Home » Eclipse Projects » Rich Client Platform (RCP) » RCP export problem
RCP export problem [message #464461] Wed, 07 March 2007 12:15 Go to next message
I have a problem with the export of a RCP application. Launched from
eclipse it works perfect. When I export it with the Eclipse Product export
wizard it exports all the required packages. When I try to launch the
application the RuntimeException: No application id has been found.
appears. The Manifest.mf exported int the jar containing the application
has only one line:
Manifest-Version: 1.0.
and is different from the one I have in the workbench.
If I take the Manifest.mf from the workbench and place it into the
application jar (replacing the one with only one line) the RCP application
starts without problems. I've placed the META_INF/Manifest.mf in the
build. The built and export don't throw errors. Can someone pls tell me
what is the problem or where to look? I've tried cleaning the project,
update the classpath, rebuilt the manifest path ....
Re: RCP export problem [message #464469 is a reply to message #464461] Thu, 08 March 2007 03:33 Go to previous messageGo to next message
Originally posted by: peter_ossipov.mail.ru
Hello Radu
Surprisingly, but I have the same problem which I am struggling to
solve. I would like to know the "proper" solution, as well.
> export wizard it exports all the required packages. When I try to
> launch the application the RuntimeException: No application id has
> been found. appears. The Manifest.mf exported int the jar containing
> the application has only one line: Manifest-Version: 1.0. and is
> application starts without problems. I've placed the
> META_INF/Manifest.mf in the build. The built and export don't throw
> errors. Can someone pls tell me what is the problem or where to look?
> I've tried cleaning the project, update the classpath, rebuilt the
> manifest path ....
> Thanks
Re: RCP export problem [message #464472 is a reply to message #464469] Thu, 08 March 2007 03:47 Go to previous messageGo to next message
I have found the problem in my workspace - there was an entry in the
workspace/src folder for META-INF/MANIFEST.MF (don't know how it got there)
that contained the singled line MANIFEST.MF file. It seemed that the export
process packed this manifest instead of the correct one.
Hope this helps,
Radu Dumitrescu
Re: RCP export problem [message #464474 is a reply to message #464472] Thu, 08 March 2007 04:10 Go to previous messageGo to next message
Hello Radu.
Thanks very much for letting us know of the cause.
I just did not understand what happened. You are talking about
workspace/src
folrer. How can the folder contain a line? I thought you can say like
that with regard to text files, eh?
Could you please kindly explain the situation a bit more?
Thanks in advance.
> Hope this helps,
> Radu Dumitrescu
Re: RCP export problem [message #464475 is a reply to message #464474] Thu, 08 March 2007 04:23 Go to previous messageGo to next message
Sorry if I didn't make my self clear. The valid manifest was in the
workspace/META-INF/MANIFEST.MF and it contained all the needed information
to start the RCP application:
Bundle-ManifestVersion: 2
Bundle-Name: xxx
Bundle-SymbolicName: xxx; singleton:=true
Bundle-Version: 1.0.0
Bundle-Vendor: xxx
Bundle-Localization: plugin
Require-Bundle: org.eclipse.ui,
org.eclipse.birt.report.engine
Bundle-ClassPath: .,
lib/xxx.jar,
lib/yy.jar,
but another one was in the workspace/src/META-INF/MANIFEST.MF that contained
a single line:
The last one was the one packed in the RCP application plug-in jar and so it
made the startup fail. I deleted the folder workspace/src/META-INF and
reexported the RCP application (the valid MANIFEST.MF was packed in the jar)
and now it works.
Re: RCP export problem [message #464477 is a reply to message #464475] Thu, 08 March 2007 04:42 Go to previous messageGo to next message
Ok, thanks Radu so much!
Let me go and check! Quite possibly I can have the same problem.
> Bundle-Name: xxx
> Bundle-Vendor: xxx
> lib/xxx.jar,
> lib/yy.jar,
> a single line:
> and now it works.
Re: RCP export problem [message #464488 is a reply to message #464461] Thu, 08 March 2007 18:34 Go to previous message
Originally posted by: jcarroll.us.ibm.com
I have had similar export problems in the past.
open the run dialog and make sure that all the required
plugins are checked for your product definition.
GL.
John.
> export wizard it exports all the required packages. When I try to launch
> the application the RuntimeException: No application id has been found.
> has only one line: Manifest-Version: 1.0. and is different from the one
> manifest path ....
> Thanks
Previous Topic:TreeViewer and scrolling
Next Topic:Multiple selection of grid items
Current Time: Tue Sep 16 14:39:21 EDT 2025
Powered by FUDForum. Page generated in 0.03486 seconds
