Topic |
Replies |
Views |
Last message |
Call for Submissions: Modeling Symposium EclipseCon North America 2013 |
0 |
6242 |
Thu, 24 January 2013 13:07 By: Jonas Helming |
Disable generation of ModelFactory and ModelPackage Need a way to disable generation of additional classes without having to use orm-annotationmodel. |
4 |
2969 |
Thu, 24 January 2013 09:15 By: Pradeep Badiger |
Deletion of existing classes in same package Classes added manually within same package are getting deleted when texo generates code. |
3 |
1914 |
Wed, 23 January 2013 14:49 By: Martin Taal |
[Texo] Errors while generating model code |
6 |
5193 |
Wed, 23 January 2013 08:37 By: Bastian Wagenfeld |
Eclipse Link tenant property lost on cascading delete |
1 |
4043 |
Sat, 19 January 2013 09:36 By: Martin Taal |
[EMFStore] Is it somehow possible to use EMFStore for metamodels? |
3 |
3499 |
Fri, 18 January 2013 09:22 By: Jonas Helming |
Adding/Editing/Deleting Ecore objects programmatically using EditingDomain How? Any example? |
3 |
4115 |
Fri, 18 January 2013 08:11 By: Ed Merks |
[Texo] Problems handling ResponseType |
3 |
2770 |
Thu, 17 January 2013 14:43 By: Bastian Wagenfeld |
[Texo] Problems handling JSON response |
1 |
2276 |
Thu, 17 January 2013 14:22 By: Martin Taal |
How to change the default fill color of EClasses in the Ecore Tools Diagram Editor? By: Eclipse User on Thu, 17 January 2013 |
2 |
2158 |
Thu, 17 January 2013 13:24 By: Eclipse User |
[Texo] texo template files in external plugin |
4 |
3583 |
Tue, 15 January 2013 13:13 By: Emanuele Gesuato |
texo webservice support for nested packages |
5 |
3363 |
Sun, 13 January 2013 15:19 By: Martin Taal |
WebServiceHandler does not use template method to create EntityManager |
2 |
1846 |
Fri, 11 January 2013 14:31 By: Donat Mueller |
Texo - ECore reference to another ECore using archive: Exception while generating code from ecore file having reference using archive: |
7 |
4582 |
Fri, 11 January 2013 11:34 By: Pradeep Badiger |
Empty line on generated ecore file |
1 |
2561 |
Tue, 08 January 2013 18:50 By: Martin Taal |
[EEF] EObjects with different alternative views ? |
0 |
7527 |
Mon, 07 January 2013 14:04 By: Romain Bernard |
[Texo] Entity Listener annotation not generated correctly Entity listener annotation is not generated correctly |
2 |
4048 |
Fri, 28 December 2012 14:21 By: Emanuele Gesuato |
[Texo] Example for creating orm.xml from ecore model programmatically |
9 |
7061 |
Thu, 20 December 2012 12:53 By: Pradeep Badiger |
EMF + Texo + Xpand2 Access ecore model annotations in custom texo template |
8 |
8318 |
Thu, 20 December 2012 11:37 By: Martin Taal |
Multi Java Annotations in the model Java Annotations in the model |
5 |
3751 |
Mon, 17 December 2012 13:15 By: Martin Taal |
NPE When Serializing with Texo |
3 |
4044 |
Sat, 15 December 2012 18:43 By: Martin Taal |
Access to the XTend2 Template Files. |
1 |
1684 |
Fri, 14 December 2012 15:31 By: Martin Taal |
[EEF] Problems with references to other models |
0 |
7732 |
Wed, 12 December 2012 16:18 By: Erlend Stav |
[EMF Facet] TreeViewer with EObject from different resource sets |
1 |
2880 |
Thu, 06 December 2012 10:51 By: Gregoire Dupe |
Texo - orm annotation model has invalid default values @Column annotation has invalid default values |
4 |
5060 |
