Topic |
Replies |
Views |
Last message |
Drops and Updates are now Builds |
0 |
838 |
Fri, 08 March 2024 20:13 By: Ed Willink |
Propagate warning information to ExecutionDiagnostic |
5 |
1306 |
Mon, 27 November 2023 13:41 By: Christopher Gerking |
Remove object in place transformation |
3 |
1185 |
Tue, 14 November 2023 08:38 By: Christopher Gerking |
Create QVTo project programmatically |
2 |
1021 |
Fri, 07 July 2023 13:31 By: Christopher Gerking |
Type references for nested EClasses |
4 |
1039 |
Tue, 13 June 2023 20:09 By: Ed Willink |
Transformation involving UML profiles |
1 |
584 |
Thu, 08 June 2023 16:59 By: Ed Willink |
Resolution operations for objects in other containers. |
2 |
747 |
Thu, 13 April 2023 14:53 By: Christopher Gerking |
Different URI |
1 |
713 |
Thu, 30 March 2023 17:25 By: Ed Willink |
Output model into separate files |
2 |
694 |
Fri, 27 January 2023 19:37 By: Ed Willink |
QVTo transformation with Xtext target models |
4 |
1030 |
Fri, 13 January 2023 20:15 By: Christopher Gerking |
Transform UML models with applied profile |
1 |
1234 |
Sat, 24 December 2022 05:58 By: Ed Willink |
EPX to Ecore and EMX to Xtext instances |
3 |
1321 |
Thu, 22 December 2022 14:27 By: Christopher Gerking |
Representing QVT-Operational transformations in XML, JSON or or any other serialized format I have a requirement where I need to parse the transformations defined in the QVT-Operational file. |
3 |
1147 |
Sat, 03 December 2022 12:08 By: Christopher Gerking |
Disjunction and inheritance |
3 |
2503 |
Mon, 25 April 2022 11:43 By: Christopher Gerking |
Access existing objects |
1 |
1190 |
Thu, 07 April 2022 19:01 By: Christopher Gerking |
Change value of ENum attribute depending on type of class |
3 |
1399 |
Thu, 10 March 2022 19:36 By: Ed Willink |
Wrong output model structure |
4 |
1200 |
Tue, 08 March 2022 16:46 By: Ed Willink |
Conditional mappings |
1 |
850 |
Mon, 07 March 2022 15:20 By: Christopher Gerking |
Qualified name of reference |
2 |
1159 |
Fri, 25 February 2022 16:39 By: Christopher Gerking |
Mono and multi valued attributes |
3 |
1234 |
Tue, 22 February 2022 11:32 By: Christopher Gerking |
Replace conditional statements with queries |
5 |
2227 |
Tue, 22 February 2022 10:57 By: Christopher Gerking |
Modeltype metamodel |
2 |
1849 |
Thu, 03 February 2022 18:58 By: Ed Willink |
[QVTo] Can a constructor call another constructor? |
2 |
1132 |
Wed, 02 February 2022 13:23 By: Ed Willink |
Can black-box library use metamodel from workspace? |
14 |
2965 |
Mon, 10 January 2022 19:03 By: Ed Willink |
how to transform a bidirectional relationship? |
3 |
1177 |
Wed, 29 December 2021 20:08 By: Ed Willink |
When to use . and -> |
4 |
1281 |
Thu, 16 December 2021 12:34 By: Ed Willink |
Autocomplete window colors in dark theme |
0 |
2881 |
Thu, 16 December 2021 10:41 By: Denis Nikiforov |
QVTo disjunct operation on abstract mappings |
5 |
1581 |
Mon, 29 November 2021 16:33 By: Christopher Gerking |
Compiled output A way for compiling and load/save processed compiler output |
3 |
1055 |
Mon, 29 November 2021 15:14 By: Christopher Gerking |
Element is not transformed inside its container |
