Home » Modeling » GMF (Graphical Modeling Framework) » GMF and MultiPageEditorPart
GMF and MultiPageEditorPart [message #173263] Thu, 21 February 2008 06:18 Go to next message
Originally posted by: gregory.vanseghbroeck.intec.ugent.be
Hello all,
I have a model with 3 environments:
* an environment which creates nodes and the relations between these
nodes
* an environment to create some types
* and finally, an environment which creates a workflow using the
above nodes and types.
I want to create a diagram (preferably something like MultiPageEditorPart)
where I can create the elements of these different environments and, where
needed, use objects from the other environments. What is the correct and
best way to accomplish this with GMF?
Kind Regards,
Gregory
Re: GMF and MultiPageEditorPart [message #173700 is a reply to message #173263] Fri, 22 February 2008 09:00 Go to previous messageGo to next message
Hello everybody,
Perhaps I wasn't clear enough.
Suppose I have a model like this one:
* Package
- environment1:Env1 (1, containing)
- environment2:Env2 (1, containing)
* Env1
- nodes:Node (1-*, containing)
- relationships:Rel (0-*, containing)
* Rel
- source:Node (1)
- target:Node (1)
* Node
- name:EString (1)
* Env2
- types:Type (1-*, containing)
* Type
- name:EString (1)
- node:Node (1)
Is it possible to create with GMF from this model one Diagram with
subdiagrams for each environment? Both subdiagrams need to use the same
model, because they refer to each others objects (Node).
Hopefully, now I receive an answer. If the question still is unclear, just
let me know.
Kind regards,
Gregory
Re: GMF and MultiPageEditorPart [message #173795 is a reply to message #173700] Fri, 22 February 2008 11:39 Go to previous message
Hello Gregory,
> same model, because they refer to each others objects (Node).
Yes. It is possible. I suggest you start doint this and ask the questions
as required.
Alex Shatalin
Previous Topic:Ecore with subpackages
Next Topic:[Sample Ecore Editor] Edit operation parameters
Current Time: Thu Oct 30 18:29:03 EDT 2025
Powered by FUDForum. Page generated in 0.03329 seconds
