| How to remove the options of "-MMD -MP -MF" of C++ complier [message #175459] |
Thu, 24 August 2006 21:46  |
Originally posted by: lserlohn.163.com
I use Eclipse with CDT 3.0 to build my project for Embeded System of ARM,
which is C++ program.
But some option such as "-MMD -MP -MF" are not support by
ARM-cross-complier,so every time I uses:
arm-linux-g++ -O0 -g3 -Wall -MMD -MP -MF"main.d" -MT"main.d" -o"main.o"
"../main.cpp"
there always shows errors:
arm-linux-g++: unrecognized option `-MP'
arm-linux-g++: unrecognized option `-MFmain.d'
arm-linux-g++: unrecognized option `-MTmain.d'
I want to delete these options, but I don't know how to. I don't see these
options in project properties.I edited subdir.mk, but nothing changed.
What should I do?
| Re: How to remove the options of "-MMD -MP -MF" of C++ complier [message #197407 is a reply to message #175459] |
Mon, 16 July 2007 10:28   |
> ARM, which is C++ program.
> "../main.cpp"
> these options in project properties.I edited subdir.mk, but nothing
> changed. What should I do?
These options are used to output dependency information to the .d file,
which is then included by the makefile in order to properly react to
changes in files that your source files are dependent upon. E.g., this
is how header dependencies are handled so that if you change a header
file, the source files that include it are recompiled.
The options (actually the entire command) are provided by the dependency
calculator class. To get rid of them you'd have to create your own GNU
toolchain that used a different dependency calculator of your own devising.
Alternatively, you could use the internal builder rather than the
generated makefile. This tracks dependencies via the index, so it
doesn't rely on compiler invocations.
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
| Re: How to remove the options of "-MMD -MP -MF" of C++ complier [message #197595 is a reply to message #197570] |
Tue, 17 July 2007 14:36  |
>>> -o"main.o" "../main.cpp"
> Same thing here, but with g++ 2.8.1 on Solaris. Is my g++ too old to
> recognize "-MMD" etc and generate dependency info?
Not sure. Check the man page?
> (Sorry, total newbie to Eclipse here.... :-( Apologies in advance for
> an RTFM question...)
> How would I do that ("use the internal builder rather than the generated
> makefile")? And would I even want to? (I'm trying to migrate a big C++
> project currently under sniff/cvs, into Eclipse/CDT/ClearCase/Maven)
> Thanks and best regards,
> - Daniel
> Fredericton, NB Canada
If you select the project, you can view the properties on it with either
a right click or via the Project->Properties item. You can then go to
the C/C++ Build preferences and change the builder in the Builder
Settings Tab.
It's preferable to use the internal builder if you are able to do all
your builds inside Eclipse, because the internal builder is much faster
and scales much better. If you need to do command line builds at any
point though then you'll want the external builder with makefile
generation turned on.
Chris Recoskie
IBM Toronto
FUDForum. Page generated in 0.05115 seconds
