Home » Archived » BIRT » hiding an element in the ROM
hiding an element in the ROM [message #202279] Tue, 21 November 2006 19:02 Go to next message
Originally posted by: goykhmanster.gmail.com
Hi all
I am trying to conditionally hide an element if a certain counter variable
reaches a certain value as rows keep rendering. However, it doesn't work,
because i don't know how to handle ROM elements via javascript. I am
using BIRT 2.0.2 and I added the following event handlers for the table:
<method name="onPrepare"><![CDATA[var countRecords =
0;]]></method>
<method name="onRender"><![CDATA[if (countRecords > 200) {
document.getElementById('107').style.display = 'none';
}]]></method>
and the following event handler for every row:
<method name="onRender"><![CDATA[countRecords++;]]></method>
The code inside 'if' statement is obviously wrong, so if someone could
point out how to hide a ROM element, i would greatly appreciate it.
Re: hiding an element in the ROM [message #202473 is a reply to message #202279] Wed, 22 November 2006 11:04 Go to previous messageGo to next message
try removing the var keyword, it should make the variable global.
Dont use the if statement here. You can but it is better to just use the
visibility property for the elment. In the visibillity expression put
something like
if( countRecords > 200 ){
true;
}else{
false;
Jason
"Boris" <goykhmanster@gmail.com> wrote in message
news:11d5b00397f7e61f35a18958b6d8563e$1@www.eclipse.org...
> Hi all
> 0;]]></method>
> }]]></method>
> Thanks
Re: hiding an element in the ROM [message #202488 is a reply to message #202473] Wed, 22 November 2006 11:23 Go to previous messageGo to next message
Jason
Thanks for your response.
The problem is, however, the element that i want to hide renders BEFORE
the data table starts rendering. Therefore, if i use condition
countRecords>200 for it, it will read countRecords variable's value at the
time when it was first initialized when it is still 0.
This is why i'm trying to execute something at the time when the table
finishes rendering (onRender method is the right place for that, right?).
Is there a way to apply a visibility property to an element dynamically
via the script or anything else?
Re: hiding an element in the ROM [message #202495 is a reply to message #202473] Wed, 22 November 2006 11:25 Go to previous messageGo to next message
... and i tried removing 'var' keyward and updated the visibility
expression, and it produces the same result.
Re: hiding an element in the ROM [message #203054 is a reply to message #202488] Mon, 27 November 2006 11:09 Go to previous message
Try setting this in the onRender event.
//this.getStyle().visibleFormat = "'pdf'";
//this.getStyle().visibleFormat = "'html'";
this.getStyle().visibleFormat = "'all'";
Jason
news:7e049481b76846d31a634a9cf26fb169$1@www.eclipse.org...
> Jason
Previous Topic:For Jason:Null Ptr Exceptn on running MS SQL Query from a scripted database
Next Topic:HowTo - Custom Series for Charts
Current Time: Tue Oct 21 22:29:46 EDT 2025
Powered by FUDForum. Page generated in 0.03728 seconds
