Home » Archived » BIRT » modify chart color by dataset value
modify chart color by dataset value [message #177166] Thu, 13 July 2006 03:48 Go to next message
Originally posted by: thomas.buffagni.otconsulting.com
Hi All!
I'm trying to modify at runtime the bar's color of chart conditionally.
I've tryed this code:
function beforeDrawDataPoint( dataPointHints, fill, context ){
val = dataPointHints.getOrthogonalValue();
chart = context.getChartInstance();
marker = 0;
if (val > marker) //crosses marker?
fill.set(0, 255, 0); //yes - display in red
else
fill.set(0, 0, 255); //no - display in blue*/
and it works but now i want change the color by the value of row field
that it isn't the value of the serie
I would like make somethings like this: marker = row["myMarker"], have you
some ideas?
Re: modify chart color by dataset value [message #177213 is a reply to message #177166] Thu, 13 July 2006 08:23 Go to previous messageGo to next message
This is currently not supported. You can try to create an invisible series
linked to "myMarker", then access the value of that series by getting the
chart instance from the context:
context.getChartInstance().getAxes().get(0).getAssociatedAxe s().get(0).getRuntimeSeries().get(1).getDataSet().getValues( );
This will return an array of the values for the second series on the first Y
Axis (assuming this is the invisible one), then you can look up the value
for the index you're at in the beforeDrawDataPoint function. (the
dataPointHints should have the current index).
David
"Thomas" <thomas.buffagni@otconsulting.com> wrote in message
news:e7e2d5e1d1cad416277649e9980de5da$1@www.eclipse.org...
> Hi All!
> marker = 0;
> else
> some ideas?
Re: modify chart color by dataset value [message #177229 is a reply to message #177213] Thu, 13 July 2006 09:03 Go to previous messageGo to next message
Hi David!
I've tryed your code but doesn't work, i've this error:
Java class "[Lorg.eclipse.birt.chart.model.component.Series;" has no
public instance field or method named "get". at line 273 of chart
script:''
My Code:
index = dataPointHints.getIndex();
seriesArray =
context.getChartInstance().getAxes().get(0).getAssociatedAxe s().get(0).getRuntimeSeries().get(0).getDataSet().getValues( );
marker = seriesArray[index];
fill.set(255, 0, 0); //yes - display in red
else
Re: modify chart color by dataset value [message #177259 is a reply to message #177229] Thu, 13 July 2006 09:32 Go to previous message
This is the right code, now it works
seriesArray =
context.getChartInstance().getAxes().get(0).getAssociatedAxe s().get(0).getRuntimeSeries();
markerValue = seriesArray[0].getDataSet().getValues()[index];
if (markerValue < val) //crosses marker?
else
Previous Topic:BIRT 2.0 Performance issues
Next Topic:Matrix Report
Current Time: Mon Oct 20 20:14:51 EDT 2025
Powered by FUDForum. Page generated in 0.06510 seconds
