Topic |
Replies |
Views |
Last message |
Push with: git push --force-with-lease Include in the function Branch Push the option to force the push only if the local repository is updated. This is done with the command: git push --force-with-lease |
0 |
10118 |
Fri, 13 November 2015 15:20 By: Adriano Demetrio |
does prepare-commit-msg work? It seems pre-commit hook works but I have a problem with commit message |
4 |
3669 |
Tue, 10 November 2015 08:50 By: Ewelina Wilkosz |
MAMP directory deleted on commit Added existing eclipse workspace to git and everything got moved |
2 |
3181 |
Tue, 10 November 2015 07:35 By: Shawn Fuller |
Latest EGit in Luna doesn't show filenames in commit dialog |
7 |
6967 |
Mon, 09 November 2015 19:49 By: Mark Lehky |
Git Staging view enhancements to contribute |
3 |
12317 |
Mon, 09 November 2015 10:16 By: Matthias Sohn |
jgit-cli: "log <file>" -- failed: <file> is not a commit jgit-cli: "log <file>" -- failed: <file> is not a commit |
2 |
2074 |
Fri, 06 November 2015 09:39 By: Anselm D. |
EGit says files are dirty but Git says working directory is clean |
9 |
16287 |
Thu, 05 November 2015 22:10 By: Matthias Sohn |
jgit: mvn clean install (windows 7) / core tests failed jgit: mvn clean install (windows 7) / core tests failed |
3 |
2888 |
Thu, 05 November 2015 12:36 By: Anselm D. |
Eclipse EGit "Team->Switch To" menu is empty |
3 |
2082 |
Tue, 03 November 2015 11:53 By: Patrick Gillespie |
AccessControlException for .gitconfig file By: Matt C. on Thu, 15 October 2015 |
1 |
3861 |
Mon, 02 November 2015 20:14 By: Matthias Sohn |
[RESOLVED] Can't install EGit plugin on Eclipse Luna Trying to install the EGit plugin from marketplace or install new software doesn't work. Label decorations not showing, and can't compare with commit. |
4 |
6314 |
Mon, 02 November 2015 20:11 By: Matthias Sohn |
Your branch is ahead of 'origin/master' by X commits. |
1 |
6682 |
Mon, 02 November 2015 20:07 By: Matthias Sohn |
A library that wraps around JGit this will certainly help you if you are dealing with bare repository |
0 |
4454 |
Mon, 02 November 2015 12:05 By: Junyi Bei |
JGit ListBranchCommand with contains does not close RevWalk |
2 |
2166 |
Mon, 02 November 2015 11:47 By: Junyi Bei |
JGit blame ignore whitespace |
1 |
3757 |
Mon, 02 November 2015 11:36 By: Junyi Bei |
Rename error when pull |
2 |
8743 |
Sun, 01 November 2015 14:06 By: Mattias Andersson |
EGit exceptions and repository state |
2 |
1631 |
Wed, 28 October 2015 07:54 By: Mattias Andersson |
using native git not jgit in Eclipse git? |
3 |
3060 |
Sat, 17 October 2015 04:54 By: Ed Merks |
Jgit SSH problem on IBM OS/390 arch system Cannot clone a remote git repository with SSH protocol on IBM OS/390 system. Caused by: com.jcraft.jsch.JSchException: Auth fail |
2 |
3402 |
Thu, 15 October 2015 14:47 By: Matthias Sohn |
Git History Bug, file level only from Project Explorer |
1 |
3274 |
Thu, 15 October 2015 13:38 By: Matthias Sohn |
Installed EGit, but not showing up Installed EGit, but not showing up |
7 |
23810 |
Tue, 13 October 2015 17:26 By: Mario Mario |
MAMP disapeared after adding project to Git How to get the MAMP directory back |
0 |
2330 |
Sat, 10 October 2015 04:29 By: Shawn Fuller |
