Topic |
Replies |
Views |
Last message |
Move Eobject from one container to another container in EMF Move Eobject from one container to another container in EMF |
2 |
1640 |
Thu, 23 June 2022 10:31 By: Nagaraj Kandoor |
Xtext 2.26 based Maven build failing since 2022-06-15 |
3 |
4437 |
Fri, 17 June 2022 07:14 By: Christian Dietrich |
Vscode extension formatting has different behavior than Eclipse Different outputs when formatting directly in Eclipse and when packaged into a Vscode extension |
1 |
1283 |
Sat, 11 June 2022 17:12 By: Christian Dietrich |
JvmUnknownTypeReference for Support Class |
1 |
2268 |
Fri, 10 June 2022 04:04 By: Christian Dietrich |
Generate templates.xml? |
2 |
1750 |
Fri, 03 June 2022 17:57 By: Ed Willink |
Building an xtext language using gradle, in the main thread |
11 |
6535 |
Fri, 03 June 2022 17:07 By: Andrzej Wasowski |
How to add a documentation in code-completion? |
3 |
1809 |
Fri, 03 June 2022 14:02 By: Christian Dietrich |
'Generate WTEXT artifact' does not end... |
2 |
2089 |
Thu, 02 June 2022 13:02 By: Christian Dietrich |
Xtext grammar for SQL Right now I work on mapping SQL to Cypher and vice versa, I need Xtext grammars for SQL and Cypher |
1 |
2244 |
Wed, 01 June 2022 13:16 By: Ed Willink |
Workaround semantic predicates Workaround semantic predicates |
2 |
3004 |
Tue, 24 May 2022 13:47 By: Antonio Garmendia |
Xtext 2.27.0.M3 is out |
0 |
4852 |
Mon, 23 May 2022 07:30 By: Christian Dietrich |
Missing generated Activator class in *.*.ui/src-gen folder |
3 |
2849 |
Wed, 18 May 2022 12:28 By: Christian Dietrich |
How to convert XMI to plain text when opening XTextEditor? By: jo ber on Fri, 13 May 2022 |
2 |
3240 |
Tue, 17 May 2022 09:26 By: jo ber |
Error: "Message could not be parsed" in Socket Mode |
5 |
1455 |
Wed, 11 May 2022 18:34 By: Tom Martens |
Check Validity of automatically generated instances |
4 |
1887 |
Thu, 05 May 2022 16:46 By: Christian Dietrich |
Xtext 2.27.0.M2 is out |
0 |
3310 |
Sun, 01 May 2022 11:01 By: Christian Dietrich |
Multiple Xtext files and Same Ecore Multiple Xtext and Same Ecore |
9 |
3427 |
Sat, 30 April 2022 13:03 By: Antonio Garmendia |
NullPointerException in Xtext IDE project after removing generate model statement from grammar Grammar both imports existing EPackages and generates an EPackage |
3 |
1690 |
Thu, 28 April 2022 17:22 By: Christian Dietrich |
How to react on external changes of the AST |
1 |
3686 |
Tue, 26 April 2022 18:53 By: Alejandro González |
Custom Syntax Colouring for ide By: P J on Tue, 08 January 2019 |
11 |
5893 |
Mon, 25 April 2022 17:39 By: Christian Dietrich |
Including Maven Dependencies on XText Eclipse Project |
5 |
1743 |
Fri, 22 April 2022 21:39 By: Ben Holland |
[1...*] cardinality in xtext |
2 |
984 |
Thu, 21 April 2022 14:44 By: Christian Dietrich |
Get already build xtext resource in languageServer Get already build xtext resource in languageServer |
4 |
1402 |
Thu, 21 April 2022 09:54 By: Nagaraj Kandoor |
LSP4J : Language Server method call never ends |
1 |
983 |
Wed, 20 April 2022 16:15 By: Christian Dietrich |
Packages does not exist from Xtext Maven Example |
5 |
3989 |
Sat, 16 April 2022 05:17 By: Christian Dietrich |
Allow cross-references to "built-in" types |
17 |
2925 |
Wed, 13 April 2022 15:07 By: Christian Dietrich |
Xtext 2.27.0.M1 is out |
0 |
2690 |
Mon, 11 April 2022 12:43 By: Christian Dietrich |
Same keywords xtext formatter |
1 |
1268 |
Sat, 09 April 2022 05:25 By: Christian Dietrich |