9 |
1898 |
Mon, 22 November 2021 08:45 By: Christopher Gerking |
Compiling performance Poor compiling performance |
4 |
1402 |
Mon, 15 November 2021 08:54 By: Fabio Popcorn |
Create new element in target model |
3 |
1215 |
Wed, 03 November 2021 08:05 By: Christopher Gerking |
Can we map two abstract classes? |
6 |
1226 |
Mon, 01 November 2021 19:46 By: Christopher Gerking |
Only recognise the first model type |
5 |
1713 |
Mon, 18 October 2021 07:22 By: Christopher Gerking |
Support of metamodels referencing other metamodels |
13 |
3081 |
Fri, 18 June 2021 15:14 By: Christopher Gerking |
M2M trasformation hel about MoWebA approach I'm looking for experts about M2M trasformation with QVT operational mappings language |
7 |
1095 |
Mon, 14 June 2021 17:00 By: Ed Willink |
Problems with color themes in Eclipse Strange behaviour of color themes settings in Eclipse |
2 |
5946 |
Fri, 30 April 2021 11:53 By: Antonio Cicchetti |
Define infix arithmetic operations for a custom class |
3 |
922 |
Tue, 06 April 2021 12:45 By: Ed Willink |
QVTo correct map references |
3 |
1170 |
Sun, 07 March 2021 15:35 By: Ed Willink |
QVTo apply stereotype |
4 |
1135 |
Sat, 06 March 2021 13:32 By: Ed Willink |
allSubobjectsOfType works with some types. |
2 |
2003 |
Mon, 01 February 2021 09:36 By: Ed Willink |
QVTo transformation from command line |
11 |
6286 |
Fri, 13 November 2020 19:00 By: Ed Willink |
Multiple source objects to single target object |
2 |
2540 |
Fri, 13 November 2020 16:17 By: pere joseph rodríguez |
Create references between models |
4 |
1250 |
Fri, 13 November 2020 15:31 By: pere joseph rodríguez |
Compilation errors found in unit when calling QVTo transform calling QVTo transform from standalone java |
4 |
3436 |
Tue, 18 August 2020 11:33 By: Christopher Gerking |
Could not find unit 'platform:/resource QVTO Transformation |
4 |
3130 |
Tue, 18 August 2020 11:25 By: Christopher Gerking |
Adding EAttributes to EStructuralfeatures |
2 |
37735 |
Tue, 18 August 2020 11:18 By: Christopher Gerking |
[QVTo] No constructor defined, using implicit constructor |
2 |
933 |
Tue, 18 August 2020 09:09 By: Francesco Bedini |
Problems when applying UML profile to an UML model Profiling and stereotyping an UML model |
1 |
10288 |
Fri, 13 September 2019 20:49 By: Ed Willink |
UML activity diagram to Simulink |
1 |
36949 |
Fri, 13 September 2019 20:40 By: Ed Willink |
Executing query standalone mode and retrieve results Get empty List |
2 |
23031 |
Sun, 04 August 2019 03:26 By: Daniel San Martín |
Announce QVTo 3.9.2 |
0 |
18346 |
Wed, 20 March 2019 15:21 By: Ed Willink |
Eclipse QVTo latest P2 repos |
0 |
2598 |
Tue, 04 December 2018 07:05 By: Ed Willink |
Error while generating Diagram Editor Gen Model in Luna SR2 |
2 |
3277 |
Mon, 12 November 2018 09:10 By: Ed Willink |
Announce QVTo 3.9.0 |
0 |
5598 |
Wed, 19 September 2018 15:32 By: Ed Willink |
[QVTo] How to mapp association between two classes |
5 |
6031 |
Mon, 17 September 2018 07:10 By: Ed Willink |
creating operation parameters creating operation parameters with ParameterDirectionKind return |
2 |
2144 |
Thu, 06 September 2018 17:19 By: Ed Willink |
