Home » Eclipse Projects » JFace » [Databinding] ValueChangeListers on MultiValidator ValidationStatus don't fire
[Databinding] ValueChangeListers on MultiValidator ValidationStatus don't fire [message #487398] Wed, 23 September 2009 02:12 Go to next message
Hi All,
I'm attempting to use an IListChangeListener on the ValidationStatus of MultiValidator to update an FormPage's IMessageManager when the validation changes. When the initial state of the validator is ERROR, and the next state post-bind is also error, the ValueChangeListeners are not fired. This is due to the Util.equals check in MultiValidator$ValidationStatusObservableValue#doSetValue which prevents the event firing is it's value is the same as the previous value.
The catch is that the initial value is set BEFORE the ValueChageListener is added (as getValueStatus() calls revalidate which sets then causes the initial value to be set.
The is best shown in a test case.
public class MultiValiditatorValidationStatusTest
	private WritableValue value1;
	private WritableValue value2;
	private BooleanHolder booleanHolder;
	private DataBindingContext dataBindingContext;
	@Before
	public void beforeEach()
		CurrentRealm.setDefault(SWTObservables.getRealm(Display.getCurrent()));
		value1 = new WritableValue();
		value2 = new WritableValue();
		booleanHolder = new BooleanHolder();
		dataBindingContext = new DataBindingContext();
	@Test
	public void shouldCallHandleValueChangeOnIValueChangeListenersForMultiValidator() throws Exception
// value1.setValue(Integer.valueOf(1));
		MultiValidator multiValidator = new MultiValidator()
			protected IStatus validate()
				Object value = value1.getValue();
				if (value != null && value instanceof Number && ((Number) value).intValue() == 1)
					return ValidationStatus.ok();
				return ValidationStatus.error("Value was not one");
		multiValidator.getValidationStatus().addValueChangeListener(new IValueChangeListener()
			public void handleValueChange(ValueChangeEvent event)
				booleanHolder.value = true;
		dataBindingContext.addValidationStatusProvider(multiValidator);
		dataBindingContext.bindValue(multiValidator.observeValidatedValue(value1), value2, null, new UpdateValueStrategy(
			UpdateValueStrategy.POLICY_NEVER));
		value1.setValue(Integer.valueOf(2));
		assertTrue(booleanHolder.value);
	private static class CurrentRealm extends Realm
		private boolean current;
		public CurrentRealm()
			this(false);
		public CurrentRealm(boolean current)
			this.current = current;
		public boolean isCurrent()
			return current;
		public void setCurrent(boolean current)
		protected void syncExec(Runnable runnable)
			// do nothing
		public void asyncExec(Runnable runnable)
			// do nothing
		protected static Realm setDefault(Realm realm)
			return Realm.setDefault(realm);
	private static class BooleanHolder
		public boolean value = false;
When multiValidator.getValidationStatus() is called, the validator is fired and the initial value is set. So when value1.setValue(Integer.valueOf(2)); is called the nothing happens. In the real world, the IMessageManager doesn't get updated.
I can work around this in three ways:
1. Make sure the model is valid before the ValueChangeListener is added. (In the test case by doing value1.setValue(Integer.valueOf(1)) first off. Not really possible in the real world.)
2. toggle the value so the validators result is also toggled and the Util.equals check is passed (Also not possible in the real world).
3. Make the first value returned by the validator different to any of the possible following results (eg ValidationStatus.cancel("foo");), but still making sure any dependant IObservableValues are called (hence the Object value = value1.getValue(); before the firedFirst check).
			boolean firedFirst = false;
				if (!firedFirst)
					firedFirst = true;
					return ValidationStatus.cancel("ignore first fire");
Is this expected behaviour or a bug?
Ashley Cambrell
Re: [Databinding] ValueChangeListers on MultiValidator ValidationStatus don't fire [message #488485 is a reply to message #487398] Mon, 28 September 2009 16:55 Go to previous messageGo to next message
Ashley, would you file a bug report for this?
https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=E clipse&product=Platform&component=UI&short_desc=[DataBinding]&version=3.6
Matthew
Ashley Cambrell wrote:
> Hi All,
> @Before
> CurrentRealm.setDefault(SWTObservables.getRealm(Display.getC urrent()));
> @Test
> public void
> shouldCallHandleValueChangeOnIValueChangeListenersForMultiVa lidator()
> throws Exception
> @Override
> multiValidator.getValidationStatus().addValueChangeListener( new
> @Override
> dataBindingContext.addValidationStatusProvider(multiValidato r);
> dataBindingContext.bindValue(multiValidator.observeValidated Value(value1),
> this(false);
> return current;
> // do nothing
> // do nothing
> @Override
> if (!firedFirst)
> firedFirst = true;
> Cheers,
> Ashley Cambrell
Re: [Databinding] ValueChangeListers on MultiValidator ValidationStatus don't fire [message #488493 is a reply to message #488485] Mon, 28 September 2009 17:50 Go to previous message
Done
https://bugs.eclipse.org/bugs/show_bug.cgi?id=290754
Previous Topic:How to use ComputedValue for content assistance?
Next Topic:MultiValidator does not attach to empty IObservableList
Current Time: Wed Nov 05 16:37:47 EST 2025
Powered by FUDForum. Page generated in 0.03864 seconds