Storing list of eobjects before calling xtext validations |
10 |
2835 |
Thu, 07 April 2022 10:12 By: Christian Dietrich |
Using Quickfixes and a LanguageServer |
9 |
2014 |
Wed, 06 April 2022 12:51 By: Rubén Porras Campo |
Xtext and Log4j/Reload4j |
3 |
1678 |
Wed, 06 April 2022 12:33 By: Ed Willink |
Reference Enum Literals of an Ecore model |
21 |
4458 |
Tue, 05 April 2022 14:48 By: Christian Dietrich |
Xtext String no quotes |
3 |
1047 |
Tue, 05 April 2022 14:30 By: John Henbergs |
xtext some .dsl files shall not be checked from grammar |
9 |
2393 |
Mon, 04 April 2022 11:25 By: Christian Dietrich |
Update language server UI in non UI thread Update language server UI in non UI thread |
2 |
975 |
Fri, 01 April 2022 20:06 By: Nagaraj Kandoor |
AbstractFormatter2 |
6 |
1153 |
Thu, 31 March 2022 19:21 By: Christian Dietrich |
Reference Epackage |
19 |
3585 |
Wed, 30 March 2022 11:30 By: John Henbergs |
Xtext & Build Loops |
8 |
6757 |
Tue, 29 March 2022 07:28 By: Christian Dietrich |
Xtext maven plugin language order Language generation order by xtext-maven-plugin |
3 |
8528 |
Mon, 28 March 2022 18:12 By: Edmundo López Bóbeda |
Bi-directional reference |
2 |
1320 |
Mon, 28 March 2022 15:38 By: Ed Willink |
xtend src-gen folder relative to dsl file |
2 |
1516 |
Mon, 28 March 2022 07:01 By: Dennis Untiet |
Use Xtext Editor for a model field |
2 |
2801 |
Mon, 28 March 2022 06:58 By: Inaki Berriotxoa |
Register Xtext Resource Factory in Xtend |
3 |
1317 |
Sun, 27 March 2022 17:53 By: Christian Dietrich |
General Xtext question |
4 |
2346 |
Thu, 24 March 2022 15:23 By: Gaël DENIAU |
Specify output directory of generated classes via configuration |
3 |
2489 |
Thu, 24 March 2022 07:56 By: Ed Willink |
Xtext LSP - Validation - @Check annotations @Check annotations don't seem to be taken into account by Xtext LSP |
4 |
2304 |
Thu, 17 March 2022 10:25 By: Rubén Porras Campo |
Syntax-Error for LessThan-Keyword |
2 |
1878 |
Thu, 17 March 2022 09:42 By: Ed Willink |
How to avoid ambiguity |
16 |
3313 |
Wed, 16 March 2022 08:58 By: Konrad Jünemann |
Language server not responding to client request Language server not responding to client request |
11 |
3298 |
Mon, 14 March 2022 16:08 By: Nagaraj Kandoor |
Trigger validator(builder) for multiple files Trigger validator(or builder) for multiple files/ validator rules over multiple files |
12 |
3577 |
Thu, 10 March 2022 12:48 By: Christian Dietrich |
Data annotation overrides toString from parent class Is it possible to keep the behaviour of the parent class? |
3 |
2037 |
Wed, 09 March 2022 10:34 By: Elie Richa |
Generate Files outside of the xtext project, relative to the projects location |
2 |
11835 |
Mon, 07 March 2022 15:30 By: Christian Dietrich |
XMI model to Defined Xtext Model |
1 |
1266 |
Mon, 07 March 2022 15:13 By: Ed Willink |
Xtext & Xtend Release 2.26.0 is available now Xtext & Xtend Release 2.26.0 is available now |
1 |
4018 |
Sun, 06 March 2022 05:15 By: Mirko Raner |
Export DSL to PDF along with highlighting |
0 |
4694 |
Sat, 05 March 2022 01:41 By: Jonathan Menzies |
From custom types to Java types |
6 |
1920 |
Fri, 04 March 2022 16:03 By: Christian Dietrich |
Installation of older SDK Versions broken Installation of older SDK Versions broken |
3 |
1383 |
Thu, 03 March 2022 13:58 By: Christian Dietrich |
Generate correct code in xtend |
8 |
2393 |
Mon, 28 February 2022 14:23 By: Muhammad Salman Tayyab |
Text changes not reflected on the AST |
7 |
2244 |
