Home » Eclipse Projects » Sirius » Container Drop, Move Operation
Container Drop, Move Operation [message #1613387] Thu, 12 February 2015 11:19 Go to next message
i have a model, where a Container have 0..* activities of type Activity. The Container itself is also of type Activity. In my Diagram i want to be able to move activities in and out the Containers. In my odesign i use a Container Drop together with a Move operation:
https://dl.dropboxusercontent.com/u/4062763/containerDrop1.png
The Move operation is specifed like this:
https://dl.dropboxusercontent.com/u/4062763/containerDrop2.png
However, when i drag and drop an Activity on a Container, like this:
https://dl.dropboxusercontent.com/u/4062763/containerDrop3.png
Eclipse freezes and i have to kill it. So i got no error msg. Any idea what is going wrong? I am not sure if my odesign file is even valid ... Rolling Eyes
Re: Container Drop, Move Operation [message #1614838 is a reply to message #1613387] Fri, 13 February 2015 09:30 Go to previous messageGo to next message
> Hello,
Instead of define a "Move" operation, you should perform the move
"semantically".
I don't know your meta-model but if the relation between a Container and
an Activity is a containment relation, you just need to affect the
Activity to the container relation where it has been dropped. That
should look like something like that:
Begin
Change Context [newSemanticContainer/]
Set
Feature name : yourContainementFeature
Value Expression : var:element
A good example is the "Ecore Tools" modeler:
http://git.eclipse.org/c/ecoretools/org.eclipse.ecoretools.git/tree/org.eclipse.emf.ecoretools.design/description/ecore.odesign
You can take a look on the "Drop EClassifier into EPackage" Container
Drop for instance.
> :roll:
Florian - Obeo
Need professional services for Sirius?
Re: Container Drop, Move Operation [message #1614876 is a reply to message #1614838] Fri, 13 February 2015 10:04 Go to previous messageGo to next message
Begin
Set
Works like a charm!
Btw.: In which case do you use the 'Move Operation' then?
https://www.eclipse.org/sirius/doc/specifier/general/Model_Operations.html#move
Re: Container Drop, Move Operation [message #1619503 is a reply to message #1614876] Mon, 16 February 2015 11:29 Go to previous message
Le 13/02/2015 16:04, Studs Terkel a écrit :
> Quote:
>> Begin
>> Set
> Works like a charm!
Given a newContainer, an element to add and the name if a containing
feature, it is up to you to choose between both constructions:
Set operation:
. changeContext newContainer
. set containmentFeatureName element
Move operation:
. changeContext element
. move newContainer containmentFeatureName
The move operation will log an error if the feature upper bound is 1 and
if a value is already specified for the new container.
Maxime - Obeo
Previous Topic:Can't find the target of the diagram
Next Topic:Unrecognized variables in .odesign
Current Time: Thu Oct 30 18:58:52 EDT 2025
Powered by FUDForum. Page generated in 0.04561 seconds
