Re: disabled mylyn features [message #39928 is a reply to message #39806] |
Fri, 28 December 2007 01:18 |
Originally posted by: beatmik.acm.org
We have not encountered behavior of this sort before and and will need
more information to figure out what's going on. It would be best to
file a bug and include all of the features that you have installed, and
the precise Eclipse version. It sounds like there is something in the
dependency chain that's either failing or missing, so it would also be
helpful if you attached your <worskspace>/.metadata/.log file, ideally
containing only the entries after the first restart with -clean.
Mik
M;chi wrote:
> Hi everyone,
> I'm having the situation whenever I start eclipse with -clean all the
> features of the mylyn package have been disabled. I then have to enable
> them manually, which actually works but still it's quite annoying.
> Does anybody know where that behaviour stems from, because I've observed
> this with a few other plugins as well.
> Thanks for any help
> bye M;chi
Re: disabled mylyn features [message #40201 is a reply to message #40113] |
Mon, 31 December 2007 22:42 |
Originally posted by: dcarver.starstandard.org
M;chi wrote:
> Just in case anybody is interested in the solution. Eclipse can't load
> jarred features, which happened when I just unzipped the plugin package
> into my extension location.
Yep. They need to have the features jarred for correct download when
not going through an update site. This requires a different setting on
the feature packaging when exporting the feature in PDE.
Re: disabled mylyn features [message #586519 is a reply to message #40113] |
FUDForum. Page generated in 0.03234 seconds
