Home » Eclipse Projects » Standard Widget Toolkit (SWT) » drop down action?
drop down action? [message #455864] Fri, 20 May 2005 14:31 Go to next message
does anyone know how to populate Action on a toolbar which is of type
"IAction.AS_DROP_DOWN_MENU" with values?
Thanks!
Anima.
Re: drop down action? [message #455870 is a reply to message #455864] Fri, 20 May 2005 17:42 Go to previous messageGo to next message
just to be more clear here:
I have defined a Action of the time IAction.AS_DROP_DOWN_MENU - It shows
up as a down arrow, along with image on the toolbar of the view - which
is great.
Action filterAction = new Action("Filter",IAction.AS_DROP_DOWN_MENU) {
public void run() {
filterAction.setImageDescriptor(Images.ICON_FILTER);
filterAction.setToolTipText("Filter");
IToolBarManager toolbarManager =
getViewSite().getActionBars().getToolBarManager();
toolbarManager.add(filterAction);
Now I want to put some list of values in it, but I cannot see any
methods on Action to do so.
I see a ActionContributionItem class, and I am using it like this:
ActionContributionItem a = new ActionContributionItem(filterAction);
IMenuManager m = new MenuManager();
m.add(new Action("only active"){public void run(){}});
m.add(new Action("only obsolete"){public void run(){}});
a.fill(((MenuManager) m).getMenu(), 1);
But this does not see to show the drop down of 2 menu items when I click
the filterAction that shows up on the toolbar -
Can anyone tell me what I am doing wrong, or missing something?
Thanks.
Anima.
Anima Gupta wrote:
> Thanks!
> Anima.
Re: drop down action? [message #455944 is a reply to message #455870] Mon, 23 May 2005 14:33 Go to previous message
Originally posted by: venkatrj.gmail.com
You need to use ActionContributionItem class. I have a sample action class
below.
package com.microstrategy.web.sdk.seditor.actions;
import java.util.Iterator;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Menu;
import org.eclipse.swt.widgets.MenuItem;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.ActionContributionItem;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.action.IMenuCreator;
public class DropDownAction extends Action implements IMenuCreator {
private Menu fMenu;
public DropDownAction() {
setText("My Actions");
setMenuCreator(this);
public void dispose() {
if (fMenu != null) {
fMenu.dispose();
fMenu= null;
public Menu getMenu(Menu parent) {
return null;
public Menu getMenu(Control parent) {
if (fMenu != null)
fMenu.dispose();
fMenu= new Menu(parent);
int i= 0;
Action filterAction = new Action("Filter") {
public void run() {}
Action gen = new Action("gen",IAction.AS_DROP_DOWN_MENU){
public void run(){}
addActionToMenu(fMenu, filterAction);
new MenuItem(fMenu, SWT.SEPARATOR);
addActionToMenu(fMenu, gen);
return fMenu;
protected void addActionToMenu(Menu parent, Action action) {
ActionContributionItem item= new
ActionContributionItem(action);
item.fill(parent, -1);
public void run() {
* Get's rid of the menu, because the menu hangs on to
* the searches, etc.
void clear() {
dispose();
In the View, add the following code to add the above action.
DropDownAction dn = new DropDownAction();
manager.add(dn);
I hope this will solve your problem.
--venkat
> is great.
> public void run() {
> Thanks.
> Anima.
> Anima Gupta wrote:
>> Thanks!
>> Anima.
Previous Topic:Equal Height widgets on PocketPC
Next Topic:Check when user changes tabitem
Current Time: Thu Oct 23 07:39:57 EDT 2025
Powered by FUDForum. Page generated in 0.03882 seconds
