Home » Archived » BIRT » Missing extenion id in data source definition
| Missing extenion id in data source definition [message #176312] |
Mon, 10 July 2006 17:19  |
Originally posted by: kevin_ou.yahoo.com
I am currently using BIRT 2.1 to generate a PDF from a java application
(not from a web).
However, I got the error says "Missing extenion id in data source
definition".
Could some one help me with that? Thanks
Kevin
| Re: Missing extenion id in data source definition [message #176494 is a reply to message #176476] |
Tue, 11 July 2006 10:47   |
Hi Jason
Thanks for the reply, hope you can help me out for this issue.
below is my code
public class CBReportConfig
private EngineConfig gobjEngineConfig;
private String gstrEngineHome;
private String gstrDesignFileDir =
"C:/kou_am_development_snap/Applimation/Codebase/4.2/";
private String gstrOutputDir =
"C:/oracle/oradev10g/forms90/j2ee/forms90app/forms90web/";
public static String gstrReportPropertyPath =
"c:/codebase/conf/ReportProperty.properties";
private String gstrFormat;
private String gstrDesignFile = "";
public CBReportConfig(String istrFormat)
gstrFormat = istrFormat;
Properties p = new Properties();
try
InputStream iobjStream = new
FileInputStream(gstrReportPropertyPath);
p.load(iobjStream);
catch (Exception ex)
ex.printStackTrace();
setEngineHome(p.getProperty("BIRT_HOME"));
setDesignFileDir(p.getProperty("DESIGN_FILE"));
setOutputDir(p.getProperty("RPT_OUTPUT"));
public String getDesignFile()
return gstrDesignFile;
public void setDesignFile(String designFile)
gstrDesignFile = designFile;
public void setReportFormat(String lstrFormat)
gstrFormat = lstrFormat;
public String getReportFormat()
return gstrFormat;
public void setReportPropertyPath(String istrPropertieFilePath)
gstrReportPropertyPath = istrPropertieFilePath;
public EngineConfig getEngineConfig()
return gobjEngineConfig;
public String getDesignFileDir()
return gstrDesignFileDir;
public String getOutputDir()
return gstrOutputDir;
public void setOutputDir(String istrOutputDir)
gstrOutputDir = istrOutputDir;
public void setEngineHome(String istrEngineHome)
gobjEngineConfig = new EngineConfig();
// IPlatformContext context = new PlatformFileContext();
// gobjEngineConfig.setEngineContext(context);
config.setEngineHome("C:/myInstall/birt/birt-runtime-2_0_1/Report Engine");
gobjEngineConfig.setEngineHome(istrEngineHome);
gstrEngineHome = istrEngineHome;
public void setDesignFileDir(String istrDesignFileDir)
gstrDesignFileDir = istrDesignFileDir;
* <p>This method returns the current class name</p>
* @return String - Class name
private String getClassName()
return (this.getClass().getName());
} //End Of getClassName
* <p>This method returns the version of the class</p>
* @return String - Version of the class
public static String getVersion() throws Exception
return /*#CC_JAVA_VERSION_NUM#*/ "2";
} //End Of getVersion
public CBReportRender(CBReportConfig iobjCBReportConfig)
engine = new ReportEngine(iobjCBReportConfig.getEngineConfig());
engine.changeLogLevel(Level.FINEST );
gobjReportConfig = iobjCBReportConfig;
public void runAndRenderReport(String istrOutputFile, CBDBHelper
iobjDBHelper) throws Exception
try
String lstrDesignFile = gobjReportConfig.getDesignFileDir() +
gobjReportConfig.getDesignFile();
//AMConnection lobjAMConn = iobjDBHelper.getConnection();
//Open a report design - use design to modify design, retrieve
embedded images etc.
IReportRunnable design =
engine.openReportDesign(lstrDesignFile);
//Create task to run the report - use the task to execute and
run the report,
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
//Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put("org.eclipse.birt.report.data.oda.jdbc",null);
task.setAppContext(contextMap);
//Set rendering options - such as file or stream output,
//output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName(istrOutputFile);
options.setOutputFormat(this.gobjReportConfig.getReportForma t());
task.setRenderOption(options);
//run the report and destroy the engine
task.run();
catch (Exception e)
throw new CBException(e, "Report render failed!");
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:e9085v$94g$1@utils.eclipse.org...
> Can you post your code and try using the sampledb?
> Jason
> "kevin ou" <kevin_ou@yahoo.com> wrote in message
> news:eb511c3427963394398f7032a4b9a240$1@www.eclipse.org...
>> Thanks for the reply.