Filter a specific commit tree using RevWalk / TreeWalk fllter Customize RevWalk and TreeWalk filters |
4 |
4009 |
Wed, 07 October 2015 18:49 By: David Bekel |
eGit missing when using Websphere 8 Java runtime |
0 |
3984 |
Mon, 05 October 2015 16:20 By: Raymond Lee |
EGit needs --NOfollow option |
0 |
3962 |
Mon, 05 October 2015 12:48 By: Anthony Mising name |
how to set the system wide gitconfig(windows msysgit 2.5.3 64bit) |
1 |
3184 |
Thu, 24 September 2015 15:02 By: Matthias Sohn |
How to Synchronize and Commit from the root project? EGit submodule |
0 |
4701 |
Thu, 24 September 2015 10:43 By: mgiaco Mising name |
Eclipse and Egit : Remote Push is blocked |
4 |
4836 |
Wed, 23 September 2015 09:51 By: Matthias Sohn |
Why is Eclipse deleting the CVS directories from my Git cloned repo? |
7 |
3275 |
Wed, 23 September 2015 09:47 By: Matthias Sohn |
Git Conflict issue Conflict status is not removing after synchronize and mark as merge |
0 |
4336 |
Tue, 22 September 2015 14:58 By: siva kumar lankada |
JGit method to retrieve "Your branch is ahead of 'origin/master' by 2 commits."? I'd like to show the info that git status returns regarding commits behind the origin repo. |
1 |
6044 |
Fri, 18 September 2015 09:00 By: Rüdiger Herrmann |
Branch switching: closed projects After switching the branch, branch specific projects are closed |
2 |
10245 |
Thu, 17 September 2015 12:00 By: carlo luib-finetti |
git worktree support ? |
3 |
9108 |
Tue, 15 September 2015 15:59 By: Benjamin Waehner |
[RESOLVED] Git options are enabled for "Team" submenu, but DISabled for Git 'top-menu'? |
6 |
3576 |
Tue, 08 September 2015 23:54 By: John Adev |
Git command equivalent in JGit (diff & Show) |
2 |
1881 |
Tue, 08 September 2015 13:51 By: Matthias Sohn |
EGit not remembering SSH passphrase |
1 |
3289 |
Tue, 08 September 2015 13:46 By: Matthias Sohn |
(someclass).getResourceAsStream is not working with egit. |
1 |
8923 |
Tue, 08 September 2015 13:33 By: Matthias Sohn |
Egit error Cast ssl Egit error Cast ssl |
2 |
5097 |
Mon, 07 September 2015 12:37 By: Sundar Rajan |
JGit low level subtree merge (?) By: NOX L. on Tue, 25 August 2015 |
0 |
4347 |
Tue, 25 August 2015 08:18 By: NOX L. |
Projects duplicate with Git Submodules A question about how to use EGit Submodules feature |
2 |
2768 |
Thu, 20 August 2015 06:33 By: Lake Fu |
Not Able to add new index file |
1 |
1721 |
Thu, 06 August 2015 10:02 By: Christian Halstrick |
Binary files differ: Cannot diff UTF16 files in GIT history Git history trouble with UTF16 encoded files |
1 |
2436 |
Sun, 02 August 2015 11:34 By: Christian Halstrick |
List conflicts prior to pull or merge Check wether a file will be in conflict state if a pull command is performed |
2 |
4837 |
Fri, 31 July 2015 22:06 By: David Bekel |
InternalException: combination of --all and --only not allowed error in basic functionality |
11 |
6564 |
Fri, 31 July 2015 15:29 By: René Jansen |
committing single files with jgit/API command line function not implemented ? |
1 |
1747 |
Wed, 29 July 2015 08:16 By: Christian Halstrick |
NPE on checkout if there are two branches on the commit |
1 |
1884 |
Thu, 23 July 2015 22:41 By: Matthias Sohn |
How to clone a single branch in JGit |
11 |
14713 |
Thu, 23 July 2015 18:33 By: Julian Enoch |