Wed, 05 December 2012 08:54 By: Pradeep Badiger |
[EEF] Custom table representation EEF + GMF |
0 |
8241 |
Mon, 03 December 2012 14:34 By: Hristina Pavlovska |
[EEF] Contributing new widgets |
4 |
3837 |
Mon, 03 December 2012 14:28 By: Hristina Pavlovska |
customization templates: EPackageModelGenAnnotation not found customization templates: EPackageModelGenAnnotation not found |
7 |
4879 |
Thu, 29 November 2012 18:00 By: Martin Taal |
Teneo EMF @OneToOne and @ManyToOne |
4 |
3997 |
Tue, 27 November 2012 22:22 By: Svetoslav Missing name |
Hook to modify how xsd:double is serialized by XMLResource |
13 |
4038 |
Sun, 25 November 2012 21:17 By: Ed Merks |
[EMFStore] Workspace singularity |
1 |
3089 |
Thu, 22 November 2012 21:07 By: Jonas Helming |
Texo - Roadmap and releases |
3 |
2771 |
Wed, 21 November 2012 18:23 By: Martin Taal |
Re-Generation orm annotation file Generation orm annotation file |
9 |
4675 |
Wed, 21 November 2012 15:37 By: Pradeep Badiger |
[Texo] Generation Code [Texo] Annotation is not correct |
3 |
3936 |
Tue, 20 November 2012 10:27 By: Martin Taal |
File goes dirty when existing item selected EEF based editor marks file dirty when selecting an existing item in a EEF AdvancedTableComposition widget By: Eclipse User on Mon, 19 November 2012 |
0 |
8882 |
Mon, 19 November 2012 22:02 By: Eclipse User |
Call EMF Compare |
1 |
1839 |
Fri, 16 November 2012 17:35 By: Ed Willink |
Texo - implementing an interface How to generate jpa code for the model which implements an interface |
4 |
2875 |
Fri, 16 November 2012 15:21 By: Martin Taal |
[Teneo] Use objects in a query later on |
1 |
1878 |
Thu, 15 November 2012 18:50 By: Martin Taal |
[EuGENia] Issue with the generated editor Two gmf.links (instead of one) between two gmf.nodes |
1 |
3271 |
Mon, 12 November 2012 15:50 By: Mirco Franzago |
Generate entity annotations in orm file Generate orm file for eclipse link with details present on entity. |
5 |
5565 |
Fri, 09 November 2012 05:03 By: Pradeep Badiger |
Texo on Indigo Windows 32 bit Install Texo on Indigo Eclipse package |
3 |
3067 |
Wed, 07 November 2012 09:05 By: Martin Taal |
[Texo] My template overrides are not being used Odd properties problem... |
11 |
7383 |
Tue, 06 November 2012 09:25 By: Pradeep Badiger |
[Teneo] HbHelper.INSTANCE.deRegisterDataStore [Teneo] HbHelper.INSTANCE.deRegisterDataStore |
2 |
2187 |
Mon, 05 November 2012 23:17 By: Martin Taal |
Edapt (Undo changes after release and migrate) |
0 |
10263 |
Thu, 01 November 2012 14:34 By: lucky informatik |
[TEXO] Exception [EclipseLink-93] |
2 |
2569 |
Wed, 31 October 2012 16:59 By: Micha-Jamie Guthmann |
UI generation of EMF model |
6 |
4572 |
Wed, 31 October 2012 15:41 By: Jonas Helming |
[EMF TENEO] Placing and naming external xml mapping file What to name and where to place my external mapping file |
2 |
1881 |
Mon, 29 October 2012 21:24 By: Duncan Krebs |
EGF status? |
1 |
2332 |
Fri, 26 October 2012 17:08 By: Benoit Langlois |
Edit - ignore this post [Texo] Trying to get the Rest Web Service going Problems with multiple inheritance |
1 |
1677 |
Fri, 26 October 2012 13:51 By: Micha-Jamie Guthmann |
EMFStore catalog/index EMFStore catalog/index |
8 |
7563 |
Fri, 26 October 2012 10:12 By: Maximilian Koegel |
EMFStore Team Support |
1 |
2510 |
