Home » Modeling » M2T (model-to-text transformation) » [Accelo]use of @code-explicit
[Accelo]use of @code-explicit [message #512301] Thu, 04 February 2010 10:40 Go to next message
Originally posted by: koos.waytostay.com
Hi All,
I have to generate code from UML getting the following result for c-sharp
like
[ServiceContract]
public interface IBookingService
[OperationContract]
BookingContract getBookingContract();
I tried using @code-explicit according the standard but this does not work.
Is this not implemented and if not is there another way to generate the []
maybe using an excape character?
Koos
Re: [Accelo]use of @code-explicit [message #512309 is a reply to message #512301] Thu, 04 February 2010 11:18 Go to previous messageGo to next message
According to Accelo documentation, the code explicit syntax is not implemented yet.
But you can escape bracket characters like that :
['['/]ServiceContract[']'/]
['['/]OperationContract[']'/]
Sebastien
Re: [Accelo]use of @code-explicit [message #512450 is a reply to message #512309] Fri, 05 February 2010 03:25 Go to previous message
--------------070208020100060409090801
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Sebastien, Koos,
Sebastien's answer is exactly right, just wanted to mention that the
closing bracket ']' doesn't need to be escaped.
Laurent Goubet
Obeo
> implemented yet.
> Regards
> Sebastien
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------070208020100060409090801--
Previous Topic:[Acceleo]How to protect user code by signature changes
Next Topic:starting an Ant task from a Xpand workflow
Current Time: Fri Oct 17 02:58:22 EDT 2025
Powered by FUDForum. Page generated in 0.03898 seconds