Fri, 25 February 2022 12:27 By: Christian Dietrich |
Xtext&Xtend Milestone 2.26.0.RC1 is available now |
1 |
2810 |
Wed, 23 February 2022 09:35 By: Mirko Raner |
Convert RCP plugin project to a Maven project |
2 |
1760 |
Thu, 17 February 2022 08:03 By: Karsten Thoms |
Dsl runtime library |
6 |
1600 |
Tue, 15 February 2022 16:41 By: Yannick DAVELUY |
How to have both cross references and non cross references for a rule? |
6 |
2195 |
Fri, 11 February 2022 11:11 By: Christian Dietrich |
Xtext & Xtend Milestone 2.26.0.M3 is available now |
3 |
4580 |
Fri, 11 February 2022 07:11 By: Rubén Porras Campo |
XBase Imports with Cross References to Another File |
1 |
1403 |
Thu, 10 February 2022 04:52 By: Christian Dietrich |
Whitespace issue with nested blocks |
2 |
4228 |
Wed, 09 February 2022 21:13 By: Axel Guckelsberger |
Cascading Xtext Generators |
5 |
1834 |
Tue, 08 February 2022 14:12 By: Christian Dietrich |
Adapting the generated java code from xtend How to change body of generated method using active annotations |
2 |
1371 |
Tue, 08 February 2022 10:29 By: Wilbert Alberts |
Disable validation rule if editor state is dirty |
1 |
6473 |
Wed, 02 February 2022 09:36 By: Yannick DAVELUY |
Xtend and Xtext M2M Transformation with Xtend |
1 |
870 |
Thu, 27 January 2022 15:15 By: Christian Dietrich |
How to prevent a dsl file to be built if it is not in the classpath |
3 |
1193 |
Thu, 27 January 2022 15:10 By: Christian Dietrich |
Formatting comma-separated list with new line & indent |
3 |
1501 |
Wed, 26 January 2022 15:27 By: Carl Weathers |
Position of Comments in a Line How to manipulate the ordering of hidden and semantic regions |
0 |
4711 |
Tue, 25 January 2022 04:05 By: John Dreight |
Partial instance conversion between EMF<->Xtext Converting EMF objects to Xtext, modify them, and then transform back |
1 |
1294 |
Mon, 17 January 2022 09:42 By: Tamas Miklossy |
XText model to XMI model |
8 |
2376 |
Thu, 13 January 2022 15:52 By: Campbell McCausland |
Xtext with Java as code generator Looking for a tutorial on Xtext with Java |
2 |
1431 |
Thu, 13 January 2022 13:05 By: Abdelgafar Elkhaoui |
Validator context based |
7 |
1956 |
Thu, 13 January 2022 10:02 By: Karsten Thoms |
Log4j 1.x updates to Log4j2 |
4 |
2129 |
Fri, 31 December 2021 14:22 By: Ed Willink |
Handling of backslash |
1 |
916 |
Mon, 27 December 2021 17:42 By: Ed Willink |
Defined 2-way link-list xtext grammar issues Defined 2-way link-list xtext grammar issues |
3 |
1291 |
Thu, 23 December 2021 19:15 By: Ed Willink |
Strange launch and build issue with XText antlr dependency and Eclipse products |
1 |
1235 |
Thu, 23 December 2021 09:33 By: Christian Dietrich |
Xtext 2.26.0.M2 is available |
3 |
2573 |
Thu, 23 December 2021 09:26 By: Christian Dietrich |
How can I transform an xtext dsl file to xml? |
4 |
1598 |
Thu, 23 December 2021 07:34 By: Christian Dietrich |
XText project migrating from Eclipse to LSP : No ContentAssist working Unable to make the completion work on a XText project using LSP |
4 |
1674 |
Fri, 10 December 2021 11:06 By: Arthur Daussy |
Compile into Native using GraalVM I would like to compile a XText Project using GraalVM's native image. |
4 |
2279 |
Fri, 03 December 2021 07:27 By: Karsten Thoms |
Converting Xtext DSL tests to Junit5 |
9 |
2529 |
Sat, 27 November 2021 10:56 By: Christian Dietrich |
Maven Build Issues - Xtext 2.22 2020-06 Java11 |
2 |
1755 |
Wed, 24 November 2021 13:58 By: Brandon Lewis |
Extending Xtend type system with own kinds of type? |
