Topic |
Replies |
Views |
Last message |
Get original mouse coordinates when opening context menu in headers |
2 |
873 |
Thu, 04 January 2024 11:10 By: Jan-Philipp Steghöfer |
NatTable 2.2.1 released |
0 |
906 |
Thu, 16 November 2023 07:16 By: Dirk Fauth |
Issue with zoom out text size |
1 |
702 |
Thu, 26 October 2023 07:33 By: Dirk Fauth |
NatTable @ GitHub |
0 |
944 |
Fri, 20 October 2023 05:34 By: Dirk Fauth |
Default corner style/painter |
2 |
531 |
Thu, 07 September 2023 16:24 By: Jonathan Menzies |
How to programmatically select a cell in the row header? |
2 |
746 |
Wed, 06 September 2023 20:30 By: Jonathan Menzies |
NatTable 2.2.0 released |
0 |
4920 |
Fri, 30 June 2023 13:11 By: Dirk Fauth |
NatTable : how to show a minimum of 10 rows if scrollable? NatTable : how to show a minimum of 10 rows if scrollable? |
3 |
556 |
Sat, 24 June 2023 19:25 By: Dirk Fauth |
EMF forms EMF forms with Multiselect Dropdown |
1 |
919 |
Fri, 12 May 2023 07:46 By: Dirk Fauth |
Remove row number |
4 |
982 |
Tue, 09 May 2023 14:58 By: Yann Binot |
Mysterious popup text editor on Linux - ComboBoxCellEditor |
4 |
1550 |
Thu, 27 April 2023 05:45 By: Dirk Fauth |
questions about LinkClickConfiguration |
2 |
798 |
Wed, 19 April 2023 15:22 By: Edit Mihancea |
0 |
1032 |
Tue, 18 April 2023 08:16 By: Edit Mihancea |
NatTable 2.1.0 released |
0 |
1242 |
Fri, 31 March 2023 08:07 By: Dirk Fauth |
Buffering for tables |
1 |
747 |
Sun, 19 March 2023 06:50 By: Dirk Fauth |
Formatting numbers in excel export |
14 |
2932 |
Fri, 24 February 2023 07:52 By: Uwe Peuker |
Any plans for Web/Theia based NatTable? |
2 |
1610 |
Thu, 19 January 2023 21:13 By: Jonathan Menzies |
NatTable 2.0.5 released |
0 |
1403 |
Tue, 20 December 2022 16:10 By: Dirk Fauth |
NatTable 2.0.4 released |
0 |
1334 |
Wed, 14 December 2022 20:02 By: Dirk Fauth |
Multiple Nattables inside one container |
1 |
974 |
Mon, 12 December 2022 09:36 By: Dirk Fauth |
java.lang.IllegalStateException: Could not find any implementations of MutableSetFactory java.lang.IllegalStateException: Could not find any implementations of MutableSetFactory |
1 |
979 |
Mon, 14 November 2022 15:41 By: Dirk Fauth |
Vertical scroll bar is appearing when filter applied wrt base list with empty rows |
4 |
1144 |
Fri, 11 November 2022 15:14 By: Indana Amaresh |
How to update row group header while filtering |
6 |
1914 |
Thu, 10 November 2022 17:00 By: Indana Amaresh |
Fill down function |
4 |
1168 |
Wed, 02 November 2022 20:51 By: nicolas Bunnet |
TextCellEditor causes a "SWT Resource was not properly disposed" |
3 |
1575 |
Thu, 15 September 2022 20:13 By: Dirk Fauth |
How to add a button to a table cell How to add a button to a table cell and a pop-up window when the button is clicked |
2 |
3051 |
Tue, 13 September 2022 06:31 By: Tianyu Wu |
How to remove or hide default row numbers when using row group header layer in composite layer |
6 |
3376 |
Sun, 28 August 2022 22:07 By: Indana Amaresh |
How to create more than two level column grouping in nattable |
5 |
2725 |
Wed, 17 August 2022 11:01 By: Indana Amaresh |
NatTable 2.0.3 released |
0 |
1682 |
Tue, 09 August 2022 06:34 By: Dirk Fauth |
Support for Remote Application Plattform (RAP) |
3 |
1178 |
Wed, 27 July 2022 11:49 By: Dirk Fauth |
Undo Changes Step by step is working fine but when we apply filter its Not working? |
1 |
944 |
Mon, 25 July 2022 05:58 By: Dirk Fauth |
Once delete Nattable row cursor should goes for next line but after grouping its not happen.?? |