cannot open git-receive-pack: Server redirected too many times (20) |
2 |
10167 |
Tue, 21 July 2015 20:49 By: Sam Davis |
Files in package explorer, Commit works error when pushing Egit problems in Mars |
1 |
2032 |
Tue, 21 July 2015 16:06 By: Matthias Sohn |
Simultaneously pulling repositories |
1 |
931 |
Tue, 21 July 2015 16:03 By: Matthias Sohn |
can't enter username |
4 |
1845 |
Tue, 14 July 2015 07:42 By: Jan Marti |
Shallow Clones Does jgit support shallow clones? |
1 |
2582 |
Mon, 13 July 2015 15:23 By: Christian Halstrick |
Eclipse EGit Plugin does not allow to save username & password |
0 |
1944 |
Mon, 13 July 2015 09:44 By: Jan Marti |
How to run source code of EGit ? |
1 |
2329 |
Sun, 12 July 2015 13:37 By: Peter Karena |
Wrong working directory? Incorrect files appearing in Git Staging View |
5 |
5040 |
Sun, 12 July 2015 06:45 By: Sean Thomas |
A orion plugin to enable a private git repository |
1 |
1381 |
Wed, 01 July 2015 22:36 By: Matthias Sohn |
Project layout to avoid full rebuild after switching branches Looking for a way to avoid a full rebuild after switching branches, probably with a new project layout. |
0 |
2059 |
Mon, 29 June 2015 22:38 By: Angelo Andrade Cirino |
Resolve conflict without changes Resolve conflict without changes |
1 |
2629 |
Mon, 29 June 2015 14:40 By: Fábio Silva |
Commit compare layout issues Team/Commit/Compare with head layout issues |
2 |
2641 |
Fri, 26 June 2015 20:01 By: Andrey Loskutov |
EGit and Mars Team > Commit |
1 |
2334 |
Fri, 26 June 2015 19:55 By: Andrey Loskutov |
Garbage collection concurrency with ref update |
3 |
3374 |
Wed, 24 June 2015 10:50 By: Christian Halstrick |
EGit Work on a Branch, Commit, Switch and Pull remote master Suggestion on EGit Workflow for Eclipse Contributors: how to work on Branch, Commit, Switch and Pull remote master |
2 |
2375 |
Mon, 22 June 2015 15:45 By: Patrik Suzzi |
Missing history By: Jason D on Sat, 17 January 2015 |
5 |
5035 |
Wed, 17 June 2015 16:46 By: Jason D |
Create custom actions |
0 |
2127 |
Wed, 17 June 2015 12:36 By: Csaba Debreceni |
build path "no actions available" build path "no actions available" |
0 |
4693 |
Mon, 15 June 2015 08:26 By: Verena Berg |
Need help with JGit API and symbolic links |
2 |
1854 |
Sat, 13 June 2015 12:04 By: Jason Brown |
HELP WITH EGIT |
0 |
2811 |
Wed, 10 June 2015 09:08 By: Francesco Primerano |
upon import, project not connected to git |
3 |
2207 |
Tue, 09 June 2015 22:31 By: Matthias Sohn |
Maven using JGit to release project within Eclipse -JGit status failure! |
1 |
3006 |
Tue, 09 June 2015 22:26 By: Matthias Sohn |
windows: git over plink just not working trying to get a connection to github over plink makes eclipse hang / nothing helps except killing process over task manager |
4 |
6113 |
Mon, 01 June 2015 21:55 By: Matthias Sohn |
How to import sources from local repository into GitHub ? |
3 |
2703 |
Mon, 01 June 2015 21:53 By: Matthias Sohn |
Git.lsRemoteRepository().call() throws NullPointerException in case of Dumb Http |
1 |
1991 |
Mon, 01 June 2015 21:49 By: Matthias Sohn |
Project is forgetting it's tied to a EGIT repo After eclipse restarts it no longer is associated with the egit repository |
1 |
1969 |
