Home » Language IDEs » ServerTools (WTP) » How does webapp deployment works?
How does webapp deployment works? [message #157575] Fri, 20 January 2006 16:32 Go to next message
Originally posted by: qiaoxin6.yahoo.com
I just tried the webtool. I deployed a JSP and Servlet webapp under
tomcat5.0.28 following the tutorial. But I do not know how the deployment
works.
1. I did not see my app is copied under ${Tomcat_dir}/webapps directory.
The docBase of the app is "/SchoolSchedule". I think I should see
${Tomcat_dir}/webapps/SchoolSchedule dir.
2. where is the context defined? I could not see schoolschedule.xml file
under Tomcat_dir/conf/catalina/localhost dir.
3.After I deployed the webapp use "Run on server" webtool, I loaded the
page "localhost:8080". It did not show the tomcat page (index.html under
ROOT dir)I had when I started tomcat from terminal. I could not load the
JSP example or servlet examples that downloaded with Tomcat.
I am not sure if I did something wrong or eclipse webtool deployment is
specific?
Thank you for advance.
Qiao
Re: How does webapp deployment works? [message #157691 is a reply to message #157575] Mon, 23 January 2006 09:13 Go to previous messageGo to next message
Originally posted by: bela.mobil-serv.cluj.astral.ro
Hi.
By default wtp uses only the engine of tomcat, it does not map your
webapps directory. If you look into your eclipse workspace, you'll see a
directory called Servers and in it other directories representing the
server instances you configured in WTP. Every such directory contains
configuration files that are used by WTP to tell tomcat where is the
"current" webapps directory.
All in all, if you want to see the apps deployed to tomcats original
"webapps" dir, you should uncheck the checkbox saying "Run modules
directly from the workspace (do not modify Tomcat installation)".
Bela.
Qiao Xin wrote:
> deployment works.
> ${Tomcat_dir}/webapps/SchoolSchedule dir. 2. where is the context
> defined? I could not see schoolschedule.xml file under
> specific?
> Qiao
Re: How does webapp deployment works? [message #157717 is a reply to message #157691] Mon, 23 January 2006 13:57 Go to previous messageGo to next message
Which web.xml file has to be used ? I found one under the project's
webContent directory and an other one under the server directory ?
I tried to declare the servlet in the web.xml file of the webcontent
directory and it didn't work.
Re: How does webapp deployment works? [message #157778 is a reply to message #157717] Mon, 23 January 2006 21:18 Go to previous messageGo to next message
Originally posted by: jazeltine.sbcglobal.net
rdaniel@neuf.fr (bob) wrote in news:c90002dcebc1061aed579fcd184d69cf$1
@www.eclipse.org:
When you use the wizard to create a new servlet, it modifies the web.xml
file that is under the WebContent/WEB-INF of the project. When you go to
"run on server" it will publish it to the tomcat instance. You should not
need to be editing the web.xml manually if you use the wizard.
Re: How does webapp deployment works? [message #158286 is a reply to message #157778] Sun, 29 January 2006 05:28 Go to previous messageGo to next message
that's right, when I use the "create servlet" wizzard, the web.xml file is
updated.
But I have still http 404, tomcat does not find the servlet, I will try to
find where is the problem
Re: How does webapp deployment works? [message #159088 is a reply to message #158286] Sun, 05 February 2006 19:12 Go to previous message
It might be possible that the files (especially web.xml) are not copied
from the workapce/yourproject to
workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp 0/webapps/yourproject/WEB-INF
try copying it by hand
cheers
max
> is updated.
> to find where is the problem
Previous Topic:Can't add Web App Libraries
Next Topic:Exploded deployment and auto reconcile
Current Time: Sun Nov 02 07:56:26 EST 2025
Powered by FUDForum. Page generated in 0.05061 seconds