1 |
822 |
Mon, 25 July 2022 05:53 By: Dirk Fauth |
Classloading issue with slf4j and nattable |
1 |
849 |
Thu, 21 July 2022 10:07 By: Dirk Fauth |
Stop horizontal scrolling when extending selection mit Down-key |
6 |
4927 |
Thu, 14 July 2022 12:21 By: Dirk Fauth |
User resizing of columns is wrong |
11 |
4579 |
Wed, 22 June 2022 14:40 By: Mokhtar Alshubei |
Combo boxes for items with identical string representation |
2 |
2261 |
Thu, 16 June 2022 17:14 By: Louis Detweiler |
Freeze columns programmatically |
2 |
5643 |
Mon, 13 June 2022 14:23 By: Mokhtar Alshubei |
FreezeColumn Nattable 2.0.2 not working not working the way it was in 1.5.0 |
8 |
3050 |
Mon, 13 June 2022 11:53 By: Mokhtar Alshubei |
Custom GridLineCellLayerPainter issue with RowReorderLayer |
2 |
3800 |
Thu, 09 June 2022 21:55 By: Louis Detweiler |
RichTextPainter with subscript and superscript Text formatting with subscript and superscript |
1 |
1628 |
Fri, 20 May 2022 13:17 By: Dirk Fauth |
Row Filtering issue Problems getting filtering to work |
5 |
1856 |
Tue, 10 May 2022 14:45 By: Dirk Fauth |
Nattable fill by drag selection data How to get drag copied data |
1 |
1498 |
Fri, 06 May 2022 04:14 By: Dirk Fauth |
Nebula NatTable Integer column Sorting Registering custom comparator for integer column sorting does not work |
2 |
2046 |
Fri, 29 April 2022 12:18 By: Tejamurthy Shivakumar |
Highlight Row reorder swapping of rows Highlighting swapped rows uses old label |
2 |
1074 |
Thu, 21 April 2022 17:50 By: Dirk Fauth |
Combine Excel-like filters and drop-down lists with text search in the same table The ComboBoxFilterRowHeaderComposite seems to have problems when we try to replace the CellEditor for some columns |
3 |
1478 |
Tue, 12 April 2022 04:14 By: Dirk Fauth |
Column Width Listener Is it possible to add a column width listener? |
3 |
2201 |
Wed, 06 April 2022 14:10 By: Dirk Fauth |
How to hide Images (Labels) Icons are replacing column headers, how to switch back and forth |
2 |
1865 |
Mon, 21 March 2022 09:24 By: Peter Vilhelmsen |
ComboBoxCellEditor events on linux, a follow up to the mac issue |
1 |
1610 |
Wed, 09 March 2022 05:35 By: Dirk Fauth |
NatTable 2.0.2 released |
3 |
4114 |
Fri, 14 January 2022 06:56 By: Dirk Fauth |
How we can undo changes in Nattable like we did in excel? is it possible to undo changes in nattable? |
9 |
1901 |
Wed, 17 November 2021 11:10 By: Dirk Fauth |
How we can apply filter by color on Nattable like we did in excel? is it possible ? if yes then could you please tell me how we can achieve it. Thanks in Advance |
4 |
1461 |
Mon, 15 November 2021 06:55 By: Prashant Pawar |
natTable Focus natTable selection |
1 |
825 |
Tue, 09 November 2021 09:05 By: Dirk Fauth |
dynamic coloring of cells using CellOverrideLabelAccumulator with filtering/grouping/sorting Issue with coloring cells using CellOverrideLabelAccumulator when filtering/sorting/grouping is applied |
1 |
782 |
Mon, 20 September 2021 13:54 By: Dirk Fauth |
natExporter.exportMultipleNatTables tables are overlapping |
4 |
1167 |
Wed, 15 September 2021 10:55 By: Dirk Fauth |
filter filtered data |
3 |
2040 |
Mon, 06 September 2021 09:38 By: Dirk Fauth |
Nattable added keybindings |
1 |
859 |
Thu, 02 September 2021 03:29 By: Dirk Fauth |
Closing combo box dropdowns when leaving NatTable editor |
3 |
1151 |
Thu, 02 September 2021 03:24 By: Dirk Fauth |