2 |
2181 |
Thu, 06 September 2018 14:51 By: Siegfried Nolte |
About Family2Person Transformation |
8 |
4406 |
Fri, 13 July 2018 08:03 By: ashrafur rahman |
Using QVTo with Xtext |
6 |
4167 |
Wed, 25 April 2018 10:55 By: Ed Willink |
How to use an external class as a black-box library? |
3 |
2898 |
Sat, 14 April 2018 14:38 By: Denis Nikiforov |
generating .qvtotrace file fails when i try to run the operational QVT Project it goes wrong with the following errors |
9 |
5656 |
Tue, 03 April 2018 10:04 By: Ed Willink |
a wrong with qvt When I new a *.qvto file , it goes wrong |
2 |
4556 |
Fri, 30 March 2018 08:47 By: wang shiyu |
How to import a library |
4 |
3422 |
Fri, 23 March 2018 14:28 By: Ed Willink |
Running a QVT transformation headless or from JUnit Running a QVT transformation headless or from JUnit |
1 |
2266 |
Wed, 21 March 2018 10:18 By: Ed Willink |
QVTO - Calling a mapping versus clone Calling a mapping versus clone |
2 |
2375 |
Thu, 15 March 2018 09:37 By: Bruce Trask |
Basic syntax question in mapping Basic syntax question in mapping |
3 |
2870 |
Wed, 14 March 2018 12:50 By: Ed Willink |
Documentation for QVTO Documentation for QVTO |
11 |
6992 |
Tue, 13 March 2018 14:22 By: Bruce Trask |
How to trigger XMI transformation in programed java EMF, QVT, Ecore |
1 |
3728 |
Fri, 28 July 2017 17:07 By: Ed Willink |
EMF to EMF Transformation Creating custom EClass objects |
1 |
3684 |
Wed, 28 June 2017 18:03 By: Ed Willink |
apply stereotype on element Problem! I use applySereotype(),but there's no corresponding element. |
6 |
11048 |
Thu, 30 March 2017 14:30 By: Siegfried Nolte |
Semantics of xmap on a null value |
1 |
3213 |
Mon, 20 February 2017 15:24 By: Ed Willink |
Serialization of QVT-O Traces |
2 |
4293 |
Mon, 09 January 2017 09:43 By: Stephan Seifermann |
set XMI id of object during a QVTo transformation |
1 |
3251 |
Wed, 04 January 2017 10:48 By: Ed Willink |
Refine profiled model in QVT-OML |
5 |
3853 |
Mon, 07 November 2016 16:40 By: Ferdinando Sodano |
How to set tagged values after applying a profile |
3 |
3416 |
Tue, 01 November 2016 10:21 By: Ed Willink |
setValue() a Stereotype with another Stereotype |
1 |
4757 |
Mon, 31 October 2016 12:57 By: Ferdinando Sodano |
Passing external variables from eclipse External variables in QVTo |
5 |
4588 |
Mon, 26 September 2016 20:05 By: Sergey Boyko |
Cannot add stereotypes when launching the QVTo transform programmatically from Java I provide a minimal example to try out. Any help on how to make it work? |
2 |
3899 |
Tue, 30 August 2016 08:04 By: Christopher Gerking |
Metemodel registry |
1 |
4738 |
Thu, 28 July 2016 05:55 By: Ed Willink |
QVT 1.3 |
0 |
4735 |
Wed, 13 July 2016 09:42 By: Ed Willink |
Incremental transformation not working because input traces are ignored |
14 |
9324 |
Tue, 05 July 2016 12:47 By: Christian Damus |
Model Abstrction |
3 |
3255 |
Fri, 17 June 2016 13:39 By: Laurence Robert |
Mapping reference |
1 |
3186 |
Mon, 30 May 2016 09:29 By: Ed Willink |
Use of quotations |
1 |
3344 |
Fri, 27 May 2016 21:07 By: Ed Willink |
QVTO - Import Works in 3.4 but not in 3.6 |
3 |
5483 |
Sun, 22 May 2016 10:23 By: Christopher Gerking |
