Home » Eclipse Projects » Remote Application Platform (RAP) » IRunnableWithProgress refresh problem
IRunnableWithProgress refresh problem [message #666411] Wed, 20 April 2011 07:18 Go to next message
Hi @all,
I have a problem with RAP and the IRunnableWithProgress. When the runnable is finished, the GUI doesn't refresh automatically.
This part is the runnable:
final IRunnableWithProgress runnable = new IRunnableWithProgress()
         public void run(final IProgressMonitor monitor) throws InvocationTargetException, InterruptedException
               // Do something
               monitor.beginTask("Progress is running...", IProgressMonitor.UNKNOWN);
               monitor.done();
This part is the service call:
final IProgressService service = (IProgressService) PlatformUI.getWorkbench().getService(IProgressService.class);
service.run(true, false, runnable);
After runnable is finished a dialog with a notification pops up. It's a "MessageDialog.openInformation" - method call.
The run method does an action, that last for 10 - 60 seconds, so the user have to wait this time. After this action is finished the GUI doesn't update automatically.
The user has to move the dialog to refresh the GUI and make the dialog disappear.
Anyone an idea or a suggestion to update the view automatically?
Greetings
Stefan R.
[Updated on: Wed, 20 April 2011 07:22] by Moderator
Re: IRunnableWithProgress refresh problem [message #666480 is a reply to message #666411] Wed, 20 April 2011 10:27 Go to previous messageGo to next message
Stefan,
looks like you ran into this bug
315418: Progress Dialog will not automatically close during UICallback
https://bugs.eclipse.org/bugs/show_bug.cgi?id=315418
It was fixed in 1.4 M3. What version of RAP are you running?
- Rüdiger
On 20.04.2011 13:18, Stefan R. wrote:
> Hi @all,
> @Override
> // Do something
> monitor.done();
> PlatformUI.getWorkbench().getService(IProgressService.class) ;
> disappear.
> Anyone an idea or a suggestion?
> Greetings
> Stefan R.
Re: IRunnableWithProgress refresh problem [message #666486 is a reply to message #666480] Wed, 20 April 2011 10:56 Go to previous messageGo to next message
I'm running rap 1.3.0.20100615-1704.
Stefan
Re: IRunnableWithProgress refresh problem [message #666508 is a reply to message #666486] Wed, 20 April 2011 11:40 Go to previous messageGo to next message
Stefan,
the fix was also included in the 1.3.2 service release. You can obtain
it from the download page [1].
HTH
Rüdiger
[1] http://eclipse.org/rap/downloads
> Stefan
Re: IRunnableWithProgress refresh problem [message #666511 is a reply to message #666508] Wed, 20 April 2011 11:53 Go to previous messageGo to next message
Rüdiger,
thx 4 help.
Stefan
Re: IRunnableWithProgress refresh problem [message #666620 is a reply to message #666511] Thu, 21 April 2011 06:51 Go to previous messageGo to next message
Hey,
in the case of the bug I had to patch the RAP 1.3 jar files in my targetplatform. I checked out the rap projects from the CVS with the 1.3 maintenance branch.
How can I build the patched jars?
I got some errors while running the "RAP Releng" - Launch Configuration:
!SESSION 2011-04-21 12:10:42.566 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_21
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments:  -application org.eclipse.ant.ui.antRunner -buildfile C:\opt\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20080604\scripts\build.xml
Command-line arguments:  -application org.eclipse.ant.ui.antRunner -data C:\opt\workspace/../runtime-New_configuration -dev file:C:/opt/workspace/.metadata/.plugins/org.eclipse.pde.core/RAP Releng/dev.properties -os win32 -ws win32 -arch x86 -buildfile C:\opt\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20080604\scripts\build.xml
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2011-04-21 12:10:42.956
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.simpleconfigurator.Activator.start() of bundle org.eclipse.equinox.simpleconfigurator.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
Caused by: java.lang.IllegalStateException: The System Bundle was updated. The framework must be restarted to finalize the configuration change
	at org.eclipse.equinox.internal.simpleconfigurator.ConfigApplier.install(ConfigApplier.java:71)
	at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:129)
	at org.eclipse.equinox.internal.simpleconfigurator.SimpleConfiguratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:143)
	at org.eclipse.equinox.internal.simpleconfigurator.Activator.start(Activator.java:48)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
	... 11 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2011-04-21 12:10:42.956
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.200.v20100503 [1] is not active.