Mon, 01 June 2015 21:42 By: Matthias Sohn |
Duplicate RevCommits in RevWalk |
0 |
2025 |
Tue, 26 May 2015 11:53 By: Ruici Luo |
[Solved] Clone submodules in JGit Prerequisites? Add submodules to existing clone? |
6 |
6557 |
Thu, 21 May 2015 15:49 By: Julian Enoch |
Diff/Comparison from history for moved files does not work |
3 |
4789 |
Wed, 13 May 2015 10:43 By: Patrick Peer |
JGit requires bash? |
3 |
12448 |
Tue, 12 May 2015 08:56 By: Matthias Sohn |
Can't push project to GitHub |
15 |
35947 |
Tue, 12 May 2015 08:29 By: Matthias Sohn |
EGit Working on Bug - pull Gerrit review Help to pull a Gerrit review from remote to a local branch. |
2 |
2224 |
Fri, 08 May 2015 18:29 By: Patrik Suzzi |
Finding a merge commit with JGit |
0 |
3069 |
Wed, 06 May 2015 20:45 By: Chris Conroy |
Commiting project Committing project to git picks up previous project's working directory |
1 |
2288 |
Mon, 04 May 2015 06:45 By: Christian Halstrick |
Jgit diff and triple dot Listing remote changes using jgit |
4 |
3622 |
Wed, 22 April 2015 12:58 By: Fábio Silva |
Remote Tracking - new branches Fetching Remote Branches |
3 |
7070 |
Fri, 17 April 2015 07:43 By: Matthias Sohn |
Luna 4.4.2 + JDK 8 : cannot open git-upload-pack |
2 |
11239 |
Fri, 17 April 2015 07:38 By: Matthias Sohn |
Can't add Copy-Pasted file to index |
6 |
7757 |
Mon, 13 April 2015 06:19 By: Matthias Sohn |
Confused newbie Can't verify repo contents |
4 |
2712 |
Sun, 12 April 2015 20:54 By: Richard Wyant |
Need help getting started with JGit Documentation does not seem to pertain to my situation |
1 |
3164 |
Fri, 10 April 2015 11:13 By: Christian Halstrick |
Import function: Git option not available EGIT is installed but there is no Git feature when you try to import a file or project |
1 |
5081 |
Fri, 10 April 2015 10:42 By: Christian Halstrick |
Compare versions of a file before merging How to see the changes in a file side by side |
2 |
2380 |
Fri, 10 April 2015 10:18 By: Christian Halstrick |
Egit shows differences that don't exist |
1 |
3071 |
Thu, 09 April 2015 15:47 By: Roberto Cappa |
Just do a simple merge How to use the merge command to merge two files |
1 |
3402 |
Thu, 09 April 2015 15:41 By: Christian Halstrick |
EGit doesn't understand two consecutive asterisks in gitignore file |
1 |
1439 |
Mon, 06 April 2015 12:47 By: Andrey Loskutov |
Eclipse does not seem to recognize ecdsa-sha2-nistp256 fingerprint Eclipse EGit gets stuck at fetch/push to remote due to figerprint for git server is not known. |
2 |
11798 |
Tue, 31 March 2015 09:48 By: Gunnar Wagenknecht |
Problems starting with EGit development |
5 |
2707 |
Fri, 27 March 2015 14:04 By: Ulrich Wielant |
Ref HEAD can not be resolved |
2 |
10271 |
Thu, 26 March 2015 15:42 By: Derrick McKee |
JGit clone fails with "Auth fail" jgit fails to clone from GitHub via SSH, where git CLI succeeds. |
6 |
9927 |
Wed, 25 March 2015 15:18 By: Winston Prakash |
Repository for multiple projects Ho can I create a repository for an application consisting of 4 projects (EAR+EJB+EJB+JPA)? |
2 |
3799 |
Wed, 25 March 2015 01:26 By: Luigi Cortese |
How to push a specific commit to a remote repo |
1 |
2184 |
Fri, 20 March 2015 15:49 By: Christian Halstrick |
jgit credential helper? |
2 |
3633 |