Difference between arrow(->) and dot(.) in qvto |
1 |
3293 |
Fri, 13 May 2016 13:24 By: Ed Willink |
Qvt Simple Question Error solving |
1 |
3227 |
Tue, 10 May 2016 16:21 By: Ed Willink |
Generate QVTo-file |
6 |
7729 |
Tue, 05 April 2016 13:22 By: Uwe Ritzmann |
Cannot find imported compilation unit |
4 |
8090 |
Fri, 18 March 2016 15:01 By: Christopher Gerking |
BlackBox: can not find .class files even in neon (qvt 3.5) |
1 |
6304 |
Fri, 18 March 2016 14:55 By: Christopher Gerking |
QVT to attach elements as children to a root element |
3 |
4922 |
Tue, 01 March 2016 18:52 By: Ed Willink |
[QVTo] How to load separated (externalized) profile applications in QVTo transformations ? |
0 |
6286 |
Tue, 09 February 2016 20:23 By: Toni Siljamäki |
QVTo standalone: EMF package registries w/o maven/testng? By: Eclipse User on Thu, 28 January 2016 |
12 |
10582 |
Tue, 09 February 2016 14:46 By: Eclipse User |
Keeping xmi:id for migration |
3 |
3972 |
Fri, 08 January 2016 17:35 By: Ed Willink |
[QVTo] Transform an object by a condition. |
5 |
4742 |
Fri, 08 January 2016 10:52 By: Ed Willink |
QVTo Trace Editor doesn't show properties of elements |
3 |
3267 |
Tue, 15 December 2015 13:45 By: Ed Willink |
Implicit conversion of string literals into instances of custom data types |
7 |
6105 |
Wed, 09 December 2015 14:29 By: Ed Willink |
bpmn2uml |
7 |
4682 |
Thu, 26 November 2015 14:30 By: Srdjan Tica |
Run multiple transformations in parallel |
4 |
3174 |
Wed, 25 November 2015 14:56 By: Ed Willink |
Modified parameter 'self' is input only |
1 |
3387 |
Mon, 23 November 2015 13:44 By: Christopher Gerking |
Tracing QVT interpreter Tracing QVT interpreter |
3 |
3013 |
Thu, 05 November 2015 14:59 By: Ed Willink |
Installing QVTo 3.5 on Eclipse Kepler |
8 |
5250 |
Sat, 31 October 2015 19:18 By: Ed Willink |
RAP in combination with QVT (com.ibm.icu issue) |
0 |
5055 |
Fri, 09 October 2015 09:48 By: Karel Gardas |
QVTo object serialization manipulating QVT Operational object |
1 |
2662 |
Tue, 15 September 2015 20:30 By: Ed Willink |
QVTo Abstract Syntax Tree Fetch I want to fetch the AST |
1 |
2454 |
Thu, 27 August 2015 13:52 By: Ed Willink |
Mapping of classes N to 1 |
2 |
8996 |
Thu, 20 August 2015 12:37 By: Abhishek Kappattanavar |
Javadocs Are the QVTo Javadocs available? |
1 |
2869 |
Wed, 19 August 2015 13:17 By: Gunnar Teege |
[QVTo] Transform a unique element of the model I need to conserve all the model structure but transform one element only. |
14 |
9377 |
Thu, 06 August 2015 14:38 By: Gonzalo Bressan Zuber |
[QVTo] Mapping that needs to modify initial Model I am having troubling figuring out how to make a mapping function that needs to create dependencies which did not exist on the initial metamodel |
1 |
2704 |
Thu, 23 July 2015 16:03 By: João Bastos |
objectsOfType problem in Mars release |
0 |
3386 |
Sat, 27 June 2015 05:49 By: Ed Willink |
Run qvto transformation I need run a transformation |
1 |
3720 |
Sat, 27 June 2015 05:41 By: Ed Willink |
Map one object into two models |
5 |
4321 |
Thu, 25 June 2015 08:11 By: Denis Nikiforov |
Blackbox library in a standalone QVTo transformation |
