Home » Modeling » Epsilon » [Emfatic] bidirectional aggregation
[Emfatic] bidirectional aggregation [message #1068156] Fri, 12 July 2013 08:55 Go to next message
I'm wondering how references are handled with Emfatic. I've got the following metamodel with the according emfatic syntax:
index.php/fa/15571/0/
class Platform{
  	unsettable attr EString name = "Platform";
  	attr EString reference = "";
  	attr EString identifier = "";
  	val Variationpoint[*] variationpoints;
class Variationpoint{
	unsettable attr EString name = "Variationpoint";
	attr EString description = "";
Normally I would expect that this reference is bidirectional. So that Platform has an arbitrary number of Variationpoints and a Variationpoint knows its Platform. But this doesn't seems to be the case? I'm not able to acces the according Platform with an Variationpoint object.
So to overcome this, I tried to use an additional reference:
index.php/fa/15578/0/
But when I create a Platform and add a Variationpoint to this Platform, the Variationpoint don't know it's Platform. The user has to assign the reference in the property view manually.
How can I define a bidirectional aggregation with Emfatic?:
index.php/fa/15579/0/
Re: [Emfatic] bidirectional aggregation [message #1068159 is a reply to message #1068156] Fri, 12 July 2013 09:06 Go to previous messageGo to next message
Hi Phil,
You can use opposite references to do this [1].
class Platform{
val Variationpoint[*]#platform variationpoints;
ref Platform#variationpoints platform;
Dimitris
[1] http://refcardz.dzone.com/refcardz/essential-emf
Re: [Emfatic] bidirectional aggregation [message #1068199 is a reply to message #1068159] Fri, 12 July 2013 12:28 Go to previous messageGo to next message
Thx Dimitris, that work like a charm.
Re: [Emfatic] bidirectional aggregation [message #1070186 is a reply to message #1068199] Wed, 17 July 2013 08:22 Go to previous messageGo to next message
Hmm while it worked for the most cases, I get a warning for the following model:
class Pl{
  	unsettable attr EString name = "ProductLine";
  	val Fm[*]#pl fms;
@gmf.node(label="name", label.icon="false", color="238,233,233", border.color="0,0,0")
class Fm{
  	unsettable attr EString name = "Fm";
  	ref Pl[1]#fms pl;
  	@gmf.compartment(layout="list")
  	val Vc[*]#fm internalVc;
@gmf.node(label="expression", label.icon="true", figure="rectangle", border.color="0,0,0", color="238,233,233")
class Vc{
  	unsettable attr EString expression = "Vc";
        ref Fm[1]#internalVc fm;
I get the following warning, which is caused of the bidriectional reference between the classes Fm and Vc:
- A containment reference of a type with a container feature org.eclipse.emf.ecore.impl.EReferenceImpl@59e38a{platform:/resource/dummy#//Vc/fm} that requires instances to be contained elsewhere cannot be populated
I've no idea what is the problem in this case? Have I missed something?
Phil
Re: [Emfatic] bidirectional aggregation [message #1070272 is a reply to message #1070186] Wed, 17 July 2013 11:55 Go to previous messageGo to next message
Hi Phil,
What happens if your remove the [1] multiplicities? If memory serves, containment references, opposites and multiplicities with a lower bound > 0 don't always play well together.
Dimitris
Re: [Emfatic] bidirectional aggregation [message #1070309 is a reply to message #1070272] Wed, 17 July 2013 13:46 Go to previous message
Hi Dimitris,
the [1] multiplicities from ref Fm[1]#internalVc fm; was exactly the reason for this warning. It's working now anyway.
Phil
Previous Topic:[ETL] same metamodel
Next Topic:EOL polishing script setup
Current Time: Sat Sep 13 14:00:22 EDT 2025
Powered by FUDForum. Page generated in 0.03823 seconds