Wed, 18 March 2015 01:14 By: Shaun Mising name |
EGit Deleted My Project! TITLE SAYS ALL |
1 |
2169 |
Tue, 17 March 2015 07:18 By: Matthias Sohn |
Prevent .gitignore from being modified automatically |
2 |
4449 |
Mon, 16 March 2015 17:15 By: Eike Stepper |
# WARNING: head commit changed in the meantime # WARNING: head commit changed in the meantime |
1 |
27719 |
Mon, 09 March 2015 09:44 By: Christian Halstrick |
[SEMISOLVED] Missing tree/blob, Gerrit and EMF |
6 |
8050 |
Fri, 06 March 2015 14:47 By: Matthias Sohn |
What part of updates do I need to install? By: Eclipse User on Fri, 06 March 2015 |
1 |
1424 |
Fri, 06 March 2015 14:20 By: Matthias Sohn |
Show Annotations does not work anymore |
5 |
5747 |
Thu, 26 February 2015 07:55 By: Eike Stepper |
Indexing gen folder |
3 |
1537 |
Wed, 25 February 2015 20:12 By: Matthias Sohn |
Delete Local Branch |
1 |
11101 |
Wed, 25 February 2015 20:08 By: Matthias Sohn |
Pushing to a repository with EGit not working when it works with command-line git Pushing to Google cloud repository not working with EGit when it works with command-line client |
3 |
2207 |
Wed, 25 February 2015 13:46 By: Matthias Sohn |
Subtree - see file history of remotes |
4 |
6327 |
Sun, 22 February 2015 16:10 By: Marek Jagielski |
Having a problem installing PlugIn Error message from Eclipse |
1 |
3473 |
Thu, 19 February 2015 20:08 By: Matthias Sohn |
jgit: glog how to keep branches in the same lane |
0 |
2041 |
Thu, 19 February 2015 16:14 By: Martin d\'Anjou |
Fetching on a bare repo |
4 |
2713 |
Thu, 19 February 2015 08:51 By: Giovanni J |
Git Pull introduces unstaged changes GIT pull from the remote origin introduces unstaged changes in files which i did not modified |
1 |
4107 |
Wed, 18 February 2015 22:00 By: Matthias Sohn |
Remove project from EGIT How to put a project back to normal workspace |
4 |
2734 |
Wed, 18 February 2015 21:49 By: Matthias Sohn |
JGIt: pulling across directories. How to for file system operations. |
2 |
2751 |
Mon, 16 February 2015 12:31 By: Pete Kowalsky |
See the git commands that are executed by the EGit GUI? I'd like to learn the git CLI while using EGit |
1 |
1997 |
Fri, 06 February 2015 07:32 By: Matthias Sohn |
egit ssh failure |
3 |
9875 |
Sat, 31 January 2015 18:56 By: Fabio Almeida |
is there any way to pull a subdirectory from a git repo using jGit |
2 |
6356 |
Tue, 27 January 2015 02:28 By: rupert THURNER |
Java Project Git Tag Changed From master to NO-HEAD eGit status has changed from master to NO-HEAD |
3 |
12230 |
Tue, 27 January 2015 00:25 By: Ron Westfall |
Unable to upgrade Eclipse Luna due to missing repositories |
3 |
16665 |
Sun, 25 January 2015 02:40 By: x t |
egit fails to ask for password |
2 |
5790 |
Sat, 24 January 2015 12:43 By: Mark Winterbottom |
Pushing, auth fail Suddenly can't push to github |
5 |
18708 |
Sat, 24 January 2015 12:41 By: Mark Winterbottom |
EGit removing stale branches? By: na na on Mon, 04 November 2013 |
4 |
7122 |
Thu, 22 January 2015 22:41 By: Matthias Sohn |
Saving in merge tool causes endless blocking |
3 |
4245 |
Thu, 22 January 2015 22:37 By: Matthias Sohn |
How to upgrade EGit ? |
3 |
2374 |
Thu, 22 January 2015 22:36 By: Matthias Sohn |
can NOT install EGit because of m2e - Maven |
1 |
5715 |
