Migration from Polarion version to Eclipse version fails with Eclipse 3.3 [message #31778] |
Wed, 13 August 2008 12:10  |
I'm still using Eclipse 3.3 and wanted to upgrade Subversive from the
Polarion version (SVN Team Provider 1.1.9.02) to the most current Eclipse
version (Subversive SVN Team Provider 0.7.3). I followed the migration
instructions
http://www.eclipse.org/subversive/documentation/gettingStart ed/aboutSubversive/update_polarion.php
and did the following steps in this order:
1.) Install Subversive SVN Team Provider 0.7.3 via archived update site
downloaded from
http://www.eclipse.org/downloads/download.php?file=/technolo gy/subversive/0.7/builds/Subversive-incubation-0.7.3.I200808 14-1500.zip
Note that the Polarion version was not uninstalled (as the instructions
document indicates).
2.) Restart Eclipse and try to click 'Help > Subversive > Migrate Projects
and Settings'. The result is that a dialog window pops up saying "The chosen
operation is not currently available". In the error log appears a new event
and stack trace as appended at the end of this message.
I also tried to disable the Polarion version (including all its
dependencies), restart Eclipse, and try the same action. The effect is the
same.
Any hints what I can do now?
Best,
Thorsten
Error
Wed Aug 13 17:24:35 CEST 2008
Plug-in org.eclipse.team.svn.ui was unable to load class
org.eclipse.team.svn.ui.debugmail.MigrateToEclipse.
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
An error occurred while automatically activating bundle
org.eclipse.team.svn.ui (628).
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.team.svn.mylyn.SVNActiveChangeSetProvider.getAct iveChangeSetManager(SVNActiveChangeSetProvider.java:25)
org.eclipse.mylyn.internal.team.ui.FocusedTeamUiPlugin.addAc tiveChangeSetProvider(FocusedTeamUiPlugin.java:124)
org.eclipse.mylyn.internal.team.ui.FocusedTeamExtensionPoint Reader.readExtensions(FocusedTeamExtensionPointReader.java:5 0)
org.eclipse.mylyn.internal.team.ui.FocusedTeamUiPlugin$1.run (FocusedTeamUiPlugin.java:77)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:129)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Caused by: org.osgi.framework.BundleException: The activator
org.eclipse.team.svn.ui.SVNTeamUIPlugin for bundle org.eclipse.team.svn.ui
is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
... 38 more
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/team/svn/core/operation/IActionOperation
at org.eclipse.team.svn.ui.SVNTeamUIPlugin.<init>(SVNTeamUIPlugin.java:54)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknow n Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Un known
Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:136)
... 43 more
Caused by:
org.eclipse.team.svn.core (624).
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.team.core.RepositoryProvider.newProvider(Reposit oryProvider.java:706)
org.eclipse.team.core.RepositoryProvider.mapNewProvider(Repo sitoryProvider.java:162)
org.eclipse.team.core.RepositoryProvider.mapExistingProvider (RepositoryProvider.java:235)
org.eclipse.team.core.RepositoryProvider.getProvider(Reposit oryProvider.java:577)
org.eclipse.team.svn.ui.decorator.wrapper.AbstractDecoratorW rapper.isSVNShared(AbstractDecoratorWrapper.java:39)
org.eclipse.team.svn.ui.decorator.wrapper.ProjectDecoratorWr apper.decorate(ProjectDecoratorWrapper.java:27)
org.eclipse.ui.internal.decorators.LightweightDecoratorDefin ition.decorate(LightweightDecoratorDefinition.java:253)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er$LightweightRunnable.run(LightweightDecoratorManager.java: 71)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.decorate(LightweightDecoratorManager.java:336)
org.eclipse.ui.internal.decorators.LightweightDecoratorManag er.getDecorations(LightweightDecoratorManager.java:322)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.ens ureResultCached(DecorationScheduler.java:369)
org.eclipse.ui.internal.decorators.DecorationScheduler$1.run (DecorationScheduler.java:329)
Caused by: org.osgi.framework.BundleException: Exception in
org.eclipse.team.svn.core.SVNTeamPlugin.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1018)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
... 30 more
Caused by: java.io.StreamCorruptedException: invalid type code: 00
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
org.eclipse.team.svn.core.svnstorage.AbstractSVNStorage.load LocationsFromFile(AbstractSVNStorage.java:548)
org.eclipse.team.svn.core.svnstorage.AbstractSVNStorage.init ializeImpl(AbstractSVNStorage.java:402)
org.eclipse.team.svn.core.svnstorage.SVNRemoteStorage.initia lize(SVNRemoteStorage.java:163)
at org.eclipse.team.svn.core.SVNTeamPlugin.start(SVNTeamPlugin. java:154)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 35 more
FUDForum. Page generated in 0.03638 seconds