coloring of nattable cells dynamically coloring of nattable cells dynamically with row and column index during runtime |
4 |
858 |
Wed, 25 August 2021 18:29 By: Vinod Gangal |
Drag and Drop in a TreeLayer How to do drag and drop in a TreeLayer |
7 |
1297 |
Mon, 16 August 2021 14:59 By: Dirk Fauth |
UpdateDataCommand + ViewportLayer |
3 |
974 |
Thu, 05 August 2021 14:04 By: Dirk Fauth |
Is Nattable Java 11 compatible ? |
1 |
1011 |
Thu, 05 August 2021 03:25 By: Dirk Fauth |
Create a tree dynamically with NatTable NatTable tree without GlazedLists |
2 |
878 |
Tue, 15 June 2021 23:33 By: Laksono Adhianto |
NatTable 2.0.1 released |
0 |
2091 |
Mon, 07 June 2021 10:47 By: Dirk Fauth |
Table cell is moving after Return |
2 |
693 |
Thu, 27 May 2021 21:09 By: Ralf Heydenreich |
Filter Not working when column cell value contains "*" If filter is applied on my Nattable column, if that column has a value which contains "*" in it at any position, then filter does not work correctly. |
6 |
2894 |
Thu, 13 May 2021 07:04 By: Aswin Kumar |
ComboBoxCellEditor events on mac ComboBoxCellEditor |
3 |
2016 |
Thu, 06 May 2021 04:40 By: Dirk Fauth |
Possible Bug Report for Single Select + Use Checkbox Combobox Cell Editors |
3 |
2771 |
Thu, 29 April 2021 05:10 By: Dirk Fauth |
First key press deleted on macOS |
4 |
1125 |
Mon, 12 April 2021 09:32 By: Thomas Krause |
Tracking of data changes |
2 |
1070 |
Mon, 12 April 2021 09:22 By: Alexandra Tritean |
How to realize print preview? |
0 |
1647 |
Wed, 07 April 2021 02:21 By: kevent smith |
Editing UTF-8 text |
5 |
1367 |
Mon, 22 March 2021 06:19 By: Alexandra Tritean |
Summary row layer with mutliple rows |
1 |
661 |
Thu, 25 February 2021 14:37 By: Dirk Fauth |
NatTable is not redrawn when ShowRowPositionsEvent is triggered |
4 |
1014 |
Thu, 18 February 2021 14:23 By: Yann Mortier |
Multi Cell Editor Multi Cell Editor - Different cells with Different LOV values |
4 |
1027 |
Wed, 27 January 2021 09:29 By: Aswin Kumar |
NatTable add header row cell How can I add a header row cell with an image, that triggers a delete row action? |
3 |
1759 |
Sat, 23 January 2021 06:44 By: Dirk Fauth |
Hierarchical Nat table Dynamic column |
2 |
1078 |
Wed, 06 January 2021 04:42 By: anu singh |
Nattable Dark theme and white patch |
4 |
1565 |
Tue, 22 December 2020 20:03 By: Santhosh Kumar |
NatTable 2.0 released |
0 |
3279 |
Wed, 16 December 2020 17:43 By: Dirk Fauth |
Scrolling changing indexes |
5 |
1333 |
Wed, 09 December 2020 05:45 By: Alexandra Tritean |
Please test the latest NatTable 2.0 SNAPSHOT |
0 |
2010 |
Thu, 03 December 2020 21:03 By: Dirk Fauth |
Column widths - scaled / unscaled |
4 |
1360 |
Thu, 26 November 2020 10:52 By: Klaus Reger |
Drag the mouse to select multiple row headers to select multiple rows |
4 |
1902 |
Thu, 19 November 2020 01:36 By: kevent smith |
Unit Tests - Issues with timeout |
1 |
975 |
Wed, 11 November 2020 15:33 By: Dirk Fauth |
TreeLayer and RowReorderLayer -> supported? |
2 |
1108 |
Thu, 15 October 2020 11:58 By: Vincent Lorenzo |
StackOverFlow Error |
8 |
3283 |
Fri, 02 October 2020 10:10 By: Dirk Fauth |
Same package in multiple versions javax.annotation is twice in p2 repo |
1 |
873 |
Fri, 25 September 2020 04:32 By: Dirk Fauth |
How to get the selected object from the tree table not able to get the exact selected object from the tree table |
2 |
3229 |
Mon, 14 September 2020 10:08 By: Dirk Fauth |
Scrolling changing style |
2 |
1242 |
Tue, 08 September 2020 07:07 By: Alexandra Tritean |