0 |
3040 |
Mon, 22 November 2021 00:12 By: Constantine Plotnikov |
Reference Ecore model in Xtext grammar |
4 |
1223 |
Wed, 17 November 2021 16:33 By: Christian Dietrich |
0 |
2321 |
Wed, 17 November 2021 12:53 By: Jan Crkvic |
Xtext builder stops eclipse build |
1 |
917 |
Wed, 17 November 2021 08:06 By: Christian Dietrich |
Gradle Build Folder not Ignored |
3 |
1147 |
Tue, 16 November 2021 13:50 By: Alfredo Aldundi |
Simple SuperType Problem in Grammar - Cannot find compatible feature |
7 |
1277 |
Thu, 11 November 2021 18:07 By: Ed Willink |
[Xtext] Grammar - Enhancing the infered model for language expressions |
5 |
3806 |
Sat, 06 November 2021 05:05 By: Mirko Raner |
log4j.properties not updating changed log4j.properties not picking up changed properties file |
6 |
2766 |
Sun, 31 October 2021 17:53 By: Don Flinn |
using custom java bean in my language using custom java bean in my language By: Ramu M on Sun, 31 October 2021 |
0 |
2206 |
Sun, 31 October 2021 07:49 By: Ramu M |
How to add Template Proposal in Xtext as LSP for VSCODE |
1 |
1234 |
Thu, 28 October 2021 02:58 By: Christian Dietrich |
How could empty elements be allowed in a whitespace-aware DSL in xtext? How could empty elements be allowed in a whitespace-aware DSL in xtext? |
1 |
876 |
Wed, 27 October 2021 09:43 By: Christian Dietrich |
Disable new resource creation for every character entry Disable incremental build |
7 |
2365 |
Wed, 27 October 2021 04:48 By: Christian Dietrich |
How to extend Xtext's trace API? How to add extra information to trace files generated by TracingSugar? |
0 |
2419 |
Mon, 25 October 2021 11:02 By: Prasanna Balaji |
problems with importing xtext libraries |
1 |
967 |
Sat, 23 October 2021 15:05 By: Christian Dietrich |
Scoping Performance |
2 |
1721 |
Thu, 21 October 2021 13:47 By: Alfredo Aldundi |
Default Cross-References Allowing a list to contain both cross-references to created objects and keywords |
3 |
1800 |
Thu, 14 October 2021 19:22 By: Camden Blake |
User defined functions with builtin functions |
2 |
1511 |
Thu, 14 October 2021 15:29 By: Charalampos Alexopoulos |
XText + XSemantics + Maven Need help with project setup |
4 |
1401 |
Thu, 14 October 2021 09:56 By: Simon Cockx |
3AC three addresses code grammar |
0 |
28423 |
Thu, 07 October 2021 15:17 By: Soulimane KAMNI |
VS Code published mydsl extensions don't work - why? |
1 |
934 |
Tue, 05 October 2021 11:30 By: Christian Dietrich |
An icon for DSL file |
4 |
1214 |
Fri, 01 October 2021 15:28 By: Márcio Koch |
Namespace import no longer works since XText 2.21.0 |
8 |
1967 |
Wed, 29 September 2021 14:11 By: Christian Dietrich |
Change StringConcatenation for grammar tests Using unix line endings in tests |
2 |
1545 |
Tue, 28 September 2021 11:48 By: Horacio Hoyos |
Extending XtextBuilder for two DSLs Extending XtextBuilder for two DSLs |
8 |
2823 |
Tue, 28 September 2021 05:40 By: Virag Purnam |
Best Practise for autocompletion during syntax errors |
1 |
2458 |
Fri, 24 September 2021 19:43 By: Konrad Jünemann |
How to solve this ambiguity problem |
1 |
950 |
Fri, 24 September 2021 16:39 By: Konrad Jünemann |
How to stop the validation programmatically for dsl project |
7 |
1769 |
Thu, 23 September 2021 14:56 By: Christian Dietrich |
Shared utility object for entire project build |
4 |
1095 |
Sun, 19 September 2021 18:37 By: Elie Richa |
Implicit Model Elements |
6 |
1588 |
Fri, 17 September 2021 14:03 By: Alfredo Aldundi |
Label Provider not being invoked |
