Home » Eclipse Projects » Remote Application Platform (RAP) » Tomcat + RAP
Tomcat + RAP [message #1129941] Wed, 09 October 2013 00:54 Go to next message
I am trying to setup RAP application on my tomcat server.
RAP demo application work properly from my eclipse.
After that I am exporting warproduct via eclipse. I am using next demo war product configuration:
	<!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.2//EN" "http://java.sun.com/j2ee/dtds/web-app_2_2.dtd">
	<web-app id="WebApp">
	  <servlet id="bridge">
	    <servlet-name>equinoxbridgeservlet</servlet-name>
	    <display-name>Equinox Bridge Servlet</display-name>
	    <description>Equinox Bridge Servlet</description>
	    <servlet-class>org.eclipse.equinox.servletbridge.BridgeServlet</servlet-class>
	    <init-param>
	      <param-name>enableFrameworkControls</param-name>
	      <param-value>false</param-value>
	    </init-param>
	    <init-param>
	      <param-name>commandline</param-name>
	      <param-value>-registryMultiLanguage -console -ws rap</param-value>
	    </init-param>
	    <load-on-startup>1</load-on-startup>
	  </servlet>
	  <servlet-mapping>
	    <url-pattern>/*</url-pattern>
	  </servlet-mapping>
	</web-app>
After copying builded war file "controls.war" (depends on file name or not?) into webapps dir and I am getting 404 error "The requested resource is not available.".
I have checked troubleshooting page, my war file does not contains jetty plug-ins as well.
Also where is not ".log" file in the ws directory ".../apache-tomcat 6.0.37/work/Catalina/localhost/controls/eclipse/workspace/.metadata/"
I have found an advice on troubleshoouting page: "type ss in the console and see if all bundles are started. If not try starting them with "start <bundle-id>". The stack traces may hint to what is missing".
Looks like at first I need to specify OSGI remote port and connect to it via telnet. I have added "osgi.console=5471" in launch.ini (don't sure that it is correct place) and error occurs during connection telnet: Unable to connect to remote host.
Also I am removing my application work directory before re-deploying ".../work/Catalina/localhost/work/controls".
So, now I have 404 error and have no any logs/error. Could please help to find the main issue?
Igor
Re: Tomcat + RAP [message #1130210 is a reply to message #1129941] Wed, 09 October 2013 06:15 Go to previous messageGo to next message
Hi Igor,
if you are running your Tomcat server locally you could type the OSGi
commands in the Tomcat console window (I saw that you enabled the OSGi
console). What is the output of "ss" command (please post it here)? Do
you have non active plugins? How do you access your app?
http://<host>:<port>/<war_name>/<entrypoint_servlet_path>?
HTH,
Ivan
On 10/9/2013 7:54 AM, Igor Zapletnev wrote:
> Hello,
> <init-param>
> <param-value>false</param-value> </init-param>
> <init-param>
> rap</param-value> </init-param>
> <load-on-startup>1</load-on-startup> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> </web-app>
> I have checked
> http://wiki.eclipse.org/RAP/FAQ#Exported_WAR_file_does_not_work, my
> Igor
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Tomcat + RAP [message #1131170 is a reply to message #1130210] Thu, 10 October 2013 04:59 Go to previous message
Hi Ivan,
You was right I used incorrect application path http://<host>:<port>/<war_name> instead of http://<host>:<port>/<war_name>/<entrypoint_servlet_path>.
Thanks!
Previous Topic:Change background-color of systemmessage-dialog
Next Topic:ExternalBrowser.open(browserWindowId, url, SWT.NONE);
Current Time: Sun Sep 14 06:39:47 EDT 2025
Powered by FUDForum. Page generated in 0.03761 seconds
