Home » Eclipse Projects » Eclipse Platform » Not found localfile_1_0_0 on AIX
Not found localfile_1_0_0 on AIX [message #337041] Thu, 23 July 2009 06:59 Go to next message
nma is currently offline nma
There is an Eclipse RCP project developed by sun jdk, and when running on
AIX, bug happened.
!ENTRY org.eclipse.core.filesystem 1 1 2009-07-07 03:36:32.194
!MESSAGE Could not load library: liblocalfile_1_0_0.a. This library
provides platform-specific optimizations for certain file system
operations. This library is not present on all platforms, so this may not
be an error. The resources plug-in will safely fall back to using
java.io.File functionality.
!STACK 0
java.lang.UnsatisfiedLinkError: localfile_1_0_0 (Not found in
java.library.path)
at java.lang.ClassLoader.loadLibraryWithPath(ClassLoa der.java:979)
at java.lang.ClassLoader.loadLibraryWithClassLoader(C lassLoader.java:948)
at java.lang.System.loadLibrary(System.java:453)
at org.eclipse.core.internal.filesystem.local.LocalFi
leNatives.<clinit>(LocalFileNatives.java:32)
at java.lang.J9VMInternals.initializeImpl(Native Method)
at java.lang.J9VMInternals.initialize(J9VMInternals.j ava:194)
le.fetchInfo(LocalFile.java:141)
at org.eclipse.core.filesystem.provider.FileStore.fet
chInfo(FileStore.java:277)
at org.eclipse.core.internal.localstore.BlobStore.<in
it>(BlobStore.java:45)
at org.eclipse.core.internal.localstore.HistoryStore2
<init>(HistoryStore2.java:77)
at org.eclipse.core.internal.resources.ResourcesCompa
tibility.createHistoryStore(ResourcesCompatibility .java:45)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native
MethodAccessorImpl.java:79)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De
legatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:618)
tibilityHelper.createHistoryStore(ResourcesCompati bilityHelper.java:73)
tibilityHelper.createHistoryStore(ResourcesCompati bilityHelper.java:47)
at org.eclipse.core.internal.localstore.FileSystemRes
ourceManager.getHistoryStore(FileSystemResourceMan ager.java:338)
at org.eclipse.core.internal.resources.SaveManager.sa
ve(SaveManager.java:1012)
at org.eclipse.core.internal.resources.Workspace.save (Workspace.java:1827)
at org.talend.commandline.CommandLineApplication.star t(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.
run(EclipseAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseA
ppLauncher.runApplication(EclipseAppLauncher.java: 110)
ppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.ru
n(EclipseStarter.java:382)
n(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework( Main.java:549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.ja va:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:12 36)
at org.eclipse.equinox.launcher.Main.main(Main.java:1 212)
Re: Not found localfile_1_0_0 on AIX [message #337086 is a reply to message #337041] Mon, 27 July 2009 09:47 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
This happens on a few platforms, including AIX, where the localfile_1_0_0
library is not included. Though I'm not sure exactly which IO functionality
is unavailable in the absence of this library, it cannot be anything
significant, otherwise this library would be included.
Grant
"nma " <maning915@gmail.com> wrote in message
news:296e6bc1b18341d21d2b6ddafa6d7d53$1@www.eclipse.org...
> AIX, bug happened.
> !STACK 0
> java.library.path)
Re: Not found localfile_1_0_0 on AIX [message #343008 is a reply to message #337086] Tue, 28 July 2009 02:03 Go to previous messageGo to next message
Grant, it's very kind-hearted of you to reply.
The problem still have not been fixed. Could you tell me what should I go
on to do to fix this problem, or do which test to try to see the problem ?
Thanks very much for your help.
nma
Re: Not found localfile_1_0_0 on AIX [message #361996 is a reply to message #343008] Tue, 28 July 2009 09:55 Go to previous messageGo to next message
What I'm saying is, this is expected behaviour on AIX, there is no fix
required on your end. Part of the warning message reads "This library is
not present on all platforms, so this may not be an error." This has been
logged as https://bugs.eclipse.org/bugs/show_bug.cgi?id=176470 . If you
want to know of future progress on this then you should CC yourself to this
bug's resolved duplicate bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=12358 .
Is this causing you an actual loss of functionality?
Grant
news:88407d3779ba36d18a1bdf6f9d87eb22$1@www.eclipse.org...
> nma
Re: Not found localfile_1_0_0 on AIX [message #370343 is a reply to message #361996] Tue, 28 July 2009 21:43 Go to previous messageGo to next message
Yes, this problem is quite serious for me, as after this exception
happened, it seemed that my product did not fall back to use java.io.File
behaviour but exited.
Thx.
nma.
Re: Not found localfile_1_0_0 on AIX [message #371008 is a reply to message #361996] Wed, 29 July 2009 00:01 Go to previous messageGo to next message
We will have a try to bulid the localfile for AIX using GCC by ourself.
Hope it can solve the problem.
nma
Re: Not found localfile_1_0_0 on AIX [message #427810 is a reply to message #370343] Thu, 30 July 2009 10:11 Go to previous message
Perhaps you should ping the bug report and indicate that it's actually
causing a problem for you that's worse than just a warning message.
Grant
news:793ba1fe39f6c07cb844568edda9e2f9$1@www.eclipse.org...
> Thx.
> nma.
Previous Topic:JFaceResources and button labels
Next Topic:Can't open classes via Plugin Spy anymore :(
Current Time: Tue May 21 11:27:42 EDT 2013
Powered by FUDForum. Page generated in 0.02501 seconds