Fri, 26 October 2012 10:10 By: Maximilian Koegel |
Create multiple Tabs with EEF based Properties view |
0 |
10136 |
Wed, 24 October 2012 14:44 By: Amine EL KOUHEN |
Headless EMFStore server EMFStore Installation Headless |
5 |
6140 |
Mon, 22 October 2012 09:52 By: Maximilian Koegel |
produce high quality diagram output of some ecore models By: Tom H on Mon, 08 October 2012 |
3 |
2878 |
Sat, 20 October 2012 18:06 By: Ed Merks |
[TEXO] JPA join table naming |
2 |
2626 |
Wed, 17 October 2012 13:18 By: Gary Godfrey |
Teneo Entity manager for Texo generated model Teneo Entity manager for Texo generated model |
3 |
3362 |
Tue, 16 October 2012 18:27 By: Martin Taal |
EMFT Texo: uses xtend2 for code generation --> when overriding templates please read |
2 |
2237 |
Sun, 14 October 2012 02:57 By: Oliver Zhou |
[Texo] How to improve speed of generating java classes? |
12 |
13778 |
Fri, 12 October 2012 22:03 By: Martin Taal |
[Texo] Does TexoResource support Element Collections? |
4 |
3369 |
Thu, 11 October 2012 03:16 By: Chris Boerger |
[Texo] Cannot resolve referring EObjects when using TexoResource |
2 |
2152 |
Wed, 10 October 2012 03:23 By: Chris Boerger |
EMFStore browser to configure server port/ip |
1 |
1974 |
Tue, 09 October 2012 08:16 By: Maximilian Koegel |
[Texo] Generating TypeConverter puts quotes around classes |
1 |
1959 |
Tue, 02 October 2012 15:56 By: Martin Taal |
(later) undo "delete from diagram" |
1 |
1862 |
Tue, 02 October 2012 13:50 By: Ed Merks |
[Texo] XMI Serialization in/from multiple files |
2 |
2849 |
Fri, 28 September 2012 07:37 By: Oliver Zhou |
Diagram Editor documentation |
2 |
2364 |
Thu, 27 September 2012 14:55 By: David Rees |
How to install "Ecore Search" |
2 |
2422 |
Thu, 27 September 2012 14:44 By: David Rees |
Error in EEF generatoed forms |
0 |
11046 |
Wed, 26 September 2012 09:48 By: Hassan BAZOUN |
[EMF Teneo] problems with integration of MySQL and EclipseLink in EMF Teneo By: kidsos on Sun, 16 May 2010 |
4 |
3665 |
Wed, 19 September 2012 23:41 By: Martin Taal |
[EEF] Using EEF with Abstact class, inheritance and reference. |
0 |
12066 |
Wed, 19 September 2012 15:45 By: aurelien didier |
EMFStore server running within an AS |
5 |
3947 |
Wed, 19 September 2012 13:55 By: Namrata Tiwari |
Texo JSON Resource: using EMF in a 3-tier architecture with a JSON JPA web server |
3 |
3785 |
Sat, 15 September 2012 06:51 By: Martin Taal |
[Edapt][CDO] EDAPT with CDO Using EDAPT onto CDO-backed models : howto? |
4 |
3978 |
Fri, 14 September 2012 11:42 By: Eike Stepper |
SWTBot & EEF generated Forms How to find ReferencesTable? By: Eclipse User on Fri, 07 September 2012 |
2 |
3001 |
Mon, 10 September 2012 09:00 By: Goulwen Le Fur |
[Texo] Programmatically generate POJOs in a standalone project |
5 |
3708 |
Fri, 07 September 2012 09:41 By: Benjamin M. |
[EEF] Errors in the generated code. |
5 |
5678 |
Thu, 06 September 2012 12:33 By: aurelien didier |
Generating model source with maven and emf.ecore2java Need help configuring maven/ant task to generate model source code |
0 |
11407 |
Thu, 06 September 2012 00:26 By: Jim Foscue |
[EEF] Other than in a tree view |
7 |
6387 |
Tue, 04 September 2012 20:54 By: Laurent Mattina |
Modeling Symposium |
1 |
1602 |
Tue, 04 September 2012 14:34 By: Jonas Helming |
[Texo] make _eclass optional when using query in PUT |