How to change the color of the only some part of the string in the cell to change the color of the only some part of the string |
2 |
1367 |
Mon, 31 August 2020 05:23 By: Chinniah Govindasamy |
FilterLayer is it possible to add filterLayer at each root level attribute By: P M on Wed, 12 August 2020 |
1 |
880 |
Thu, 13 August 2020 03:36 By: Dirk Fauth |
How to change the color of the grid lines in the nattable I want to change the color of all the lines inside the table in to white or disappear |
2 |
1424 |
Fri, 31 July 2020 18:00 By: Chinniah Govindasamy |
How to remove alternate row colors. I want all my rows in same color |
2 |
1078 |
Thu, 30 July 2020 05:54 By: Chinniah Govindasamy |
Nattable compatibility with OpenJDK Migration from Oracle JDK to OpenJDK |
1 |
998 |
Thu, 23 July 2020 16:55 By: Dirk Fauth |
Right-Click-Selection-Update with open Context Menu |
3 |
2199 |
Thu, 23 July 2020 11:59 By: Dirk Fauth |
FormText in Cell |
2 |
1248 |
Tue, 21 July 2020 09:20 By: Benedict Wright |
Row spanning not working when table is scrolled Row span displays as individual row when nattable is scrolled |
3 |
1253 |
Thu, 16 July 2020 09:42 By: Dirk Fauth |
summary row add summary row in hierarchical nat table |
1 |
1604 |
Wed, 08 July 2020 11:06 By: Dirk Fauth |
Adding item to a filtered List |
4 |
1422 |
Thu, 11 June 2020 11:23 By: Ralf Heydenreich |
Automatically Wrap the text in a Gridlayer Wrap Text in Grid Layer |
2 |
1937 |
Tue, 19 May 2020 09:57 By: Palraj Jayaraj |
problem with column hide reproduceable with modified example |
4 |
1416 |
Thu, 14 May 2020 10:20 By: Ludwig Moser |
update/refresh NatTable after updating the POJO |
9 |
7455 |
Wed, 13 May 2020 16:23 By: Chinniah Govindasamy |
How to detect, if underlying data has changed, when editing a cell |
2 |
1302 |
Tue, 05 May 2020 13:28 By: Klaus Reger |
NatTable 2.0 Release Plans |
2 |
1410 |
Tue, 31 March 2020 20:04 By: Patrick Paulin |
Cell Editors not showing up |
3 |
1557 |
Wed, 25 March 2020 15:27 By: Dirk Fauth |
NatTable 2.0 - dynamic scaling |
0 |
5803 |
Thu, 05 March 2020 21:05 By: Dirk Fauth |
Modified values of a cell is getting set into other cell when columns are hidden/shown Modified values of a cell is getting set into other cell when columns are hidden/shown |
5 |
1693 |
Fri, 14 February 2020 11:02 By: Dirk Fauth |
Repository link for latest release |
2 |
1229 |
Wed, 22 January 2020 09:11 By: Aparna Argade |
Last Group headers not appearing for performance ColumnGroupHeaderLayer |
4 |
1519 |
Thu, 16 January 2020 13:39 By: Dirk Fauth |
Row height and icon scaling in Nattable with eclipse 19-09 |
12 |
4366 |
Thu, 09 January 2020 10:48 By: Dirk Fauth |
Instances of NatTable are beeing kept in memory after composite is disposed |
1 |
1243 |
Mon, 30 December 2019 08:26 By: Dirk Fauth |
NPE while saving State (with Filters |
6 |
1568 |
Sat, 28 December 2019 07:53 By: Ludwig Moser |
how to create a custom filter |
5 |
2013 |
Sat, 21 December 2019 06:59 By: Dirk Fauth |
Nattable saveState and loadState issue |
1 |
1171 |
Fri, 20 December 2019 22:29 By: Dirk Fauth |
"Widget is disposed" from NatTable.handleLayerEvent() |
1 |
1584 |
Fri, 20 December 2019 12:26 By: Dirk Fauth |
Displaying Dialog for multi edit of checkbox. |
3 |
1593 |
Fri, 20 December 2019 08:08 By: Dirk Fauth |
Row and column header disappear |
7 |
2428 |
Wed, 18 December 2019 09:08 By: Ralf Heydenreich |
Sorting a TreeTable at first level |
2 |
1410 |