4 |
10260 |
Thu, 25 June 2015 05:29 By: Denis Nikiforov |
java M2MT I nedd transform a java model in another java model |
12 |
5718 |
Fri, 19 June 2015 13:13 By: Gonzalo Bressan Zuber |
Java model transformation with qvto Transform a java models |
3 |
3982 |
Fri, 12 June 2015 08:39 By: Ed Willink |
Call qvto in Java : applyStereotype() does not work |
2 |
3607 |
Fri, 29 May 2015 08:24 By: Thanh Liem Phan |
intermediate classes in library? |
10 |
6487 |
Wed, 27 May 2015 14:14 By: Ed Willink |
Transformation via Java class: Import Library? |
1 |
4627 |
Wed, 27 May 2015 13:14 By: Christopher Gerking |
applyStereotype() and using uml stereotype bug resolved but still not working as expected ... Is there any example to show the correct way of using uml stereotype |
1 |
5081 |
Tue, 26 May 2015 06:26 By: Thanh Liem Phan |
QVTo Trying to convert EDate into DateTime (XMLGregorianCalendar)) |
4 |
5394 |
Thu, 07 May 2015 13:17 By: Christopher Gerking |
library or example for good logging |
2 |
3709 |
Tue, 05 May 2015 07:53 By: Thomas Busch |
template function in QVT? |
2 |
3655 |
Tue, 05 May 2015 07:41 By: Thomas Busch |
transformation to adopt on metamodel-change? |
5 |
5084 |
Mon, 04 May 2015 06:28 By: Thomas Busch |
UML Tool + QVT An integration between UML Tool and QVT |
11 |
7317 |
Thu, 16 April 2015 11:04 By: eunjung park |
Sequence Diagrams Repository |
0 |
4123 |
Sat, 11 April 2015 19:02 By: Andreza Mising name |
Execute QVTo transformation using a product configuration |
3 |
3851 |
Fri, 10 April 2015 08:01 By: Carlos Gomez |
QVT 1.2 |
0 |
2832 |
Fri, 27 February 2015 16:24 By: Ed Willink |
determinism on QVTo execution |
2 |
3484 |
Wed, 28 January 2015 10:26 By: Thomas Busch |
Compilation errors found when running a transformation inside the jboss container |
6 |
4957 |
Mon, 26 January 2015 13:04 By: Christopher Gerking |
handling of abstract types |
3 |
3573 |
Wed, 17 December 2014 16:40 By: Daniele Pala |
Including UML primitive types in result of transformation |
1 |
3329 |
Tue, 02 December 2014 18:11 By: Ed Willink |
Storing and loading .qvtox A problem in loading previously stored .qvtox files |
9 |
7862 |
Mon, 24 November 2014 13:06 By: Trajche Masinov |
Transform qvto file standalone |
3 |
4293 |
Tue, 11 November 2014 13:47 By: Ed Willink |
Error while generating Diagram Editor Gen Model |
4 |
6355 |
Thu, 06 November 2014 12:52 By: Christopher Gerking |
QVT standard library extension |
3 |
4020 |
Thu, 16 October 2014 10:55 By: Ed Willink |
Build with Jenkins |
0 |
3271 |
Wed, 08 October 2014 20:58 By: Lindung Manik |
Running QVTo in a web-based application |
2 |
3934 |
Mon, 08 September 2014 11:00 By: Ed Willink |
Dynamic set of input models |
3 |
6631 |
Mon, 08 September 2014 08:03 By: Sama Elrawy |
Run exported transformation |
3 |
3983 |
Thu, 31 July 2014 07:35 By: Rolf Theunissen |
How to evaluate OCL expression that is part of the input model |
2 |
4550 |
Tue, 29 July 2014 15:29 By: Wilbert Alberts |
Obtain URI from evaluation environment in RC4 |
2 |
3917 |
Fri, 13 June 2014 12:36 By: Sergey Boyko |
How to use QVTo transformation |
1 |
2963 |