Thu, 22 January 2015 22:31 By: Matthias Sohn |
I'm having problems with CommitTimeRevFilter |
0 |
3468 |
Wed, 21 January 2015 18:18 By: Kevin North |
"Replace with Index" and "Replace with HEAD" in Staging view do nothing |
3 |
7907 |
Thu, 15 January 2015 12:55 By: Juan Cadavid |
insert git head into code |
1 |
1648 |
Thu, 15 January 2015 12:28 By: Matthias Sohn |
security-fix for CVE-2014-9390 How do we upgrade or patch Egit for the Git Vunerability |
8 |
4288 |
Thu, 15 January 2015 12:22 By: Matthias Sohn |
How to avoid eclipse setting files while git rebase? How to avoid eclipse setting files while git rebase? |
1 |
3896 |
Thu, 15 January 2015 12:19 By: Matthias Sohn |
import from git...project not working anymore |
1 |
4625 |
Thu, 15 January 2015 12:11 By: Matthias Sohn |
S3 Jgit IAM Credentials |
1 |
4012 |
Wed, 14 January 2015 17:24 By: Jesse Peters |
JGit push with --set-upstream how push a branch to a remote and add upstream (-u option on push command) |
1 |
2604 |
Fri, 09 January 2015 05:34 By: Eike Stepper |
jgit fetch LOCK_FAILURE jgit fetch fails on alternate calls with a lock failure |
1 |
2771 |
Wed, 07 January 2015 07:31 By: Christian Halstrick |
Setting up classpath for source control |
1 |
4552 |
Tue, 30 December 2014 23:47 By: Matthias Sohn |
unable to push sources to JGit in Gerrit Invalid tree a33cf05e7a: duplicate entry names |
1 |
4342 |
Thu, 25 December 2014 23:46 By: Roman Shiryaev |
TeamProjectSet repository-folder TeamProjectSet repository-folder does not honor Default-Repository folder |
1 |
1543 |
Thu, 11 December 2014 12:00 By: Ed Merks |
TeamProjectSet Export cannot export a checked out tag |
0 |
3139 |
Thu, 11 December 2014 11:50 By: kurt Mising name |
WWW-Authenticate: NTLM By: ms ms on Tue, 19 November 2013 |
3 |
11579 |
Fri, 21 November 2014 08:42 By: Petr Dousa |
Secure Reference (CMAC instead of HMAC)? is it possible to encrypt object id's and not break jgit or git ? |
1 |
3436 |
Thu, 20 November 2014 11:52 By: Matthias Sohn |
E git plugin not automatically recognizing git projects when imported as a general project e git plugin does not recognize the project as a git project |
1 |
2664 |
Thu, 20 November 2014 10:06 By: Matthias Sohn |
Using local repository as shared repository |
0 |
5214 |
Mon, 17 November 2014 12:58 By: Deepak Senapati |
Abort merge of a single/multiple file(s) with EGit? |
2 |
3666 |
Sat, 15 November 2014 09:24 By: Lukasz T. |
Does Egit rumtime override the settings in the plugin.xml? Does Egit rumtime override the settings in the plugin.xml? |
1 |
4104 |
Fri, 14 November 2014 19:24 By: Stefan Lay |
When is the staging view updated? |
3 |
6415 |
Wed, 12 November 2014 22:34 By: Matthias Sohn |
SOLVED: Eclipse keeps asking for passphrase (even when entered) |
3 |
6353 |
Thu, 06 November 2014 14:06 By: Matthias Sohn |
Working with git clone but on remote server Desktop connects via ssh to remote server with git clones - Using these git clones for development |
7 |
5520 |
Thu, 06 November 2014 14:03 By: Matthias Sohn |
Error validating settings: Not Found |
1 |
2356 |
Wed, 05 November 2014 19:40 By: Michael Remijan |
Amazon S3 Object Interaction How to seamlessly upload repository objects to AmazonS3 |
3 |
4033 |
Tue, 04 November 2014 12:27 By: Matthias Sohn |
