Home » Modeling » EMF » [EMF Query 2] Help with writing conditions
[EMF Query 2] Help with writing conditions [message #870660] Wed, 09 May 2012 05:21
I'm trying to write a query which has a condition composed of two different other conditions, something like:
FROM Book as b
SELECT b.title, b.pages
WHERE b.title = "First book" and b.pages > 20
I need some help cause I have no idea how to convert the finalClause which represents the results of the AND operation applied to this two conditions to a WhereEntry Object in order to be able to pass it to the Where part of the query.
Here is my code:
WhereString whereStringEqualTo = new WhereString("title", Operation.EQUAL, "Second book");
		WhereInt whereIntGreaterThan = new WhereInt("pages", Operation.GREATER, 20);
		org.eclipse.emf.query2.WhereEntry whereStringEqualToEntry = new LocalWhereEntry("b", whereStringEqualTo);
		org.eclipse.emf.query2.WhereEntry whereIntGreaterThanEntry = new LocalWhereEntry("b", whereIntGreaterThan);
		ArrayList<WhereClause> clauses = new ArrayList<WhereClause>();
		clauses.add(whereStringEqualTo);
		clauses.add(whereIntGreaterThan);
		WhereOr finalClause = new WhereOr(clauses);
		org.eclipse.emf.query2.WhereEntry[] whereEntries = new org.eclipse.emf.query2.WhereEntry[] {whereStringEqualToEntry, whereIntGreaterThanEntry};
If I'm running the query now, as it is written I get an AND operator between whereStringEqualToEntry and whereIntGreaterThanEntry but the problem is what if I want to do a OR operations between them?
The second question would be, is it possible to use also OCL Conditions instead these condition classes that are already provided by Query 2? If so, how can I convert from BaseCondition class to a WhatEntry object?
Any answer would be much appreciated.
Radu Comaneci
[Updated on: Wed, 09 May 2012 05:22] by Moderator
Previous Topic:Problem XSD to ECore mapping
Next Topic:Adapt Getters/Setters syntax
Current Time: Fri Oct 31 11:33:24 EDT 2025
Powered by FUDForum. Page generated in 0.27566 seconds