Mon, 16 December 2019 10:28 By: Ralf Heydenreich |
Customize/Configure ColumnChooser |
3 |
1548 |
Wed, 04 December 2019 07:19 By: Dirk Fauth |
CellOverrideLabelAccumulator CellOverrideLabelAccumulator |
1 |
1233 |
Tue, 03 December 2019 20:58 By: Dirk Fauth |
Validation error style |
4 |
1468 |
Sat, 30 November 2019 07:34 By: zida wang |
0 |
2316 |
Fri, 29 November 2019 02:10 By: zida wang |
FormulaGrid |
3 |
1771 |
Thu, 28 November 2019 04:19 By: Dirk Fauth |
background image not showing in column header background image not showing in column header |
2 |
1859 |
Wed, 27 November 2019 05:45 By: dhruba kumar |
SWTBot and Nattable: wait until all pending updates are performed |
5 |
1503 |
Thu, 21 November 2019 13:55 By: Dirk Fauth |
List view is not updated while filtering Using GlazedListTreeData and ITreeRowModel |
4 |
1509 |
Thu, 21 November 2019 10:01 By: Ralf Heydenreich |
Changing the color of the freeze grid line |
2 |
1553 |
Mon, 18 November 2019 10:59 By: Stefan T |
Styling Grid : Windows OS Style |
1 |
1284 |
Fri, 15 November 2019 19:36 By: Dirk Fauth |
Select a row without the actual cell selection |
1 |
1464 |
Fri, 15 November 2019 15:19 By: Dirk Fauth |
Unbind cell selection with selected row |
0 |
1681 |
Mon, 11 November 2019 13:21 By: Alexey Kazakov |
Row Spanning |
2 |
1636 |
Fri, 15 November 2019 13:32 By: dhruba kumar |
Generating PDF in NatTable |
1 |
957 |
Tue, 12 November 2019 12:46 By: Dirk Fauth |
Trouble with content assist in TextCellEditor |
5 |
1748 |
Tue, 05 November 2019 09:44 By: Maria Fardig |
Comboboxcelleditor combo values based on cell value Comboboxcelleditor combo values based on cell value |
1 |
1023 |
Thu, 31 October 2019 21:05 By: Dirk Fauth |
Filter converted data |
9 |
4143 |
Wed, 30 October 2019 17:24 By: Dirk Fauth |
How to track drown RowSelectionEvents |
12 |
2818 |
Mon, 14 October 2019 10:41 By: Dirk Fauth |
Validation dialog popup multiple times |
3 |
5575 |
Wed, 25 September 2019 13:06 By: Dirk Fauth |
Custom TextMatchingMode Add new TextMatchingModes which could handle simple star regex. |
2 |
1381 |
Tue, 24 September 2019 14:01 By: Nikolai Chebanov |
Misbehaving two-level column groups |
28 |
13016 |
Mon, 23 September 2019 20:12 By: Dirk Fauth |
Column group header problem I have a problem trying to identify column groups with the same name |
4 |
3382 |
Mon, 23 September 2019 15:35 By: krishna kalvakuri |
EPL v2 |
0 |
11033 |
Fri, 20 September 2019 10:09 By: Dirk Fauth |
NatTable 1.6.0 |
0 |
9649 |
Wed, 18 September 2019 18:57 By: Dirk Fauth |
Custom Scrollbar Mousewheel Support |
3 |
16052 |
Tue, 03 September 2019 06:35 By: Dirk Fauth |
How to correctly register an Action on the GridRegion.Body Mouse.RMB |
2 |
1542 |
Fri, 30 August 2019 08:55 By: Ludwig Moser |
Wrong order after inserting a row into a NatTable |
4 |
2694 |
Tue, 27 August 2019 08:07 By: Ralf Heydenreich |
excel export excel export is creating formul from string |
8 |
4553 |
Thu, 22 August 2019 13:49 By: Dirk Fauth |
Alternatives for Nattable Alternatives for Nattable |
6 |
8491 |
Wed, 14 August 2019 06:35 By: girijanandan nucha |
can we span column Header cells using spanningDataLayer in Nattable can we span column Header cells using spanningDataLayer in Nattable |
3 |
2513 |
Mon, 12 August 2019 21:36 By: Dirk Fauth |
Focus next widget below NatTable How to focus-exit in NatTable? |
1 |
1686 |
Tue, 06 August 2019 14:59 By: Dirk Fauth |