8 |
1684 |
Fri, 17 September 2021 06:43 By: Horacio Hoyos |
Unable to create Eclipse Product from the sample MyDsl projects |
6 |
1831 |
Thu, 16 September 2021 13:48 By: Franck De Bruijn |
Reference model elements from target platform How is it possible to provide parts of the model reflected in my DSL in bundles in the target platform |
8 |
1478 |
Tue, 14 September 2021 13:03 By: Christian Dietrich |
Configurable generator |
1 |
2693 |
Mon, 13 September 2021 15:38 By: Christian Dietrich |
Expression Language Formatting and Quickfixes |
4 |
1165 |
Sun, 12 September 2021 20:28 By: Alfredo Aldundi |
No Xtext languages have been registered |
3 |
1076 |
Wed, 08 September 2021 18:03 By: Christian Dietrich |
Validator Validator to avoid repetition |
4 |
1332 |
Wed, 08 September 2021 18:02 By: Christian Dietrich |
Cannot Reference One Xcore Model from Another |
0 |
2384 |
Wed, 08 September 2021 17:57 By: Greg Lusk |
problems with Xtext 2.8 and Xcore 1.3.0 |
4 |
3984 |
Fri, 27 August 2021 15:26 By: Greg Lusk |
Trigger build automatically Trigger doGenerate from different project |
1 |
1360 |
Fri, 27 August 2021 08:45 By: Christian Dietrich |
Validation method not being called Only one check method is called |
10 |
3195 |
Thu, 26 August 2021 10:40 By: Christian Dietrich |
Xtend gradle builder leaves java files for deleted Xtend files behind |
1 |
1386 |
Wed, 18 August 2021 15:14 By: Christian Dietrich |
Concurrent readers impossible? |
7 |
2025 |
Tue, 17 August 2021 11:19 By: Ed Willink |
Customize Java-Expression "toString" Customizing NodeModelUtils getTokenText |
3 |
1366 |
Mon, 16 August 2021 10:55 By: Christian Dietrich |
Validating against non EMF context How to do per instance synamic validation |
2 |
1742 |
Thu, 12 August 2021 09:35 By: Jeff Lowcock |
Context Validation Dynamic Contect Validation - not static validation |
1 |
1728 |
Thu, 12 August 2021 05:38 By: Christian Dietrich |
Override SL_COMMENT Parsing comments |
0 |
2781 |
Mon, 09 August 2021 11:40 By: Frä Fröhlich |
Xpand or Xtext function NOCODE No Code while running algorithem |
2 |
2329 |
Fri, 30 July 2021 08:08 By: zhen zhong |
Run the generated unit tests from the dsl test programmatically |
1 |
1186 |
Wed, 28 July 2021 09:37 By: Christian Dietrich |
Two DSLs or two-tier-build? |
10 |
1974 |
Fri, 23 July 2021 18:25 By: Konrad Jünemann |
Umsetzung von Xtend-Funktionen basierend auf einem UML-Klassendiagramm Verständnisproblem zur Umsetzung von Xtend-Funktionen basierend auf einem UML-Klassendiagramm By: Pol Ek on Thu, 22 July 2021 |
14 |
2204 |
Fri, 23 July 2021 14:18 By: Christian Dietrich |
Performance issue when doing index of resourceset |
11 |
1850 |
Fri, 23 July 2021 13:26 By: Christian Dietrich |
Deadlock between Job and event listener on Display thread |
4 |
1267 |
Wed, 21 July 2021 15:59 By: Ed Willink |
Using LocalDateTime in Xtext Grammar |
4 |
993 |
Tue, 20 July 2021 14:51 By: Dimg Cim |
XtextDocument/Node does not update offset ? |
4 |
1327 |
Tue, 20 July 2021 07:50 By: Ryana Karaki |
Xtext and Java 16 |
13 |
3630 |
Mon, 19 July 2021 21:37 By: Michael Bischoff |
Problems changing hover size & colors (Xtext 2.24) |
6 |
1526 |
Mon, 19 July 2021 09:50 By: Ryana Karaki |
Customizing XtextAnnotation |
2 |
1125 |
Mon, 19 July 2021 09:47 By: Ryana Karaki |
Highlight keywords with dashes |
9 |
2140 |
Wed, 07 July 2021 22:05 By: Nico-Pascal Huch |
Cannot find compatible feature name Xtext setup after migrating to Xtext 2.15 |
9 |
1845 |