Thu, 12 June 2014 09:51 By: Ed Willink |
Use of Libraries in different Projects |
3 |
6535 |
Thu, 01 May 2014 16:00 By: Christine Gerpheide |
Error with abstract mapping with lastest version of QVTo |
3 |
4845 |
Fri, 18 April 2014 06:43 By: Sergey Boyko |
I want to give you a QVTo test coverage plugin |
2 |
3969 |
Wed, 16 April 2014 21:35 By: Christine Gerpheide |
Change in Helper/Mapping behaviour from QVTO 3.2.2 to 3.3.0 |
4 |
7066 |
Tue, 25 March 2014 13:36 By: Gunnar Teege |
Pass a type as an argument |
1 |
2896 |
Thu, 20 March 2014 09:41 By: Ed Willink |
Swapping out EvaluationVisitor to add instrumentation (dependency injection...?) |
10 |
7009 |
Wed, 19 March 2014 19:53 By: Sergey Boyko |
Adding qvto editor in RCP application |
10 |
5834 |
Wed, 12 March 2014 15:40 By: ModelGeek Mising name |
helper with side effect in QVT - OML helper with side effect in QVT - OML |
2 |
4080 |
Wed, 12 March 2014 07:38 By: Sergey Boyko |
Running qvto Transformations with in/out Metamodels registered by Metamodel-Plugins |
1 |
4011 |
Mon, 10 March 2014 15:39 By: Ed Willink |
Research survey to improve quality of QVTo code Please consider contributing if you have experience in QVTo |
1 |
3230 |
Sun, 09 March 2014 10:57 By: Christine Gerpheide |
Invalid transformation Problem |
10 |
7917 |
Mon, 03 March 2014 15:49 By: ModelGeek Mising name |
Transformations chaining for inout model passing the updated model (inout) in calling another transformation |
6 |
6863 |
Thu, 27 February 2014 14:45 By: Sergey Boyko |
QVTo code samples for project Have any transformations lying around? |
0 |
23598 |
Tue, 18 February 2014 10:35 By: Christine Gerpheide |
Input model to be used by Operational QVT Interpreter By: Eclipse User on Wed, 29 August 2012 |
3 |
5572 |
Tue, 18 February 2014 10:15 By: ModelGeek Mising name |
Unit testing tools for QVTo? |
4 |
8223 |
Tue, 18 February 2014 09:24 By: Christine Gerpheide |
Failed to save model to platform:/resource Error while running a qvto transformation |
5 |
6409 |
Sun, 16 February 2014 18:00 By: Ed Willink |
Stereotype not applied to the xmi output file ! applyStereotype() does not really apply/add stereotype to the output xmi file even getAppliedStereotypes() return correct result |
1 |
19139 |
Fri, 14 February 2014 01:50 By: Naif Mokhayesh |
Setting a configuration property from Java |
4 |
7349 |
Tue, 28 January 2014 07:57 By: nicholas pacini |
Transforming two model instances into a single model instance Parameter passing QVTO |
3 |
6711 |
Thu, 23 January 2014 16:53 By: Ed Willink |
Posible enhacements in the QVT code |
12 |
10322 |
Wed, 08 January 2014 18:19 By: Victor Roldan Betancort |
Plz help me [ QVT Relational] |
1 |
3393 |
Fri, 03 January 2014 14:49 By: Ed Willink |
goal for new objects in a transformation |
6 |
7808 |
Thu, 02 January 2014 07:44 By: Ed Willink |
Execute native OCL query in qvt-o code |
5 |
17883 |
Sun, 22 December 2013 16:35 By: Ed Willink |
OCL Errors in StandAlone QVTo |
4 |
5916 |
Fri, 13 December 2013 15:36 By: Ed Willink |
How to create javax.xml.namespace.QName? |
0 |
36093 |
Fri, 13 December 2013 05:45 By: Denis Nikiforov |
Redirect log to stdout in standalone QVTo-script |