Changing Font type of NatTable header dynamically MakingFont type of NatTable header as BOLD and NON-BOLD dynamically |
4 |
4598 |
Tue, 06 August 2019 10:02 By: Sharmila Naik |
SelectAll does not select all rows [solved] |
0 |
24160 |
Wed, 31 July 2019 07:24 By: Klaus Reger |
How to get notified, that the DataLayer has finished loading data |
3 |
2689 |
Wed, 24 July 2019 14:29 By: Dirk Fauth |
Sorting Not honoring applied style labels On single click sort the applied column labels are not getting arranged correctly |
3 |
1988 |
Sat, 22 June 2019 12:36 By: Dirk Fauth |
Labels not working with sorting Labels applied at Row level is not carry forward with Sorting |
1 |
3824 |
Mon, 17 June 2019 10:44 By: Dirk Fauth |
Adding a summary header for columns and rows |
5 |
4573 |
Fri, 07 June 2019 15:10 By: Dirk Fauth |
Nattable create cell value Nattable create cell value |
2 |
2895 |
Mon, 03 June 2019 09:26 By: Balachandran Palanisamy |
Prevent sort column |
7 |
5589 |
Fri, 24 May 2019 08:36 By: Dirk Fauth |
Vertical scrollbar shifts to the top after user clicks on cell at the bottom Vertical scrollbar shifts to the top after user clicks on cell at the bottom |
5 |
2846 |
Fri, 10 May 2019 11:13 By: Dirk Fauth |
Ad a overlay such as a "glaspane" over the whole table |
4 |
2248 |
Thu, 09 May 2019 13:30 By: Benedict Wright |
Date cell editor - set null for date column i want to set null date , but date picker does not show up if we do not set any date value |
1 |
4041 |
Thu, 09 May 2019 05:11 By: Dirk Fauth |
Duplicate elements created on sorting a tree implemented using Nattable Duplicate elements created on sorting a tree implemented using Nattable |
1 |
1431 |
Wed, 08 May 2019 14:18 By: Dirk Fauth |
Filtering combo box filtering |
20 |
11575 |
Mon, 29 April 2019 05:24 By: Dirk Fauth |
Filter column values using custom FILTER_DISPLAY_CONVERTER |
3 |
2639 |
Wed, 24 April 2019 18:52 By: Dirk Fauth |
Display loading state in table |
2 |
14272 |
Wed, 17 April 2019 14:06 By: Benedict Wright |
Multi Value Editor in NATTable How to add Multi Value editor in NAT table |
1 |
1698 |
Fri, 12 April 2019 20:11 By: Dirk Fauth |
Canonical way of clearing the content of a cell? By: na na on Thu, 11 April 2019 |
4 |
2449 |
Thu, 11 April 2019 14:13 By: na na |
How to reorder multiple columns via one mouse drag action |
1 |
2051 |
Mon, 08 April 2019 10:47 By: Dirk Fauth |
How to restore a column selection after hiding a row (via context menu or via api) |
3 |
2258 |
Mon, 08 April 2019 09:56 By: Hilger Steenblock |
Spanned Cells show not always the data of the first column |
4 |
2037 |
Fri, 15 March 2019 11:53 By: Niklas Kellner |
Filter restarting the row numbers from "1" After applying filter the displayed row numbers/ id's are starting from "1" |
1 |
2545 |
Wed, 20 February 2019 05:43 By: Dirk Fauth |
How to re-configure the column group header without a recreation of the layer stack |
1 |
1399 |
Tue, 19 February 2019 10:36 By: Dirk Fauth |
Sorting removes applied filters |
15 |
4670 |
Mon, 18 February 2019 13:42 By: Andreas Sturm |
NPE in SelectionLayer NPE in SelectionLayer |
4 |
2577 |
Mon, 18 February 2019 09:55 By: Dirk Fauth |
How show the Tooltip for part display cell(xxx...) |
7 |
6186 |
Tue, 12 February 2019 17:34 By: Alexander Till |
NatTableContentTooltip constructor for testing |
1 |
2305 |
Sat, 09 February 2019 06:15 By: Dirk Fauth |
Filtering Custom filtering using own DataProvider |
2 |
1809 |
Wed, 06 February 2019 16:11 By: Hallvard Traetteberg |