Fri, 02 July 2021 12:37 By: Ed Willink |
Issues with Xtext and Epsilon |
22 |
3266 |
Fri, 02 July 2021 09:30 By: Ed Willink |
How to format datatype rules with Formatter2 XText version 2.9 |
7 |
2759 |
Wed, 30 June 2021 16:05 By: Stanislav Tartakowski |
How to make the LSP server print more debug logs? |
4 |
1531 |
Wed, 30 June 2021 04:55 By: Christian Dietrich |
Multiple xtext DSL projects in one workspace |
6 |
1785 |
Tue, 29 June 2021 11:06 By: Christian Dietrich |
Recursive Grammar with EMF Combining Model Code Generation and recursive Grammar |
5 |
1582 |
Mon, 21 June 2021 09:07 By: Christian Dietrich |
cannot build old xtend projects with gradle old xtend projects are failing |
1 |
1065 |
Sun, 20 June 2021 18:49 By: Christian Dietrich |
Cannot build old Xtext projects with maven since 2021-06-16 |
5 |
4861 |
Sun, 20 June 2021 03:58 By: Christian Dietrich |
XExpressions and Statements Understanding the XExpression and behavior of ";" |
1 |
954 |
Thu, 17 June 2021 08:34 By: Christian Dietrich |
xtext 2.25.0 + jdk 11.0.11 error when trying to run jetty By: z232 I on Wed, 16 June 2021 |
6 |
1247 |
Wed, 16 June 2021 16:53 By: Ed Willink |
What is the use of completeRuleCall |
0 |
2113 |
Wed, 16 June 2021 15:27 By: chen fangyi |
XBase EMF Xtext XBase EMF Ecore |
10 |
1608 |
Wed, 16 June 2021 12:48 By: Christian Dietrich |
Code coverage for Xtend (outside of maven build) |
6 |
3854 |
Fri, 11 June 2021 13:14 By: Christian Dietrich |
How to export custom hovers as plug in ? |
16 |
1964 |
Wed, 09 June 2021 11:42 By: Ryana Karaki |
Trying to generate DSL files using Java I want to geenrate files following a DSL using a Java program |
14 |
4634 |
Wed, 09 June 2021 10:15 By: Christian Dietrich |
How to import EOL for syntax highlighting |
4 |
959 |
Tue, 08 June 2021 18:03 By: Ed Willink |
Integrate ocl in xtext grammar or grab all the characters until any language rule appears Integrate ocl in xtext grammar or grab all the characters until any language rule appears |
5 |
1512 |
Fri, 04 June 2021 09:10 By: Ed Willink |
How to change Xtext DSL file programmatically ? (Xtext 2.24) |
2 |
983 |
Wed, 02 June 2021 12:39 By: Ryana Karaki |
Making editor regions read-only |
2 |
1173 |
Tue, 01 June 2021 12:56 By: Yannick DAVELUY |
Optional ordering with commas where first element can also be optional By: M D on Sun, 30 May 2021 |
3 |
1210 |
Tue, 01 June 2021 12:48 By: Ed Willink |
Lexer mixes some inputs even though it is set to non-greedy? By: M D on Sun, 30 May 2021 |
11 |
1542 |
Mon, 31 May 2021 11:50 By: Ed Willink |
Using the Xtext.xtext grammar in another DSL gives "Couldn't resolve reference to EClassifier&q By: M D on Sun, 30 May 2021 |
2 |
911 |
Sun, 30 May 2021 17:25 By: M D |
Cross-referencing two different rules? By: M D on Tue, 25 May 2021 |
2 |
1192 |
Sun, 30 May 2021 09:13 By: M D |
Git / Maven Setup for standalone build |
6 |
1088 |
Fri, 21 May 2021 11:31 By: Konrad Jünemann |
Multiple Generator calls on Xtext language Multiple Generator calls on Xtext language |
1 |
3273 |
Wed, 19 May 2021 07:35 By: Neeraj Bhusare |
Update to Java 11 as minimal Java version |
0 |
2149 |
Mon, 17 May 2021 07:38 By: Christian Dietrich |
My xtext-maven-plugin does not generate DSL code on project |
10 |
2514 |
Wed, 12 May 2021 18:18 By: Márcio Koch |
Dockerizing Xtext web app docker + xtext By: z232 I on Tue, 11 May 2021 |
5 |
1216 |
Wed, 12 May 2021 15:35 By: Christian Dietrich |
Cannot import an Existing Maven Projetct in a Run As Eclipse Aplication |