2 |
4855 |
Wed, 04 December 2013 04:50 By: Denis Nikiforov |
Does Eclipse QVTo implementation support typedef? |
1 |
3087 |
Tue, 26 November 2013 12:15 By: Ed Willink |
Writing it as extension for QVTo in Java Writing it as extension for QVTo in Java |
1 |
8325 |
Sun, 24 November 2013 08:27 By: Ed Willink |
one input model and variable number of output models one input model and variable number of output model |
1 |
4050 |
Tue, 29 October 2013 07:17 By: Ed Willink |
metamodel declaration & UML profile |
3 |
5033 |
Mon, 14 October 2013 07:14 By: BaiChuan Nie |
Creating objects in secondary extents |
7 |
8857 |
Mon, 23 September 2013 10:07 By: Vlad Gheorghe |
Retrivieving stereotypes tagged values |
2 |
4634 |
Wed, 04 September 2013 09:10 By: saadia dhouib |
Problem with Stereotype application Problem with Stereotype application |
4 |
7419 |
Mon, 02 September 2013 09:59 By: Ed Willink |
Ideas for higher-order in QVTo |
3 |
5237 |
Sat, 20 July 2013 21:50 By: Christopher Gerking |
Object type issues can't resolve objects from type |
2 |
3389 |
Wed, 10 July 2013 18:05 By: lin zhang |
Shortcut for subpackages? |
3 |
5423 |
Mon, 08 July 2013 15:19 By: Ed Willink |
Applying Stereotype to model element |
3 |
7420 |
Tue, 18 June 2013 10:06 By: Thorsten Koch |
Can a mapping call itself? By: Emre T on Mon, 03 June 2013 |
2 |
5224 |
Mon, 17 June 2013 11:04 By: Christopher Gerking |
Libraries necessary to execute transformation programmatically in Juno |
6 |
6304 |
Thu, 13 June 2013 20:17 By: juan velez |
[Announce] Eclipse QVT Operational 3.3.0 (Kepler) RC3 is now available |
0 |
7773 |
Tue, 04 June 2013 10:09 By: Ed Willink |
Manual transformation vs. programmatic transformation By: Emre T on Mon, 03 June 2013 |
3 |
4879 |
Mon, 03 June 2013 14:40 By: Ed Willink |
Jumping over abstract model elements of source By: Emre T on Fri, 31 May 2013 |
7 |
10935 |
Sat, 01 June 2013 00:23 By: Alan McMorran |
A case scenario regarding the selection of mappings based on composed model elements By: Emre T on Thu, 30 May 2013 |
5 |
11498 |
Sat, 01 June 2013 00:14 By: Alan McMorran |
how to use two target sources? By: Emre T on Mon, 27 May 2013 |
2 |
6644 |
Thu, 30 May 2013 22:49 By: Emre T |
Stereotypes and multi-valued attributes Can't get the value of a multi-valued attribute defined in a Stereotype |
8 |
12451 |
Sun, 26 May 2013 08:48 By: Sergey Boyko |
Generalization relationship between stereotypes |
3 |
10154 |
Sat, 25 May 2013 22:08 By: Sergey Boyko |
[Announce] Eclipse QVT Operational 3.3.0 (Kepler) RC1 is now available |
0 |
38701 |
Tue, 21 May 2013 14:39 By: Ed Willink |
QVT project organization |
2 |
7145 |
Wed, 15 May 2013 14:56 By: Ed Willink |
Accessing stereotypes defined in SysML profiles with packages ERROR: stereotype XXX::YYY::ZZZ is not applicable to element org.eclipse.uml2.uml.internal.impl.PortImpl@... |
3 |
7506 |
Wed, 15 May 2013 12:05 By: Matteo M. |
[Announce] Eclipse QVT Operational 3.3.0 (Kepler) M7 is available |
0 |
2994 |
Wed, 08 May 2013 09:41 By: Adolfo Sanchez-Barbudo Herrera |
0 |
2962 |
0 |
3325 |
0 |
3076 |
0 |
3957 |
0 |
3084 |
0 |
3048 |
0 |
3241 |
