Block>
> <SampleData>
> <BaseSampleData>
> </BaseSampleData>
> </SampleData>
> <Interactivity>
> </Interactivity>
> <SeriesDefinitions>
> <Query>
> </Query>
> <SeriesPalette>
> <Red>80</Red>
> <Green>166</Green>
> <Blue>218</Blue>
> </Entries>
> <Red>242</Red>
> <Green>88</Green>
> <Blue>106</Blue>
> </Entries>
> <Red>232</Red>
> <Green>172</Green>
> <Blue>57</Blue>
> </Entries>
> <Red>128</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>64</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>170</Red>
> <Green>85</Green>
> <Blue>85</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>0</Blue>
> </Entries>
> <Red>192</Red>
> <Green>192</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>255</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>128</Red>
> <Green>192</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>7</Red>
> <Green>146</Green>
> <Blue>94</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>0</Red>
> <Green>255</Green>
> <Blue>255</Blue>
> </Entries>
> <Red>255</Red>
> <Green>128</Green>
> <Blue>128</Blue>
> </Entries>
> <Red>0</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>128</Red>
> <Green>128</Green>
> <Blue>192</Blue>
> </Entries>
> <Red>255</Red>
> <Green>0</Green>
> <Blue>255</Blue>
> </Entries>
FUDForum. Page generated in 0.03251 seconds