1 |
2649 |
Mon, 03 September 2012 05:23 By: Martin Taal |
[CDO] Allowing (or ignoring) duplicate objects for certain types |
1 |
2538 |
Sat, 01 September 2012 11:40 By: Eike Stepper |
Texo And Teneo |
2 |
3164 |
Mon, 27 August 2012 10:22 By: Siaraman Vilayannur |
Multiple Generated Objects with 1s appended. |
1 |
2008 |
Mon, 27 August 2012 00:43 By: Martin Taal |
[Acceleo] Capability Question [Acceleo] Capability Question |
1 |
1997 |
Sun, 26 August 2012 12:44 By: Ed Merks |
[Texo] JSONTexoResource, DynamicModelObject support Texo support for JSONTexoResource, DynamicModelObject |
7 |
5622 |
Sun, 26 August 2012 07:55 By: Neeraj Bhusare |
[EMF Compare] opening editor programmatically results in unexpected/wrong view By: Eclipse User on Sun, 29 May 2011 |
1 |
9733 |
Fri, 24 August 2012 21:15 By: Stacey Hopkins |
orm:delimited-identifiers |
2 |
3068 |
Fri, 24 August 2012 08:53 By: Peter Kullmann |
[texo] how to set references in json |
6 |
6222 |
Sun, 19 August 2012 13:11 By: Martin Taal |
[Texo] Complete tutorial (from scratch) |
3 |
3234 |
Thu, 16 August 2012 22:04 By: Martin Taal |
[TEXO] annotations |
3 |
3530 |
Thu, 16 August 2012 04:01 By: Martin Taal |
[TEXO] JPA entity names |
3 |
2905 |
Tue, 14 August 2012 15:51 By: Martin Taal |
[TEXO] transient |
2 |
2517 |
Tue, 14 August 2012 10:21 By: Gary Godfrey |
EMFStore / CDO for UML models |
1 |
2263 |
Wed, 08 August 2012 16:48 By: Maximilian Koegel |
EMFStore model migration |
1 |
2274 |
Wed, 08 August 2012 16:42 By: Maximilian Koegel |
EMFStore Default Host |
2 |
4153 |
Mon, 06 August 2012 10:02 By: Oliver Koch |
[texo] conversion from json string to EDataType |
4 |
4202 |
Wed, 01 August 2012 17:01 By: Erdal Karaca |
[EEF] Changing Representation of attributes of an Eclass with multiple SuperTypes |
2 |
2742 |
Wed, 01 August 2012 14:16 By: masija . |
[texo] git repo unavailable |
2 |
2319 |
Tue, 31 July 2012 21:38 By: Erdal Karaca |
[texo] Not possible to determine id eattribute for eClass ... |
4 |
3086 |
Fri, 27 July 2012 08:40 By: Erdal Karaca |
[Texo] Abstract schema type is unknown |
6 |
9224 |
Thu, 26 July 2012 13:54 By: Erdal Karaca |
[Texo] HTTP 404 when using Opera |
2 |
2643 |
Wed, 25 July 2012 13:51 By: Erdal Karaca |
how to remove the EReference in my Ecore Diagram |
7 |
3583 |
Wed, 25 July 2012 09:56 By: frank fotso |
Ordered feature for non-list objects |
1 |
2127 |
Wed, 25 July 2012 09:49 By: Ed Merks |
Need a user-friendly editor for creating instances User-friendly editor to create InstanceSpecification elements |
3 |
3590 |
Thu, 19 July 2012 08:36 By: Eike Stepper |
[EEF] [0..1] Composition Link Issue |
1 |
6408 |
Mon, 16 July 2012 12:53 By: yashine Missing name |
[ECP] EMF Test Model Generator |
2 |
4995 |
Fri, 13 July 2012 09:14 By: Maximilian Koegel |
[EEF] Questions about 1_1 containment relation and EEF generation |
0 |
13708 |
Wed, 11 July 2012 08:36 By: aurelien didier |
Error loading a resource file A "Resource xxx does not exist" Exception occurs in PlatformResourceURIHandlerImpl |
1 |
3840 |
Tue, 10 July 2012 14:40 By: Ed Merks |
Problem with images instead shapes |
1 |
3696 |
Mon, 09 July 2012 15:27 By: Suhrid Karthik |
[EEF] Linking EEF Property Sheet with GMF Editor |
0 |
13523 |
Sun, 08 July 2012 11:57 By: Suhrid Karthik |
