Home » Modeling » TMF (Xtext) » Testing the validator, programmatically
Testing the validator, programmatically [message #633042] Fri, 15 October 2010 04:06 Go to next message
In chapter 5. Runtime Concepts, section Test Validators of the users guide, methods for testing the validator are described. Unfortunately, only method for building a model manually is described, but not how to use the "can ...use EMF's ResourceSet to load models from your hard disk" method.
Does someone have some example (code) for me how to do that?
Thanks!
Re: Testing the validator, programmatically [message #633064 is a reply to message #633042] Fri, 15 October 2010 04:20 Go to previous messageGo to next message
You can call the validation like this:
XtextResource res = (XtextResource) myResource;
List<Issue> issues = res.getResourceServiceProvider()
.getResourceValidator()
.validate(res,
CheckMode.ALL,
CancelIndicator.NullImpl);
Sven
Am 10/15/10 10:06 AM, schrieb Bodo:
> disk" method.
> Thanks!
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Testing the validator, programmatically [message #633509 is a reply to message #633064] Mon, 18 October 2010 05:42 Go to previous messageGo to next message
Hello Sven,
I just tried to insert this code schnipsel, but in vain. 1st I got an error message with "CancelIndicator.NullImpl" I can't resolve. Either import from "org.eclipse.xtext.util" nor from "org.eclipse.xtext.validation" works!
BTW. where I have to place this code schnipsel? I added two classes under validation extending AbstractXtextTests and AbstractDeclarativeValidator as suggested by the user guide.
... and what is "myResource", is this just an input stream for the text of my DSL? A think, one have to convert the text file into something for getting a "myResource"?
Thanks ...
Bodo
Re: Testing the validator, programmatically [message #633800 is a reply to message #633509] Tue, 19 October 2010 09:35 Go to previous message
Am 10/18/10 11:42 AM, schrieb Bodo:
> Hello Sven,
Sorry, I think it's "new CancelIndicator.NullImpl()"
In your unit test.
If you extend AbstractXtextTests, then you can obtain a Resource for
your model (string literal) like this:
XtextResource myResource = getResource(new
StringInputStream("my.dsl(expression)"));
Sven
Previous Topic:Problem with stale line numbers
Next Topic:How to set k=1 in a mwe2 file
Current Time: Sat Nov 08 03:28:15 EST 2025
Powered by FUDForum. Page generated in 0.04655 seconds