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Any suggestions to fix the problem? Or is there any tutorial out there "how to build the rap projects from the CVS"?
Greetings
Stefan
Re: IRunnableWithProgress refresh problem [message #666627 is a reply to message #666620] Thu, 21 April 2011 07:24 Go to previous messageGo to next message
Stefan,
as Rüdiger said, the fix is included in the 1.3.2 service release. In
RAP download page [1], follow "RAP Runtime" -> "latest release" links to
update your target platform either from p2 repository or zipped version.
HTH,
Ivan
On 4/21/2011 1:51 PM, Stefan R. wrote:
> Hey,
> -buildfile
> C:\opt\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20080604 \scripts\build.xml
> file:C:/opt/workspace/.metadata/.plugins/org.eclipse.pde.cor e/RAP
> !MESSAGE !STACK 0
> org.eclipse.equinox.internal.simpleconfigurator.Activator.st art() of
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:806)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:370)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:374)
> at
> org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1067)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:561)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:546)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:459)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:243)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:440)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
> change
> at
> org.eclipse.equinox.internal.simpleconfigurator.ConfigApplie r.install(ConfigApplier.java:71)
> at
> org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:12 9)
> at
> org.eclipse.equinox.internal.simpleconfigurator.SimpleConfig uratorImpl.applyConfiguration(SimpleConfiguratorImpl.java:14 3)
> at
> org.eclipse.equinox.internal.simpleconfigurator.Activator.st art(Activator.java:48)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
> ... 11 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE Bundle
> active.
> !STACK 1
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> Greetings
> Stefan
Re: IRunnableWithProgress refresh problem [message #666628 is a reply to message #666627] Thu, 21 April 2011 07:43 Go to previous messageGo to next message
Hey Ivan,
well that helped a lot, but I try to understand the whole RAP thing. So I want to build it from the CVS. Maybe in the future there is a better docu, how to build the whole stuff.
So maybe I take the thing as it is and be lucky ^^
Stefan
Re: IRunnableWithProgress refresh problem [message #666632 is a reply to message #666628] Thu, 21 April 2011 07:57 Go to previous messageGo to next message
Hm, there's actually no magic involved :). Although it can be quite confusing when start with it.
You replace the jars in your targetplatform with the new ones, or better, set up a new targetplatform with the new rap bundles and your individual bundles, if there are any.
To use the CVS version you simply check out the RAP bundles in your workspace. In the launch-configurations of your application you can configure which bundles should be used (target/workspace).
To build a deployable war file you can stick to your prefered build procedure. When using for example the feature-based build (rap.demo.feature), the webappbuilder automatically picks the RAP bundles with the latest version, e.g. the bundles from you workspace if you have checked them out from CVS.
Maybe this helps a bit for your understanding :).
HTH,
Ben
Am 21.04.2011 13:43, schrieb Stefan R.:
> Hey Ivan,
> Stefan
Re: IRunnableWithProgress refresh problem [message #666926 is a reply to message #666632] Sun, 24 April 2011 13:20 Go to previous message
Stefan,
in addition to what Ben already mentioned, there are some hints on the
RAP hompe page [1] that may also help.
Plus, make sure that you understand how plug-in/bundle development of
Eclipse projects in Eclipse works in general [2].
If you still prefer ready-made builds, you may also try that latest
milstone of the 1.4 development stream [3].
HTH
Rüdiger
[1] http://eclipse.org/rap/source
[2] http://wiki.eclipse.org/CVS_Howto
[3] http://eclipse.org/rap/downloads/ -> select latest stable build
> HTH,
> Ben
>> Hey Ivan,
>> Stefan
Previous Topic:Information about RAP
Next Topic:Display#addFilter
Current Time: Thu Oct 30 12:25:26 EDT 2025
Powered by FUDForum. Page generated in 0.05164 seconds