JGit HTTPS cloning is not working JGit HTTPS cloning is not working |
6 |
26595 |
Tue, 04 November 2014 12:26 By: Matthias Sohn |
Use git repository directly from remote server |
1 |
2039 |
Tue, 04 November 2014 12:23 By: Matthias Sohn |
Push/Fetch |
1 |
1466 |
Tue, 04 November 2014 12:18 By: Matthias Sohn |
Renaming Eclipse project didn't rename folder in local git repo |
6 |
20728 |
Fri, 31 October 2014 22:33 By: Robin Rosenberg |
Synchronize Bitbucket with Eclipse |
2 |
3146 |
Thu, 30 October 2014 13:52 By: Haekkadi Haekkadi |
BundleWriter.include - Invalid ref name: HEAD BundleWriter fails to include all Refs from a repository. By: Nick L on Fri, 10 October 2014 |
1 |
4047 |
Wed, 29 October 2014 23:01 By: Matthias Sohn |
Looking for a way to auto-fetch or auto-synchronize all repositories used in workspace upon opening |
4 |
3519 |
Wed, 29 October 2014 22:54 By: Matthias Sohn |
First changed file missing from commit window |
1 |
6020 |
Wed, 29 October 2014 22:41 By: Matthias Sohn |
Websphere Integration Developer 6.1.2 cannot install EGit |
1 |
2263 |
Wed, 29 October 2014 22:39 By: Matthias Sohn |
How clone a repository containing symlinks symlink jgit |
4 |
1849 |
Wed, 29 October 2014 11:04 By: paolo di tommaso |
Is jgit a client or repository? |
1 |
1426 |
Fri, 24 October 2014 22:45 By: Robin Rosenberg |
Does EGit 3.4.1 supports SSLv3 or TLS? Problem clonning repositories |
0 |
8691 |
Fri, 24 October 2014 18:38 By: César Iván Orozco Cervantes |
Performance bad, possible to use native git? EGit / JGit bad performance |
5 |
4672 |
Tue, 21 October 2014 13:13 By: Rüdiger Herrmann |
How to call share Project command from my plugin java code I am trying to call egit share project command Team->Share Project from my eclipse plugin java code . its not working please help . |
0 |
2985 |
Tue, 21 October 2014 07:26 By: reeta aggarwal |
implement sparse checkout guidance to implement sparse checkout, |
0 |
4304 |
Mon, 20 October 2014 09:51 By: rupert THURNER |
Eclipse Kepler/Luna IDE for Java EE Developers & Egit |
5 |
3973 |
Sun, 19 October 2014 16:41 By: Robin Rosenberg |
can not switch to another branch |
4 |
14867 |
Thu, 16 October 2014 19:20 By: Robin Rosenberg |
Could not add menu item to Egit history View menu Could not add menu item to Egit history View menu |
0 |
3541 |
Sun, 12 October 2014 20:48 By: Ruhong Cai |
How to always enable command handler in Egit How to always enable command handler in Egit |
0 |
3977 |
Fri, 10 October 2014 22:43 By: Ruhong Cai |
How to integrate with Egit for adding a new item in Commit menu from history view How to integrate with Egit for adding a new item in Commit menu from history view |
0 |
3693 |
Thu, 09 October 2014 23:09 By: Ruhong Cai |
Signing Commits How to gpgsign a commit in the gui? |
1 |
3031 |
Wed, 08 October 2014 06:43 By: Matthias Sohn |
SHOW Uncommitted changes in FILE ? Is it possible to add to show uncommitted changes in EDITOR? |
1 |
3942 |
Tue, 07 October 2014 16:31 By: Felix Dorner |
Commands to import archive zip into new repository Exporting archiving and re-importingit |
1 |
1161 |
Mon, 06 October 2014 22:37 By: Matthias Sohn |
External merge tool with git How to use an external merge tool when using git on eclipse? |