[EEF] Derived Attributes and Enumerators |
4 |
3557 |
Wed, 04 July 2012 08:17 By: aurelien didier |
Hibernate tool for JUNO did their is any Hibernate tool for Juno |
1 |
3217 |
Tue, 03 July 2012 04:27 By: Martin Taal |
Cannot create Migrator (Edapt/COPE) emf model migration |
14 |
14786 |
Fri, 29 June 2012 10:14 By: lucky informatik |
my EMF model generated tests... |
0 |
13323 |
Wed, 27 June 2012 19:38 By: Sharon Snyder |
How to Document MWE and XPT Files |
0 |
13368 |
Tue, 26 June 2012 17:05 By: Detlef Burkhardt |
[EMFT] Getting started but how? By: Thomas on Mon, 02 November 2009 |
14 |
9575 |
Thu, 21 June 2012 10:01 By: Almamy Ndiaye |
Teneo proper save & validate |
8 |
5056 |
Wed, 20 June 2012 05:42 By: C Peter |
[EOL] Delete the default group: Objects ?? By: Lili R on Sun, 17 June 2012 |
2 |
3664 |
Sun, 17 June 2012 20:36 By: Lili R |
[Texo] - Change package name in annotation model ? |
1 |
3437 |
Fri, 15 June 2012 03:09 By: Martin Taal |
problem with subpackages |
0 |
13801 |
Thu, 14 June 2012 17:43 By: Daniel Mirón |
EGF passed the graduation review EGF |
0 |
14182 |
Thu, 14 June 2012 09:21 By: Benoit Langlois |
Customizing the palette By: Lili R on Mon, 11 June 2012 |
0 |
14248 |
Mon, 11 June 2012 15:12 By: Lili R |
[TEXO] Enum documentation |
4 |
2949 |
Fri, 08 June 2012 18:43 By: Martin Taal |
TENEO problems on HOT redeploy |
6 |
5092 |
Thu, 07 June 2012 16:33 By: Martin Taal |
[TEXO] Enum values |
7 |
4771 |
Thu, 07 June 2012 15:22 By: Martin Taal |
[Teneo] Hibernate 4.1 has Trouble with Booleans |
6 |
9222 |
Tue, 05 June 2012 10:38 By: Flavio Donze |
Texo ModelPackage already registered |
4 |
4073 |
Tue, 05 June 2012 10:13 By: Sebastian Steinacher |
EMFT Texo: Latest Build and Backward Compatibility |
2 |
2918 |
Fri, 01 June 2012 13:39 By: Martin Taal |
[Edapt] handle user input during migration |
3 |
3190 |
Fri, 01 June 2012 13:13 By: Bernd B. |
EMF Serialization |
1 |
2027 |
Fri, 01 June 2012 09:16 By: Almamy Ndiaye |
EMT Texo: Latest Build and Backward Compatibility |
0 |
15060 |
Thu, 31 May 2012 13:12 By: Martin Taal |
[Teneo] Using Teneo in JBoss Environment ePackage issue By: Ben R on Tue, 29 May 2012 |
1 |
2485 |
Tue, 29 May 2012 21:03 By: Martin Taal |
EMFInterceptor Audit Logging |
2 |
2673 |
Tue, 29 May 2012 14:19 By: Serhan OZAN |
[EcoreTools] Problem installing on 3.8 |
4 |
2936 |
Mon, 28 May 2012 16:18 By: Alain Picard |
[Texo] ignore not null syntax Oracle problem with string 0 lenght |
2 |
2745 |
Mon, 28 May 2012 08:56 By: Martin Taal |
[Texo] Problem with enforce unique names Too long names of tables |
3 |
2789 |
Fri, 25 May 2012 11:57 By: Olaf Burdziakowski |
Connection between EMFStore server and client |
1 |
2543 |
Fri, 25 May 2012 10:29 By: Maximilian Koegel |
Re: Texo: how to declare one-to-many relations for different parent types? |
8 |
4276 |
Thu, 24 May 2012 20:39 By: Martin Taal |
Problems when running the EMF Store client |
5 |
5016 |
Thu, 24 May 2012 13:05 By: Jonas Helming |
[Texo] Inappropriate @JoinTable JPA mapping |
3 |
4649 |
Thu, 24 May 2012 03:56 By: Martin Taal |
[EEF] component binding and eOperations |
0 |
15032 |
Wed, 23 May 2012 20:11 By: Alain Picard |
[Texo] How to create ecore file with sub-packages? |
7 |
4068 |
Tue, 22 May 2012 12:02 By: Martin Taal |
