GridData exclude problem [message #460413] |
Thu, 25 August 2005 09:13  |
I want to switch between two composites when clicking on a button. I use
the GridData.exclude attribute to do so. The problem is that the switch
process only works once. The snippet below illustrates this.
Thanks for your help,
Helene
package test;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class SwitchableCompositeWithExclude {
private static Composite bigOne;
private static Composite smallOne;
private static Composite rightComposite;
private static Button button;
Display display = Display.getDefault ();
final Shell shell = new Shell (display);
shell.setLayout(new GridLayout(2, false));
Composite leftComposite = new Composite(shell, SWT.BORDER);
leftComposite.setLayoutData(new GridData());
leftComposite.setLayout(new GridLayout());
button = new Button(leftComposite, SWT.TOGGLE);
button.setText("Switch");
button.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent arg0) {
if (button.getSelection()) {
switchComposite(1);
} else {
switchComposite(0);
button.setLayoutData(new GridData());
rightComposite = new Composite(shell, SWT.BORDER);
rightComposite.setLayoutData(new GridData());
rightComposite.setLayout(new GridLayout());
bigOne = new Composite(rightComposite, SWT.BORDER);
bigOne.setLayoutData(new GridData());
bigOne.setLayout(new GridLayout());
Label label;
for (int i = 0; i < 5; i++) {
label = new Label(bigOne, SWT.NONE);
label.setText("Label number " + i);
label.setLayoutData(new GridData());
smallOne = new Composite(rightComposite, SWT.BORDER);
smallOne.setLayoutData(new GridData());
smallOne.setLayout(new GridLayout());
label = new Label(smallOne, SWT.NONE);
label.setText("SMALL ONE !");
switchComposite(0);
shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose ();
private static void switchComposite(int value) {
GridData smallGridData = (GridData) smallOne.getLayoutData();
GridData bigGridData = (GridData) bigOne.getLayoutData();
if (value == 0) {
System.out.println("Hiding BIG Showing SMALL");
bigGridData.exclude = true;
smallGridData.exclude = false;
} else {
System.out.println("Hiding SMALL Showing BIG");
smallGridData.exclude = true;
bigGridData.exclude = false;
rightComposite.layout();
rightComposite.getParent().layout();
Re: GridData exclude problem [message #460447 is a reply to message #460413] |
Fri, 26 August 2005 12:27   |
The problem is that exclude just excludes the widget from layout, it doesn't
hide it. Here is the relevent part of your code fixed:
if (value == 0) {
bigOne.setVisible (!(bigGridData.exclude = true));
smallOne.setVisible (!(smallGridData.exclude = false));
} else {
smallOne.setVisible (!(smallGridData.exclude = true));
bigOne.setVisible (!(bigGridData.exclude = false));
"hortiz" <hortiz@xxxxxx.xxx> wrote in message
news:50eb50ab0545a8ece877d51e872287ab$1@www.eclipse.org...
> Helene
> package test;
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> switchComposite(1);
> } else {
> switchComposite(0);
> Label label;
> switchComposite(0);
> shell.open();
> display.sleep();
> display.dispose ();
> if (value == 0) {
> } else {
FUDForum. Page generated in 0.03428 seconds
