Home » Language IDEs » ServerTools (WTP) » Tomcat refuses using port 8080
Tomcat refuses using port 8080 [message #101805] Mon, 09 May 2005 22:58 Go to next message
Originally posted by: doanphihai.yahoo.com
Hi I created a Web App with Eclipse3.1M6, WTP-M4, Tomcat5.5.4, JDK1.4.8_02
and when I started this webapp I got this problem
Several ports (8080, 8009) required by Tomcat v5.5 Server @ localhost are
already in use. The server may already be running in another process, or a
system process may be using the port. To start this server you will need
to stop the other process or change the port number(s).
I make sure there isn't any Tomcat server is running. Any idea for this?
Re: Tomcat refuses using port 8080 [message #101818 is a reply to message #101805] Mon, 09 May 2005 23:01 Go to previous messageGo to next message
Originally posted by: hapy710.yahoo.com.cn
Perhaps the ports were used by other services.
"HaiDoan" <doanphihai@yahoo.com> д
Re: Tomcat refuses using port 8080 [message #101827 is a reply to message #101818] Mon, 09 May 2005 23:19 Go to previous messageGo to next message
I run netstat in command line to check it, but it's not occupied
Re: Tomcat refuses using port 8080 [message #101852 is a reply to message #101827] Tue, 10 May 2005 00:41 Go to previous messageGo to next message
May be this makes problem clearly.
I used to work in a project in EclipseM5a and WtpM3, then I upgraded to
EclipseM6 and WtpM4 and opened that project. At fist it worked fine, but
two days after, it took this problem. Until now I can not use eclipse to
launch tomcat anymore
Re: Tomcat refuses using port 8080 [message #101873 is a reply to message #101852] Tue, 10 May 2005 03:56 Go to previous messageGo to next message
In the meantime I can do nothing with WTP, I restart machine, then
reinstall Eclipse and WTP, create a simple web-app, and I stuck again.
What happen in my PC?
Re: Tomcat refuses using port 8080 [message #101927 is a reply to message #101873] Tue, 10 May 2005 09:21 Go to previous messageGo to next message
You could try putting a '1' in front of all the port numbers in the
Tomcat configuration to switch it to alternate ports. If this works,
switch them back one by one to determine which ones conflict. If they
all conflict, I would guess you might have Tomcat running as a service.
Larry
Re: Tomcat refuses using port 8080 [message #102217 is a reply to message #101827] Tue, 10 May 2005 22:49 Go to previous messageGo to next message
What about port scanning your machine instead? netstat only reports
active connections, and it's more likely you have a server just
listening on one of those ports and not actually servicing a request
at the moment.
- Nitin
Re: Tomcat refuses using port 8080 [message #102333 is a reply to message #101927] Wed, 11 May 2005 05:15 Go to previous messageGo to next message
Hi Larry
that's nice solution, I can start Tomcat, but I can not lauch url:
http://localhost:8080, Have you ever see this bug before?
--P.H
> Larry
>>You could try putting a '1' in front of all the port numbers in the Tomcat
configuration to switch it to alternate ports. If this works, switch them
back one by one to determine which ones conflict. If they all conflict, I
Larry
Re: Tomcat refuses using port 8080 [message #102375 is a reply to message #102333] Wed, 11 May 2005 08:42 Go to previous message
The port number in the URL should change as well, possibly to
http://localhost:18080. It must match the HTTP port of the Tomcat you
are running.
Did you try switching the ports back individually to see which have
conflicts?
Larry
HaiDoan wrote:
> Hi Larry
> --P.H
>> Larry
>>> again. What happen in my PC?
>>> Tomcat
> them back one by one to determine which ones conflict. If they all
> Larry
Previous Topic:OperationDesc for add was not synchronized .....
Next Topic:Obsolete method on the stack
Current Time: Tue Oct 14 13:07:36 EDT 2025
Powered by FUDForum. Page generated in 0.05306 seconds