NatTable version 1.1.0 and Glazelist version 1.8.0 compatibility NatTable version 1.1.0 and Glazelist version 1.8.0 compatibility |
1 |
1285 |
Mon, 04 February 2019 09:25 By: Dirk Fauth |
ColumGroupHeader-Styling Issue |
2 |
1840 |
Mon, 28 January 2019 10:00 By: Mathias Jankow |
How to disable the empty vertical scrollbar painting if no row data is defined |
2 |
1973 |
Fri, 25 January 2019 12:25 By: Hilger Steenblock |
ComboBox Multiselect/Use Checkbox question |
3 |
3671 |
Wed, 23 January 2019 12:05 By: Parth Desai |
Font color for a substring in a cell Need to highlight a part of cell value with different colors |
1 |
1594 |
Thu, 17 January 2019 10:31 By: Dirk Fauth |
Problem with Tree and Hide Row The tree structure is broken by hiding rows |
7 |
3804 |
Thu, 10 January 2019 07:32 By: Dirk Fauth |
Dynamically set column span for a cell i want to randomly set column span for a cell based on value in other column |
1 |
1855 |
Tue, 08 January 2019 09:41 By: Dirk Fauth |
Problem with Column Group Reorder and Column Grouping by Value Using default configuration, column reorder seems broken |
2 |
2446 |
Tue, 11 December 2018 19:34 By: Yves Prelot |
How to configure the DefaultSelectionLayerConfiguration How to configure the DefaultSelectionLayerConfiguration to select additionally the next row with SHIFT+Arrow-Down |
4 |
2141 |
Sat, 08 December 2018 09:15 By: Hilger Steenblock |
How to configure the Selection Style to not override the text foreground color of a selected cell Selection Handling |
4 |
3104 |
Tue, 04 December 2018 15:41 By: Hilger Steenblock |
NatTable Tree Filtering Show path to parent, when child is selected from filter combo |
0 |
2914 |
Mon, 26 November 2018 10:46 By: Richie Martin Pasupuleti |
Sorting on large data-set Sorting performance |
4 |
2684 |
Fri, 23 November 2018 16:40 By: chaitanya tangudu |
how to add a new row in the filter list, if rows are already filttered. By: SD Khan on Thu, 31 October 2013 |
3 |
3984 |
Wed, 21 November 2018 08:30 By: Richie Martin Pasupuleti |
How to use CellPainterDecorator class |
9 |
4589 |
Tue, 20 November 2018 10:11 By: Dirk Fauth |
How to configure the borderline of ColumnGroups Theme Configuration Column Group |
2 |
1756 |
Tue, 20 November 2018 09:01 By: Hilger Steenblock |
Coloring grid lines with GridLineCellLayerPainter |
1 |
2086 |
Tue, 20 November 2018 06:27 By: Dirk Fauth |
Release date Release date v1.6 |
5 |
3122 |
Tue, 20 November 2018 06:21 By: Dirk Fauth |
NatTable context menus with Eclipse menus |
3 |
3477 |
Sat, 20 October 2018 17:42 By: Luc H |
How to read Map in Nattable |
2 |
1642 |
Wed, 24 October 2018 09:56 By: karthykeyan Palanisamy |
How to restore default value after setting a css property |
5 |
3260 |
Fri, 19 October 2018 16:21 By: Pauline Deville |
Resizing Columns for a Single Row When only one row / single row selected, a single column resize resizes all columns |
5 |
2995 |
Fri, 28 September 2018 07:34 By: Martin Schmidt |
NatTable eample EditorExmple not visible in Composite (ViewPart Eclipse 3.7) |
1 |
1892 |
Wed, 26 September 2018 18:27 By: Dirk Fauth |
What is the best way to lock/unlock rows for editing |
1 |
2122 |
Wed, 15 August 2018 01:53 By: PK Mising name |
How to paint over header cell boundaries via an own cHeaderCellPainter |
1 |
1778 |
Thu, 02 August 2018 10:28 By: Dirk Fauth |
How to select rows with matching text in whole row or single column |
6 |
2657 |
Thu, 12 July 2018 11:18 By: Markus Barbey |