>> I copied the classes12.jar into
>> birt-runtime-2_1_0\ReportEngine\plugins\org.eclipse.birt.rep ort.data.oda.jdbc_2.1.0.N20060628-1351\drivers.
>> However, it is still getting the same error.
>> Also, I have tried to use XML as datasource, however, I got the same
>> error, therefore, I don't think copying jar file to drivers will solve
>> this error.
>> Kevin
| Re: Missing extenion id in data source definition [message #176524 is a reply to message #176494] |
Tue, 11 July 2006 17:48   |
Kevin,
What version of BIRT are you using?
In your code you have this as your home.
Jason
"kevin" <kevin_ou@yahoo.com> wrote in message
news:e90dmr$jj8$1@utils.eclipse.org...
> Hi Jason
> below is my code
> try
> p.load(iobjStream);
> return gstrFormat;
> Engine");
> try
> run the report,
> task.run();
> catch (Exception e)
>> Jason
>>> this error.
>>> Kevin
| Re: Missing extenion id in data source definition [message #176741 is a reply to message #176524] |
Wed, 12 July 2006 09:27   |
Jason,
I am using Version 2.1 and I am retrieve my Birt Home using Property file
which is point to "C:/myInstall/birt/birt-runtime-2_1_0/ReportEngine". The
one you saw has been comment.
Kevin
Jason Weathersby wrote:
> Kevin,
> Jason
>> Hi Jason
>> below is my code
>> try
>> p.load(iobjStream);
>> return gstrFormat;
>> Engine");
>> try
>> run the report,
>> task.run();
>> catch (Exception e)
>>> Jason
birt-runtime-2_1_0ReportEnginepluginsorg.eclipse.birt.report .data.oda.jdbc_2.1.0.N20060628-1351drivers.
>>>> this error.
>>>> Kevin
| Re: Missing extenion id in data source definition [message #176848 is a reply to message #176741] |
Wed, 12 July 2006 11:04   |
Can you try to hard code it to see if it works.
The error you are getting appears to be because it can not find the plugins
directory.
Jason
news:c935fb953dddc9adf969a65abf9ddec4$1@www.eclipse.org...
> Jason,
> Kevin
>> Kevin,
>> Jason
>>> Hi Jason
>>> below is my code
>>> try
>>> p.load(iobjStream);
>>> return gstrFormat;
>>> Engine");
>>> try
>>> retrieve embedded images etc.
>>> run the report,
>>> task.run();
>>> catch (Exception e)
>>>> Jason
>>>>> this error.
>>>>> Kevin
| Re: Missing extenion id in data source definition [message #180831 is a reply to message #179121] |
Fri, 28 July 2006 03:10  |
Originally posted by: markrgli.gmail.com
Hello Kevin,
Were you able to figure it out now? I'm also having the same problem.
Thanks. :)
Mark
kevin wrote:
> Thanks for the reply. I don't run the report engine from web. So I don't
> need to copy the WebViewerExample/WEB-INF/platform. But I will take a
> look at the plugin.xml see where it is looking.
> Kevin
> Thibaud wrote:
>> I sometimes have the same problem.
>> My opinion about a "Missing extension id" is that it means that the
>> plugin
> is unreachable.
>> The plugin is unreachable because, it's not present or because the loader
> failed to resolved the plugin dependencies.
>> So if you take a look into the MANIFEST of the plugin, you'll see which
> plugin needs to be present.
>> Greg Hilton wrote:
>>> If anyone is interested, I solved this problem by copying the
>>> WebViewerExample/WEB-INF/platform directory to my application WEB-INF
>>> directory.
>>> Greg
>>> "Greg Hilton" <ghilton@espsg.com> wrote in message
>>> news:e9jgu2$2p8$1@utils.eclipse.org...
>>>> I am currently encountering the same problem described in this
>>>> thread when attempting to use an XML data source with the BIRT
>>>> report engine linked into my standalone application. I have the
>>>> 2.1.0 English version
> installed
>>>> only. Perhaps I can help debug.
>>>> Can someone tell me which code should be calling ModelPlugin.start?
>>>> Greg
>>>> Kevin Ou wrote:
>>>>> I believe it could be some setting of my machine that cause this
>>>>> happens
>>>>> My Machine has both birt 2.0 and birt 2.1 install. But in the
>>>>> script, I am using birt 2.1 engine home. Also I am using the
>>>>> eclipse buddled with birt 2.1 that I downloaded from birt's website
>>>>> to run the example. Also, my non-Unicode programs setting is
>>>>> Chinese(PRC). I hope that would be enough hints for my configuration.
Current Time: Sat Oct 25 05:05:08 EDT 2025
Powered by FUDForum. Page generated in 0.53583 seconds
