| Launcher finds Sun VM instead of IBM VM on Windows. [message #656772] |
Mon, 28 February 2011 09:40  |
I have an IBM VM as my system VM (the IBM java.exe is in \windows\system32
When I start Memory Analyzer it uses the Sun VM instead. I think this is because org.eclipse.equinox.executable/library/win32/eclipseWin.c doesn't find a JRE/SDK directory for the java.exe, so goes straight to using registry keys to find the VM.
I know I could use -vm to chose a VM, but I think the launcher could do better. The simplest solution would be to use isSunVM() on the executable, and only use the registry keys if it is a Sun VM. Starting the java.exe otherwise for IBM VMs would be acceptable for me, though using the IBM registry keys and linking to java.dll would be even better.
C:\Documents and Settings\Administrator>java -version
java version "1.6.0"
Java(TM) SE Runtime Environment (build pwi3260sr8fp1ifix-20100903_02(SR8 FP1+IZ83654))
IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 Windows XP x86-32 jvmwi3260sr8-20100401_55940 (JIT enabled, AOT enabled)
J9VM - 20100401_055940
JIT - r9_20100401_15339
GC - 20100308_AA)
JCL - 20100903_02
C:\Documents and Settings\Administrator>"c:\Program Files\IBM\Java60\jre\bin\java.exe" -version
GC - 20100308_AA)
JCL - 20100903_02
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
-launcher
C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\MemoryAnalyzer.exe
-name
MemoryAnalyzer
--launcher.library
C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20090519\eclipse_1206.dll
-startup
C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plugins\org.eclipse.equinox.launcher_1.0.200.v20090520.jar
-vm
C:\Program Files\Java\jre6\bin\client\jvm.dll
eclipse.home.location=file:/C:/m5/MemoryAnalyzer-1.0.1.20100809-win32.win32.x86/mat/
eclipse.launcher=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\MemoryAnalyzer.exe
eclipse.product=org.eclipse.mat.ui.rcp.MemoryAnalyzer
eclipse.startTime=1298901024062
eclipse.vm=C:\Program Files\Java\jre6\bin\client\jvm.dll
eclipse.vmargs=-Xmx1024m
-Djava.class.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plugins\org.eclipse.equinox.launcher_1.0.200.v20090520.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre6\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre6\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre6
java.io.tmpdir=C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\
java.library.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:\Program Files\ThinkPad\Utilities;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\IBM\Infoprint Select;C:\Notes;C:\Program Files\XLView;C:\lotus\compnent;C:\Utilities;C:\Program Files\IBM\Personal Communications\;C:\Program Files\IBM\Trace Facility\;C:\Program Files\ThinkPad\ConnectUtilities;C:\WINDOWS\Downloaded Program Files;C:\Program Files\ObjREXX;C:\Program Files\ObjREXX\OODIALOG;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Common Files\Lenovo;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\IBM\CMVCDC50
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_18-b07
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_18
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=16.0-b13
line.separator=
| Re: Launcher finds Sun VM instead of IBM VM on Windows. [message #656820 is a reply to message #656772] |
Mon, 28 February 2011 12:37   |
Andrew,
The launcher has a JRE tab. By default it uses the same JRE you used to
run Eclipse itself, I think. But you can configure other JREs and use
those.
> \windows\system32
> GC - 20100308_AA)
> JCL - 20100903_02
> GC - 20100308_AA)
> JCL - 20100903_02
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\Memo ryAnalyzer.exe
> -name
> MemoryAnalyzer
> --launcher.library
> C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plug ins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.200.v20 090519\eclipse_1206.dll
> -startup
> C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.win32.x86\mat\plug ins\org.eclipse.equinox.launcher_1.0.200.v20090520.jar
> -vm
> eclipse.home.location=file:/C:/m5/MemoryAnalyzer-1.0.1.20100 809-win32.win32.x86/mat/
> eclipse.launcher=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.w in32.x86\mat\MemoryAnalyzer.exe
> -Djava.class.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32. win32.x86\mat\plugins\org.eclipse.equinox.launcher_1.0.200.v 20090520.jar
> file.separator=\
> java.class.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32.wi n32.x86\mat\plugins\org.eclipse.equinox.launcher_1.0.200.v20 090520.jar
> java.library.path=C:\m5\MemoryAnalyzer-1.0.1.20100809-win32. win32.x86\mat;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32; C:\WINDOWS;C:/Program
> Files\ThinkPad\Utilities;C:\WINDOWS\system32;C:\WINDOWS;C:\W INDOWS\System32\Wbem;C:\Program
> Files\IBM\CMVCDC50
> line.separator=
FUDForum. Page generated in 0.05168 seconds