[ECP / general modeling] How to model a bi-directional "related to" reference in EMF and E |
2 |
3074 |
Tue, 22 May 2012 11:13 By: Christian Kurze |
[SOLVED] Ecore diagram editor missing in Eclipse 4.2? |
4 |
8810 |
Tue, 22 May 2012 08:03 By: Stefan Wülfrath |
Get namespaces used in xml file |
17 |
7725 |
Mon, 21 May 2012 16:38 By: Ed Merks |
Urgent : How to Read the Ecore Model Reading the Ecore Model |
9 |
4108 |
Mon, 21 May 2012 14:25 By: Ed Merks |
[JET] "translation" code By: jpfse on Thu, 17 May 2012 |
5 |
3810 |
Sat, 19 May 2012 08:39 By: Ed Merks |
[TEXO] traverse object graph |
1 |
2093 |
Fri, 18 May 2012 16:08 By: Martin Taal |
Texo: list of annoying details |
6 |
2946 |
Thu, 17 May 2012 16:06 By: Ed Merks |
[Texo] Hard-coded date time format ... |
1 |
1975 |
Thu, 17 May 2012 13:50 By: Martin Taal |
Problem with connector of Tree Routing type Problem with connector of Tree Routing type |
1 |
1471 |
Wed, 16 May 2012 16:25 By: Ed Merks |
[EEF] Property view with groups broken |
2 |
4438 |
Wed, 16 May 2012 13:42 By: Stephane Bouchet |
0 |
15828 |
Tue, 15 May 2012 13:41 By: Martin Taal |
[TEXO] unbounded type |
1 |
2141 |
Thu, 10 May 2012 09:29 By: Martin Taal |
[EEF] Customizing EEF Generation We have to customize the EEF code generation where editor should implement our own base editor and editor page should inherit from specific page and all sections generated also should inherit from s |
1 |
3690 |
Thu, 10 May 2012 09:26 By: Goulwen Le Fur |
[TEXO] xsd mappings |
1 |
1906 |
Wed, 09 May 2012 19:38 By: Martin Taal |
Integrate EMF Search with GMF Integrate EMF Search with GMF |
0 |
15640 |
Tue, 08 May 2012 11:33 By: Abbas Mohd |
[TEXO] Generation by maven or Ant |
1 |
2219 |
Mon, 07 May 2012 16:00 By: Martin Taal |
[Texo] No Dao class is generated for abstract class |
8 |
5978 |
Mon, 07 May 2012 15:16 By: Martin Taal |
[EMF Facet] non respect of the API freeze |
0 |
16180 |
Fri, 04 May 2012 14:38 By: Gregoire Dupe |
[TEXO] JPA Foreign Key |
1 |
2105 |
Fri, 04 May 2012 10:05 By: Martin Taal |
Invitation for discussion How to develop a single-sourced, database-supported modeling environment? |
0 |
16950 |
Fri, 04 May 2012 08:06 By: Christian Kurze |
Edapt migrator |
1 |
3366 |
Tue, 01 May 2012 09:01 By: Markus Herrmannsdoerfer |
Implement undo/redo operations using EMF Refactor |
0 |
16361 |
Thu, 26 April 2012 15:44 By: Iman Imani |
[EEF] looking for a updated tutorial |
1 |
2499 |
Thu, 26 April 2012 09:04 By: Stephane Bouchet |
[TEXO] Object Embeddable |
2 |
3091 |
Wed, 25 April 2012 16:45 By: Martin Taal |
Loading an Ecore meta-model from a model instance using "Load Resource.." |
1 |
2579 |
Tue, 24 April 2012 11:01 By: Ed Merks |
Loading ecore files in Eclipse Indigo how to load an ecore file from emf in eclipse |
3 |
4543 |
Tue, 24 April 2012 05:28 By: Ed Merks |
edapt project status |
9 |
4656 |
Mon, 23 April 2012 19:25 By: Markus Herrmannsdoerfer |
[Texo] NamedQuery annotation is not correct |
6 |
5345 |
Sat, 21 April 2012 10:48 By: Oliver Zhou |
[Teneo] AbstractPersistentCollection crashes when Product is exported |
7 |
3314 |
Tue, 17 April 2012 21:15 By: Mauricio Reyes |
[EEF] Does EEF use property descriptors? |
0 |
16947 |
Mon, 16 April 2012 13:40 By: Ingo Budde |
Re: [Texo] error while generating JPA Annotated model |
0 |
17024 |
Fri, 13 April 2012 11:20 By: Martin Taal |