1 |
7265 |
Sat, 04 October 2014 00:01 By: Matthias Sohn |
Help with git/Egit (noob here), can't push project New github user, trying to push existing project |
1 |
3014 |
Fri, 03 October 2014 23:57 By: Matthias Sohn |
Get event generation source from ExecutionEvent object Issues in getting the source of generating the Selection event for the Command Handler in multi-threaded environment |
2 |
6424 |
Fri, 03 October 2014 23:55 By: Matthias Sohn |
Access GIT Repository hosted on a Windows 2008 Server in a cloud Hi All, By: Vital J on Fri, 26 September 2014 |
2 |
1913 |
Fri, 03 October 2014 23:54 By: Matthias Sohn |
Changes made on branch appear on master. |
1 |
2308 |
Fri, 03 October 2014 23:51 By: Matthias Sohn |
gitignore and importing projects |
5 |
19660 |
Tue, 23 September 2014 07:33 By: Fredrik Berg |
Checking out commit |
1 |
2071 |
Mon, 15 September 2014 07:19 By: Christian Halstrick |
Escape file name By: Dol Bik on Wed, 10 September 2014 |
6 |
6729 |
Fri, 12 September 2014 22:40 By: Robin Rosenberg |
unchanged files are being marked as changed unchanged files are being marked as changed |
3 |
3448 |
Fri, 12 September 2014 22:02 By: Robin Rosenberg |
Egit getting sluggish with WorkingTreeIterator.computeHash() |
3 |
3302 |
Fri, 12 September 2014 21:55 By: Robin Rosenberg |
Multi repositories project |
2 |
2757 |
Fri, 12 September 2014 21:50 By: Robin Rosenberg |
how to remove folder from git version control |
5 |
8930 |
Tue, 09 September 2014 13:36 By: Matthias Sohn |
Problems with egit.github |
1 |
9209 |
Tue, 09 September 2014 13:34 By: Matthias Sohn |
Delete a file on remote repository via Egit |
1 |
18749 |
Tue, 09 September 2014 13:27 By: Matthias Sohn |
Annoying repeating message 'Building workspace' on status bar after I version controlled a project |
18 |
11910 |
Tue, 09 September 2014 13:24 By: Matthias Sohn |
Execute custom command after performing pull using eGit |
1 |
4286 |
Tue, 09 September 2014 13:23 By: Matthias Sohn |
Can't "push" in a solo usage |
4 |
4324 |
Tue, 09 September 2014 13:22 By: Matthias Sohn |
"Looking for uncommitted changes" popup freezed |
1 |
4494 |
Tue, 09 September 2014 13:11 By: Matthias Sohn |
Trouble with installing EGit Eclipse Plugin Trouble with installing EGit Eclipse Plugin |
2 |
9831 |
Tue, 09 September 2014 13:07 By: Matthias Sohn |
SymlinksNotSupportedException when resetting to HEAD |
3 |
4331 |
Tue, 09 September 2014 13:05 By: Matthias Sohn |
Custom merge commit message |
2 |
4095 |
Tue, 09 September 2014 08:39 By: Felix Dorner |
authentication fails after password change |
4 |
76214 |
Tue, 09 September 2014 08:37 By: Matthias Sohn |
Configure... dialog for fetch shows wrong remote |
1 |
1599 |
Tue, 09 September 2014 08:36 By: Matthias Sohn |
JGit version of 'git merge-tree' |
0 |
2623 |
Wed, 27 August 2014 17:01 By: Sneakers Please |
Merge does not respect mergeoptions config file value not used |
5 |
4780 |
Mon, 18 August 2014 13:24 By: Andi Scharfstein |
Push a specific commit to remote repository |
1 |
8122 |
Fri, 15 August 2014 19:00 By: Konrad Kügler |
How to identify Committed but unpushed files How to identify Committed but unpushed files |
2 |
6102 |
Fri, 08 August 2014 17:41 By: sakshi kaushik |