2 |
935 |
Tue, 11 May 2021 22:03 By: Márcio Koch |
Xtext Resource Storage how to write fully resolved and computed resources to disk |
14 |
1877 |
Fri, 07 May 2021 19:19 By: Christian Dietrich |
Initialization of member JvmFields in constructor of a parent JvmGenericType Initialization of fields with XExpression not via 'JvmTypesBuilder#setInitializer' method but at some other place |
2 |
904 |
Fri, 07 May 2021 15:26 By: Ed Willink |
Proper way to install antlr-generator-3.2.0-patch.jar |
6 |
2439 |
Thu, 06 May 2021 14:07 By: Konrad Jünemann |
Supporting several versions of a DSL when using the DSL's eclipse plugin |
0 |
1880 |
Thu, 06 May 2021 06:41 By: Gerrit Schulz |
Resolving unresolved reference using IDerivedStateComputer |
24 |
2880 |
Mon, 03 May 2021 05:00 By: Nagaraj Kandoor |
xtext-services and iframe xtext-services don't work when using iframe By: z232 I on Thu, 29 April 2021 |
18 |
3854 |
Fri, 30 April 2021 06:08 By: z232 I |
Nested class and visibility of members |
10 |
1564 |
Wed, 28 April 2021 19:48 By: Christian Dietrich |
How could I create a new Xtext project from existing ecore model then there is no brackets in xtext? How could I create a new Xtext project from existing ecore model then there is no brackets in xtext? |
18 |
2381 |
Wed, 28 April 2021 13:05 By: Christian Dietrich |
On-the-fly declaration in cross-reference |
7 |
1362 |
Mon, 26 April 2021 09:43 By: Christian Dietrich |
Couldn't resolve reference to EClassifier 'XXX' in Xtext Couldn't resolve reference to EClassifier 'XXX' in Xtext file after creating xtext projects from existing ecore |
4 |
1299 |
Fri, 23 April 2021 14:21 By: Weixing Zhang |
Serializer overzealously inserts parentheses |
0 |
2052 |
Fri, 23 April 2021 14:04 By: Dimo Petroff |
Missing folders when create xtext projects from existing ecore Missing folders when create xtext projects from existing ecore |
1 |
847 |
Fri, 23 April 2021 12:53 By: Christian Dietrich |
Cross Referencing different Types |
2 |
792 |
Tue, 20 April 2021 10:23 By: Lukas Schaus |
Xtext LSP, Client with separate server process Need help in getting the basic Xtext LSP example to work |
4 |
1174 |
Tue, 20 April 2021 06:34 By: Neeraj Bhusare |
Formatter2 autowrap |
4 |
1520 |
Mon, 19 April 2021 16:37 By: Dimo Petroff |
Bind STRINGValueConverter By: M D on Sat, 17 April 2021 |
2 |
693 |
Sat, 17 April 2021 19:25 By: M D |
Missing Rule BEGIN in White-space awareness grammar |
2 |
2039 |
Fri, 16 April 2021 08:52 By: wings cu |
How to disable validation when editing in xtext editor? validator performance |
3 |
1389 |
Tue, 13 April 2021 15:35 By: Neeraj Bhusare |
Qualified Name ID.ID....KEYWORD |
1 |
850 |
Tue, 13 April 2021 13:06 By: Christian Dietrich |
Supressing content assist auto activation in DSL comments content assist auto activation supression |
2 |
929 |
Tue, 13 April 2021 08:15 By: Martin Melik Merkumians |
Compute offset from position (line,col) |
2 |
957 |
Sun, 11 April 2021 18:20 By: Ed Willink |
SecurityException in Maven build |
4 |
1394 |
Sun, 11 April 2021 14:38 By: Christian Dietrich |
Split XText Grammar into multiple files |
7 |
6040 |
Sun, 11 April 2021 01:10 By: Mirko Raner |
Qualified Name according to the hierarchical level |
7 |
1079 |
Fri, 09 April 2021 15:19 By: Christian Dietrich |
Customize Scoping for inheritance |
62 |
4539 |
Thu, 08 April 2021 13:31 By: John Henbergs |
missing RULE_BEGIN if using whitespace-aware |
14 |
3781 |
Thu, 08 April 2021 04:29 By: wings cu |