[TEXO] Touch ModelPackage |
1 |
2271 |
Thu, 05 April 2012 15:33 By: Martin Taal |
Can I implement my own TexoResourceManger |
4 |
3209 |
Thu, 05 April 2012 05:28 By: Oliver Zhou |
Which one is better in between Eclipse building and Eclipse Branding By: chavi on Fri, 30 March 2012 |
1 |
2433 |
Fri, 30 March 2012 15:45 By: Ed Merks |
[EMFT MWE] Missing org.eclipse.emf.mwe2.launch in archived update site |
1 |
2642 |
Fri, 30 March 2012 12:24 By: Aaron Digulla |
[EEF] EEFTreeMasterPart widget size problem In the EEFTreeMasterPart, the tree widget can expand beyond its expected size. |
1 |
3788 |
Thu, 29 March 2012 09:34 By: Stephane Bouchet |
[EEF] Master-Detail with subtypes |
3 |
5418 |
Thu, 29 March 2012 09:08 By: Stephane Bouchet |
[EEF] Selecting wrapped item providers in the tree |
4 |
3128 |
Wed, 28 March 2012 08:56 By: Stephane Bouchet |
[EEF] Multiple Views for a Property Edition Element |
1 |
3737 |
Wed, 28 March 2012 08:54 By: Stephane Bouchet |
[EEF] Unexpected behavior when properties view is pinned |
2 |
2581 |
Wed, 28 March 2012 07:36 By: Jan Mauersberger |
[EEF] Deadlocks when using with transactional editing domains |
3 |
2413 |
Tue, 27 March 2012 14:53 By: Stephane Bouchet |
[EEF] EEFTreeMasterPart default adapterFactory with AdapterFactoryEditingDomain |
2 |
2328 |
Mon, 26 March 2012 15:20 By: Olivier Labrosse |
[EEF] PropertiesEditingSemanticLister usage of setTarget |
1 |
2879 |
Fri, 23 March 2012 16:00 By: Stephane Bouchet |
[EMFStore] and UML2 |
4 |
3224 |
Thu, 22 March 2012 10:27 By: Maximilian Koegel |
[EEF] Generation of Containment References with upper bound = 1 |
2 |
2404 |
Tue, 20 March 2012 18:47 By: Mauricio Reyes |
autocompletion ICellEditor (used in a NatTableEditor) |
2 |
2953 |
Wed, 14 March 2012 10:29 By: Gregoire Dupe |
[emffacet] Drop a model element onto a FacetReferenceColumn |
1 |
2173 |
Wed, 14 March 2012 09:49 By: Gregoire Dupe |
[TEXO] Adding annotations |
4 |
4194 |
Tue, 13 March 2012 18:32 By: Martin Taal |
[TEXO] ecore generation > 1 top level EPackage |
3 |
3105 |
Mon, 12 March 2012 10:55 By: Martin Taal |
ecorediag missing classes in packages By: Tom H on Sat, 24 October 2009 |
6 |
5464 |
Mon, 12 March 2012 06:07 By: Ed Merks |
[Texo] Don't understand JPA generation strategy on bidir relation 0..1 to 0..* |
8 |
4605 |
Thu, 08 March 2012 15:56 By: Benoit Cantin |
rolling back a transaction manually |
0 |
16683 |
Thu, 08 March 2012 14:36 By: Sven Krause |
[Texo] How difficult would it be to add JPA implementors annotation models ? |
6 |
4580 |
Thu, 08 March 2012 12:14 By: Martin Taal |
safe bi-directional association API for many to many association |
3 |
3088 |
Wed, 07 March 2012 09:20 By: Oliver Zhou |
[Texo] How to add java annotation whose full qualified name only contain one DOT |
3 |
3979 |
Wed, 29 February 2012 06:10 By: Martin Taal |
[Texo] Annotate EAttribute whose type was EEnum by ModelGenAnnotator take too much time |
2 |
2178 |
Wed, 29 February 2012 03:41 By: Henry He |
[Texo] How to run data generator |
7 |
3949 |
Sat, 25 February 2012 09:56 By: Martin Taal |
[EEF] generation of inherited elements and listeners |
1 |
1767 |
Fri, 24 February 2012 19:47 By: Josef Pohl |
[Texo] Hibernate Search example |
1 |
2308 |
Thu, 23 February 2012 20:48 By: Martin Taal |
